Author Topic: windshield height  (Read 1007 times)
Offline Glenn Slothower
  • COG#: 8844
windshield height
« on: March 07, 2010, 01:55:00 pm »
I want to place an order for a new cee baileys windshield.I am not sure what height to get.The salesman at c baileys recomended a 20.5.I am 5-8 tall,is this tall enough? I sometimes like to get below the shield in rain or cool weather. Any help would be great
Offline turbojoe78_MA
  • COG#: 8645
windshield height
« Reply #1 on: March 07, 2010, 10:43:00 pm »
You cant go by just your height when sizing a shield, you have to consider your body height (the dimension after your inseam) and your seat.    I'm 5'9" and have a 22.5" Cee bailey shield and i can look over it in a normal seated position by an inch or more and only have to bend down a little to look through it.    I'm 5'9" with a 32" inseam and have a stock seat and I would like to have the shield just a little taller, like 23.5" which should cut out some wind noise.    Instead of getting a taller shield I got a Corbin seat, which I'm told sits you about an inch lower on the bike.  I haven't tried the seat yet but just wanted to let you know that there's more to sizing a shield than just your height.    Joe  1968 Honda 160 Scrambler,  Sold / 1979 Kawasaki SR 650, Traded in for next one,  1978 Kawasaki KZ 1000 Z1R Turbo / 1986 Kawasaki ZX 1000R Ninja / 1999 Kawasaki Concours  COG memb# 8645
Offline Kurt_Lammon_TN
    • Plastic Repair Products
  • COG#: 9014
windshield height
« Reply #2 on: March 08, 2010, 10:30:00 am »
I'm 6'-4" and just installed the tallest Cee Bailey (26"). I followed the Cee Bailey recommendation; that the top of the screen should be level with your mouth. Using that info, I just figured out how much taller the screen needed to be, and it worked out perfect for the 26". The wind buffeting I had before with the shorter screen was terrible. The taller screen makes it SO MUCH more comfortable.    Joe's recommendation on the seat is a good one, also. I already had a Corbin installed, so no worries there.     Rode in to work today at 35 degrees. Thank goodness for my Hot Hands heated grip wraps and Heat Troller from Whitehorse Gear!
Kurt Lammon  Chattanooga, TN  2001 Kawasaki Concours (current)  1979 KZ650, 1982 Honda XR200 (long-gone)  http://www.urethanesupply.com
Offline Slybones
  • COG#: 6953
windshield height
« Reply #3 on: March 08, 2010, 09:51:00 pm »
yes the seat type/height will effect how you look over the shield. So will bar risers. With the bar risers I notice I sit up straighter and therefore look over the shield more. Many variables. I would call Murph and talk / order with him.   2003 Concours, 57K  COG #6953  IBA 28004  http://home.comcast.net/~slybones/Concours/connieMain.htm
2003 Concours, 121K
2005 GL1800ABS, 52K
COG #6953, IBA 28004
