Author Topic: Windshield Mounting Mod Question  (Read 781 times)
Offline Alekkas
  • COG#: 10513
« on: May 03, 2013, 01:53:43 am »
The PO to my bike made a windshield for the bike.  Cheap, but decent.  23.5 inches from top to bottom.
I see over the top fine.  Like it.  Just a little bit of buffeting I want to tune  - for CHEAP!
SO I have considered the saeng micro swirls.  Before doing that, I have a bright or hair brained idea.
Tell me if this has a good chance of working...
Remove all screws and get new ones 1/4 or 1/2 inch longer.  Install spacers with a washer at each end or maybe just stack some hard plastic material washers.  Reinstall.  Would raising the shield off by 1/4 " or so relieve enough back pressure to smoothen out the minor buffeting?  Would it cause harm to the mounting channel normally covered by the shield?  Thoughts?
Seagiant needs to post more!
'08 C14 / PGR  / IBA
Some ride reports:
On two wheels:
Offline CRocker
  • '02 C10 CDA # 416
Re: Windshield Mounting Mod Question
« Reply #1 on: May 03, 2013, 03:22:53 am »
Can't really think of a reason why it wouldn't work...
Good luck! :beerchug:
Offline Flat-spot
  • COG#: 11111
« Reply #2 on: May 03, 2013, 07:26:50 am »
The advantage to trying this is no permanent mods to windshield so why not try it. My guess is you might need more like 3/4 or 1 inch (or a ram-air funneling scoop :o) to get enough airflow on the backside to make a noticable difference. I made my own laminar-lip style add-on with a 1 inch gap. That was on a fairly short windshield so I didn't really notice a lot of difference. Good luck. :great:
'08 C14
