Author Topic: Yet another mod....  (Read 3549 times)
Offline SAS Mayhem
  • COG#: 9199
Yet another mod....
« on: August 07, 2012, 01:00:15 pm »
I ended up finally installing my new 11 windscreen and putting on my refective decals on the gas tank and side bags.
Cheers
Ron
« Last Edit: September 03, 2012, 07:56:42 pm by SAS Mayhem »
COG & AMA Member
06 C10
09 C14
try to live a day without doing one of the 5 D’s....Deny, Defer, Deflect, Discount and Deceit...tougher than it sounds....
Offline GF-in-CA
Re: Yet another mod....
« Reply #1 on: August 07, 2012, 01:32:06 pm »
Cool!  Where did you get the decals?
Gary F.
1998 ZGX1100
Central Valley California
Offline Snarf
  • COG#: 8302
« Reply #2 on: August 07, 2012, 01:49:25 pm »
Very nice, do you have a link to the shield? How do you like it?
Chris Lillie
02 concours (CC)
86 concours (spirit of cog)
Offline SAS Mayhem
  • COG#: 9199
« Reply #3 on: August 07, 2012, 02:53:53 pm »
 :-[  Doh !!! I knew I forgot something. The decals contact is
Alex Rodriguez Wilkes
Desert Snake Offroad
Production & Design Manager
813.863.1575
www.desertsnakeoffroad.com
Email or call Alex, nice person and very quick.
The windscreen is from
http://www.bikescreen.com/proddetail.asp?prod=KawasakiConcours8605GFss
and you can get a 10%, I'll get the code.  Also there are NO holes you must drill them.  The foruming of the windscreen is molded smaller than the inlay of the windscreen area, Snarf. By that I mean if you take the windscreen out of the box and lay it were it needs to be, it (windscreen) would be 1/4 inch to small all the way around. In the instruction it tells you to have someone "push" the windscreen on . Just a little pressue for it to start to spead and fill in the gaps. Take a magic marker and mark the holes or take a soldering iron and put a small dimple in the area to be drilled. (that's what I did) the drill bit won't dance round then. All in all it seems long but all told two people it will take 30-45 min.
I drove with in all over the week end and I love in, as you know my other windscreen was cut down to 14 inchs ans this one is forned and 11 inches. A tone mor air for me and my g/f. no really enough buffeting to complain about .
Cheers
Ron
« Last Edit: August 08, 2012, 09:39:21 am by SAS Mayhem »
COG & AMA Member
06 C10
09 C14
Offline F-106
« Reply #4 on: August 07, 2012, 04:05:36 pm »
LOOKS GOOD RON, I LIKE THAT TRUNK YOU HAVE ON THE 06. BIKE IS LOOKING GOOD!! :beerchug: :beerchug:
Offline SAS Mayhem
  • COG#: 9199
« Reply #5 on: August 07, 2012, 04:18:23 pm »
Thanks a mil.  I hope to keep her up for as long as I can. This Saturday I'm picking up a 09 Red Connie.  So I'll need to do some farkling with my new red head.  :)
 :beerchug:
Cheers
Ron
COG & AMA Member
06 C10
09 C14
Offline Dave Scott
  • COG#: 8603
« Reply #6 on: August 07, 2012, 07:45:01 pm »
I give up Ron!   :))
Looks good!
Offline Eddie-SC
  • COG#: 7073
« Reply #7 on: August 07, 2012, 11:44:03 pm »
Looking good, Ron! As an aside, did you ever find out how your painter prepped the saddle bags?
Anderson, SC
1969 Triumph Bonneville
Offline SAS Mayhem
  • COG#: 9199
« Reply #8 on: August 08, 2012, 09:40:59 am »
You know Eddie, I'm going to swing by there today and find out the details, my friend.
Cheers
Ron
COG & AMA Member
06 C10
09 C14
Offline SAS Mayhem
  • COG#: 9199
« Reply #9 on: August 08, 2012, 09:41:48 am »
I give up Ron!   :))
Looks good!
LOL I was waiting for your comment, Sport Rider
Cheers
Ron
« Last Edit: August 08, 2012, 12:22:58 pm by SAS Mayhem »
COG & AMA Member
06 C10
09 C14
Offline Alekkas
  • COG#: 10513
« Reply #10 on: August 08, 2012, 12:20:50 pm »
That looks great!
Off topic:
By what method is that ball mount attached to the dash?
What's with the passenger boards?
Seagiant needs to post more!
'08 C14 / PGR  / IBA
Some ride reports:
On two wheels:
Offline SAS Mayhem
  • COG#: 9199
« Reply #11 on: August 08, 2012, 12:29:25 pm »
That looks great!
Off topic:
Hello Alekkas,
  The ball mount is attached via 3 allenhead fastener with nuts. I removed the windscreen and the inner dash panel to gain access.
  The passenger boards are for better comfort for a passenger. I got them from JCW  and made them work, it was not a bolt in operation. But it was easy.
Cheers
Ron
COG & AMA Member
06 C10
09 C14
Offline SAS Mayhem
  • COG#: 9199
« Reply #12 on: August 08, 2012, 12:33:04 pm »
COG & AMA Member
06 C10
09 C14
Offline Alekkas
  • COG#: 10513
« Reply #13 on: August 08, 2012, 06:21:50 pm »
Nice job.
So for the ball mount, are the bolts simply "screwed" into the dash material or bolts that go through it with a nut on the bottom?
I would think they would strip if just screws right?
'08 C14 / PGR  / IBA
Some ride reports:
On two wheels:
Offline Snarf
  • COG#: 8302
« Reply #14 on: August 08, 2012, 08:12:25 pm »
More than likely, the dash plastic is not very thick.
Chris Lillie
02 concours (CC)
Offline turbojoe78_MA
  • COG#: 8645
« Reply #15 on: August 08, 2012, 10:32:57 pm »
Posted by: SAS Mayhem
« on: Today at 09:29:25 AM »
Hello Alekkas,
Sounds like there through bolted with nuts and bolts.
« Last Edit: August 08, 2012, 10:34:52 pm by turbojoe78_MA »
Offline Alekkas
  • COG#: 10513
« Reply #16 on: August 09, 2012, 01:35:35 am »
Hello Alekkas,
Thanks joe.  I really need to be getting more sleep .....
'08 C14 / PGR  / IBA
Some ride reports:
On two wheels:
Offline SAS Mayhem
  • COG#: 9199
« Reply #17 on: August 09, 2012, 01:42:30 pm »
Hello Alekkas,
That is correct. But I ONLY went thru the upper plastic, and removed the under plastic to gain access, to put the washer and nuts on. That way you dont see anything with the underpanel installer.
Cheers
Ron
COG & AMA Member
06 C10
09 C14
