Author Topic: 08-09 Heat Blockers - Are they still available?  (Read 1083 times)
Offline ConnieFan
« on: May 19, 2014, 12:51:23 pm »
Was curious about the heat blockers and tried to email Zteve. The email bounced.
Does anyone know if he still makes these?
From the Farkle directory, I used this email:  h59913@frontiernet.net
Thanks,
Joe
Every day above ground is a good day.
Offline ZG
  • COG#: 9735
Offline ConnieFan
Re: 08-09 Heat Blockers - Are they still available?
« Reply #2 on: May 19, 2014, 07:43:32 pm »
Is this the same person as Zteve's? I had seen them on eBay, but was not sure if they were the same product.
Offline 1gopokes1
« Reply #3 on: May 19, 2014, 09:30:51 pm »
just got a set off Fleabay
Offline mike
  • COG#: 9595
« Reply #4 on: May 20, 2014, 12:33:59 am »
These look like the panels I had for my 09.
Offline gsun
  • CDA #560
  • COG#: 9127
« Reply #5 on: May 20, 2014, 01:07:47 am »
I have heard that they work for the legs but shoot the heat up and you get hit anyway? Comments?
Offline mike
  • COG#: 9595
« Reply #6 on: May 20, 2014, 09:57:08 am »
Just keep in mind I live in fl & my 09 was black..... so I was dealing w/ all kinds of heat. My impression was that they definitely work to remove the heat from your legs. In my case it pushed the heat up into the tank, seat & body seam areas. I felt it made it too warm in those areas & the bike wanted to run a little warmer. I used them spring & most of a summer then pulled them off the bike. Remember.... florida heat / humidity / sun & black bike. I felt the bike dissipated heat better without the panels & left it stock after that. If I lived in a less heat prone environment I might have a different opinion. Hope this helps.
Offline gsun
  • CDA #560
  • COG#: 9127
« Reply #7 on: May 21, 2014, 12:09:54 am »
The only problem I really have with heat is at a stop and the fans come on. Traffic sucks!
Offline 1gopokes1
« Reply #8 on: June 01, 2014, 12:18:04 am »
Installed mine today ( raining)
will test it tomorrow
