Author Topic: Adding another accessory socket  (Read 891 times)
Offline raananshenhav
« on: August 26, 2011, 08:23:36 am »
Anyone have  how-to instructions for adding another socket for electrical accessories to the C14 2008?
I use the one I have for the GPD and want to add other things too.
raanan
Re: Adding another accessory socket
« Reply #1 on: August 26, 2011, 10:28:28 am »
I guess it depends what you want to use and where you want to install it. What exactly do you want to do. Just add an accessory socket, and that's it? Or more? The 08 has a 10 amp circuit for accessories on the bike from the factory. You could tap into that, or run your own circuit with fuse and accessory fuse panel to also use other farkles. What do you have in mind?
Offline C1xRider
  • I'm not monitoring this forum. PM me at zggtr.org
« Reply #2 on: August 26, 2011, 03:37:01 pm »
5 amps on the 10's & 11's.  On the 08's & 09's it is 10 amps.
2010 C14 ABS  :great:
2000 XT350
1998 C10
1983 V65 Magna
1978 SX250
« Reply #3 on: August 26, 2011, 07:02:59 pm »
Anyway, found out that for 4-5$ I can get a 1-3 outlet splitter. No need to drill or cut anything...
