Author Topic: Aftermarket Cruise Control?  (Read 7883 times)
Offline HotWire
  • It's never too late for a happy childhood!
« on: December 10, 2011, 06:36:52 pm »
Has anyone tried of heard of an aftermarket cruise control setup that will work on the Concours??????
2012 Black Concours, Mark McDade pipe, PC5, Michelin PR-2's, Muzzy lowering links
Run For The Wall 2001, 2003, 2005, 2010
Offline Larry
  • COG#: 9359
Re: Aftermarket Cruise Control?
« Reply #1 on: December 10, 2011, 06:49:17 pm »
Search the forum...you will find a lot of information already here....enjoy.
10 Kawi Concours 14 ABS
Offline Mike_M
  • COG#: 9916
« Reply #2 on: December 10, 2011, 06:54:30 pm »
There are two popular cruise control units that people use.  One is the Audiovox CC-100 (no longer made) but you can find them on ebay for around $150.  The other is a Rosta electronic cruise.  It's a bit more pricey but it holds the speed much better than the audiovox vacuum controlled unit.
2012 Scheduled Rides - so far
IBA Party (BBG)  (Done)
Moonshine         (Done)
Ed's Last Resort (Done)
Founders Feast
Trifecta
Mike Morrison
2008 Concours
IBA#: 42214
Offline ZG
  • COG#: 9735
Offline Zorlac
  • COG#: 6962
« Reply #4 on: December 10, 2011, 08:53:47 pm »
Au contraire
COG #6962
Offline wally_games
« Reply #5 on: December 10, 2011, 09:58:45 pm »
« Reply #6 on: December 10, 2011, 10:16:45 pm »
There are three popular full Cruise Controls that folks use for the C14. As all mentioned in this thread. There is the Rostra and CC100 (once an Audiovox). IIRC, Murph carries both of these units. Again IIRC, the CC-100 is now a Murph's exclusive. Both have been used extensively on the Concours (both versions).
 The third is the McCruise that again was already mentioned. Yes the McCruise is more money. But the advantage of the McCruise is that they are designed for specific motorcycles. So installation is a breeze, since they are basically plug and play. I have installed McCruise CC's on my last two bikes. As well as assisting a friend install another on his C14. All three have been basically plug and play. All three have been flawless in design and function. And when I did screw it up playing with the program. McCruise customer service was second to none. And that was from australia. They got my email and called me promptly and helped me find my screw up in short order. And this was after my daughter hung up on them thinking it was a crank phone call. I can't recommend them enough. Yes expensive. But worth every penny IMO!
Offline wally_games
« Reply #7 on: December 10, 2011, 10:26:48 pm »
Looks like a great unit. How long did it take to install and how much of the bike did you have to pull apart to put in all the bits?
« Reply #8 on: December 10, 2011, 10:31:47 pm »
You have to remove a lot of the fairing panels. But it's not bad. How long really depends on you. If your motivated and quick. A few hours. If your not a few days!  :))   All kidding aside. Marc did his on his 2010 literally in about 3 hours give or take. So it can be done. But I would plan for a day. Maybe give yourself the weekend just in-case you partake and BS more the some folks! Like I said, it can be done fairly quick. But it depends on the people or person installing it.
Offline Fred_Harmon_TX
  • COG Technical Editor
    • Angel Ride Videos
  • COG#: 2170
« Reply #9 on: December 10, 2011, 11:17:29 pm »
I've installed and used both the Audiovox and the Rostra on my C14's. I'd recommend the Rostra unit over the Audiovox. Its easier to install because you don't need any vacuum lines, has the ability to hook into the clutch switch for disengaging when you pull in the clutch, it operates better at altitude since it uses a servo instead of vacuum, and it's overall operation is smoother and it doesn't loose speed like the Audiovox sometimes does over long distances.
Fred H.
Offline HotWire
« Reply #10 on: December 11, 2011, 12:31:36 am »
Thanks everyone for the great input, guess I've got some research to do. Happy motoring to all of you that don't have that cold white stuff on the ground now!!! :beerchug:
Offline Chris
« Reply #11 on: December 14, 2011, 11:50:41 am »
+1 on mc cruise and their customer service is excellent  I bought mine used and emailed needing install directions which they sent then during install i noticed i was missing the vacuum reservoir emailed them again and they sent me detailed instructions on how to fabricate it with that accomplished back to install only to find out i was missing the brake resistor once again upon asking they gave me the info needed. I recommend this cruise not only as mentioned above because of exceptional installation, extremely well made, and excellent customer service installing was like it was made from Kawasaki and they just forgot to install it
Offline ed
« Reply #12 on: February 03, 2012, 04:07:32 am »
http://www.mccruise.com/Kawasaki-Motorcycle-Cruise-Control.html
