Author Topic: aftermarket exhaust  (Read 1434 times)
Offline dirtnut67
aftermarket exhaust
« on: July 23, 2012, 06:03:44 pm »
Can i add a aftermarket exhaust without having to add angood efi programmer of some sort?
Offline dirtnut67
Re: aftermarket exhaust
« Reply #1 on: July 23, 2012, 06:11:26 pm »
Never mind.  If i had been a little patient and research a little. I would now a fuel injection tunner of some sort is the best way to go with an after market exhaust.
« Reply #2 on: July 23, 2012, 07:33:37 pm »
Although it doesn't hurt. If your only using a slip on canister. Then a fuel processor is not really necessary. Although if going with a full exhaust, yes you should use one.
Offline dirtnut67
« Reply #3 on: July 23, 2012, 09:30:48 pm »
Are you speaking from experianc Capt Bob.  I have added cans to my other road bikes and it created a lean hesitation in the throttle.
« Reply #4 on: July 23, 2012, 09:51:35 pm »
   Yes. It has been discussed many times before. I also spoke with one of the aftermarket tuners (who sells both the power commanders and both full and slip on exhausts) about this.  He has performed dynamometer runs on all of this. He confirmed that you will not need a PC with just a slip on. But he would be more than happy to sell me a power commander (with the appropriate mapping) if I wanted. But he again told me that it wasn't necessary. Although I did purchase a PC V with his mapping, from him when I removed the secondary buttery valves from the throttle bodies.
Online cuda
  • Ignorance Is Bliss.
  • COG#: 11405
« Reply #5 on: July 23, 2012, 10:48:20 pm »
I put a 08 ZX exhaust header with out Cats (cut collector removed them) dual Two Brothers mufflers and there is NO problem . I can tell after 4,000 it really turns on.  :beerchug:
You got to get those puppies out (CATS)  for it to BREATH , old story it you can't $hit you can't eat.
« Last Edit: July 23, 2012, 10:50:27 pm by cuda »
Offline Moose
« Reply #6 on: August 23, 2012, 02:17:16 pm »
What is the weight savings from switching to an aftermarket slip on? Any Idea what the stock one weighs vs aftermarket?
I am interested in the weight savings but not really needing to tweek the fueling. Anyone know if there is a better slip on for not having to buy into the whole "Power Commander"/remapping game?
I guess If I wanted a  lighter bike, I could drop 30 pounds...but I know how likely it is for that to happen!
Thanks Moose
Offline Mad River Marc
  • COG#: 8442
« Reply #7 on: August 23, 2012, 03:14:41 pm »
From what I understand most aftermarket can's are about 20lbs lighter then stock....but honestly, if your only goal is weight savings then I recommend saving your $.   You are dealing with an almost 700lb bike,  and unless you are racing, dropping the 30lbs won't make a realistic difference IMHO
