Author Topic: Aluminum Rear luggage plate rack  (Read 710 times)
Offline Jeff
« on: September 09, 2018, 02:30:42 pm »
Looking for a basic aluminum plate that can be mounted to the rear rack to hold dry bags. I've seen a few that are replacements for the plastic Kawi pc but I'm looking for a wider in both directions plate to simply mount some straps and tie down a bag.  I may fab something up myself but wanted to see if anyone had found a similar product. I'm not looking for a plate adapter for a hard bag but rather a simple plate to mount a dry bag to.
Jeff
Re: Aluminum Rear luggage plate rack
« Reply #1 on: September 09, 2018, 06:18:47 pm »
for around $10 or less, pick up a HDPE plastic cutting board, imperiveous to weather, strong, easily cut/drilled/modified, has always been the 'go to' material for rear racks and such....
can't beat it...pretty much any size you would want is available...
https://www.tigerchef.com/tigerchef-heavy-duty-plastic-cutting-board-12andquot-x-18andquot.html
Offline Jeff
« Reply #2 on: September 09, 2018, 11:14:36 pm »
Amazing idea. Will pick one up and test out. Thanks!
Jeff
« Reply #3 on: September 10, 2018, 03:24:34 pm »
Geez, I hate it when he has good info.   :-[
« Reply #4 on: September 11, 2018, 01:03:36 am »
ya know, it ain't easy having this excessively large cranium....
try my hat on...
ooops... don't fit quite right...does it?
no worries, it will some day. ;) :)) :))
