Author Topic: Anybody tried these connectors?  (Read 781 times)
Offline strum
  • COG#: 12307
« on: February 07, 2019, 08:00:02 pm »
 I have no problem using a soldering iron and heat shrink but I saw these and wondered if they are all they say they are.
  https://www.amazon.com/Kuject-Connectors-Waterproof-Electrical-Automotive/dp/B073RMRCC3
2008 C-14
Offline CRocker
  • '02 C10 CDA # 416
Re: Anybody tried these connectors?
« Reply #1 on: February 07, 2019, 09:06:34 pm »
Butt Connectors have been around for years...I guess as long as you're careful they should work...
But, I can't help thinking...if they've been around so long...why isn't everybody using them?
Never have used them, myself...but, I think I'd use solder and some heat shrink tubing to do the job...YMMV...
« Reply #2 on: February 07, 2019, 09:25:49 pm »
interesting product, may have to add some to my collection...
I don't see any U/L spec on them tho.
and they are limited to stranded copper wire, as solder doesn't bond aluminum wire,
I found a lot of aluminum wire on the C14... when I was adding my trailer harness.
still, unique in it's own way...
Offline gsun
  • CDA #560
  • COG#: 9127
« Reply #3 on: February 07, 2019, 11:17:16 pm »
Never had a problem with butt connectors and heat shrink. But i test them before the heat shrink - pull hard. I'm liking these.
Offline Jorge
  • COG#: 9297
« Reply #4 on: February 08, 2019, 01:06:07 am »
I bought some like these, but haven't used any yet.
The ones I bought are made by TE Connectivity (if you don't recognize the name, they are a major worldwide, well established connector manufacturer)
I bought them on the recommendation of a friend who is an electrical engineer, and tole me that they work very well.
I'm not sure I would trust a no-name China knock-off on anything critical or difficult to get to just in case...
Jorge
« Reply #5 on: February 08, 2019, 02:12:02 am »
as an engineer, spec'ing products used in my designs, I can not verify efficacy... I simply must go with UL/CE approved components, for every designed assembly..
ymmv
personally, I never spec;d any "spliced" wire junction, ever... but my reputation forced that premise.. bike stuff is completely different...
ymmv
Offline Jorge
  • COG#: 9297
« Reply #6 on: February 08, 2019, 09:46:02 am »
Good points Rich.
After I read their spec spec sheet, I wonder if my heat gun will run hot enough to get these to work properly...650F
Here's a link to the spec sheet; no UL/CE rating, but since they are TE parts, I'd expect, if used properly, they'll work well.
https://www.te.com/commerce/DocumentDelivery/DDEController?Action=showdoc&DocId=Specification+Or+Standard%7FRPIP-824-00%7FG%7Fpdf%7FEnglish%7FENG_SS_RPIP-824-00_G.pdf%7F114163-000
Offline JPD
  • COG#: 12064
« Reply #7 on: February 09, 2019, 02:15:22 am »
I would only use them with a good heat gun. You will have to get the solder hot enough to flow into the wire just like with an iron. The position of the solder has to be right over the wire overlap.
Offline gsun
  • CDA #560
  • COG#: 9127
« Reply #8 on: February 09, 2019, 03:57:32 am »
Good points Rich.
Why don't you give one a go and get back to us? Just practice.... >:D
« Reply #9 on: February 11, 2019, 11:44:49 pm »
Good points Rich.
the ad does state, in the Picture, that the solder begin to melt at 280*F/130*C, but as there is no "flux" involved, and the temp may have to be higher for the "bond" I can't see it being 650*F... a normal flux core solder is in the 700*range... normally...
Normal solder bonds on wires, is when the wires are heated to temp, and solder applied, and melted by the wire temp, not the "external heat", which may result in a cold bond"... I'm gonna buy some just to have tho, BIC lighter and fixing wires always is an option...  I always carry butt crimp, and IDP (scotch lok) splices, and when all else fails in an emergency "twit-em-up-tight" wire twist, and electrical tape... has always got me home.
I do like modern stuff tho, and "in the industry" have seen many new "splice" connections and materials surface, for making emergency "field" splices, with waterproof integrity, in the "large cable" end of the spectrum (like 500-750kcmil/mcm cable and such).
Offline 4Bikes
« Reply #10 on: February 13, 2019, 03:13:12 pm »
Having put together thousands of connectors as an Electronic Technician building broadcast Radio/TV facilities, and classrooms, I have to say these electrical connectors intrigued me.  I jumped on a kit and gave it a try.  Sure enough they work well!
For the test, I stripped two 16 GA wires, and followed their instructions.  I like in-line splices to hold together mechanically before soldering.  Their instructions say to simply twist the wires together, slide the connector over the splice and use a heat gun.  For this photo (sorry it’s blurry) , I left a bit more stands showing than necessary to see the solder flow.  And darned if the 1500 watt heat gun didn’t melt the solder and skink the wrap in one shot.  I could not pull the joint apart, so I say it’s a winner.  :great:
Offline strum
  • COG#: 12307
« Reply #11 on: February 13, 2019, 06:44:25 pm »
 I may get some to try also. I want to use these in the Bowling Alley (motors and such)  Thanks for the pic 4Bikes.
  I have found I have to treat the mechanical and electrical stuff at the alley like I would motorcycle and marine because of the vibrations in the building.
2008 C-14
Offline PeterL
  • Keep that platypus away from me!
« Reply #12 on: March 11, 2019, 12:30:55 am »
I used these on my last batch of brake strobes. The wires from the LED arrays were so fine that normal soldering was very difficult for me. These let me prep everything, slip the wires into the tubes, adjust everything just so, and then hit it with my heat gun and watch the solder flow. I then did a piece of black heat shrink over the wires/connectors, both for additional strain relief as well as for the aesthetics. I've had no problems reported in over 2 years. Recommended.
Mine all mine: 2008 C14 ABS (aka "Thunder")
projects: 1982 cb750F (project "Ichigo"), 1983 VF750S (x2) (I named the first one "SabreOne" just so's I could name the second one "SabreTwo-th")
just gifted: 2003 BMW K1200RS, 2018 Multistrada 950, 2019 Yamaha Tracer GT (Nice. But I'd still rather have my friend than his bikes, y'know?)
Offline 4Bikes
« Reply #13 on: March 11, 2019, 10:44:53 am »
As a followup to my other post, I used these for real for the first time adding LED bullet brake lights to my license plate bracket.  They worked great.
Offline 4Bikes
« Reply #14 on: May 05, 2019, 02:08:53 pm »
I had another chance to test these Kuject solder seal connectors. I run the Mondo Moto MM-10 lights and had a wire break free from one of the water proof connectors in the harness they provide. I decided to bypass both connectors, so I extended the wiring harness rather than remove the plastic and replace the entire harness. I used these Kuject connectors on both extensions, so 8 connectors total were installed.
I have to say I’m impressed with how solder melts to join the wires and the heat shrink seals the connection, probably supplying a mechanical connection lacking by not twisting the wires together. Two of the connections were tucked just below the fairing so I used aluminum foil when using the heat gun. With these connectors and heat shrink on top of both of the connectors, they look solid. This is a good test for this non-mechanical solder connections since the front fork action will beat up the wires over time.
« Last Edit: May 05, 2019, 02:14:46 pm by 4Bikes »
« Reply #15 on: May 07, 2019, 02:31:58 pm »
I first used these at work over 20 years ago.  It is surprising that it has taken this long to become used more widely.  Only issue I had was if you have cheap pvc insulation and a real hot gun you can blow the insulation right off the wire trying to get the solder to flow.
