Author Topic: Brake pads  (Read 569 times)
Offline Swedge
Brake pads
« on: February 11, 2019, 02:44:54 pm »
I'm looking to buy new OEM brake pads for my '14 C14. I look at sites like this https://www.motosport.com/motorcycle/oem-parts/kawasaki/2014/concours-14-%28abs%29/front-brake which show 4 pads and then says "Qty 2". It may seem like a no-brainer but I want to make sure that I'm buying one full set for the left and right side front brakes. How many do I buy?
Offline JDSCO
  • 2016 C14
Re: Brake pads
« Reply #1 on: February 11, 2019, 04:37:52 pm »
OEM's, 1 package, 4 pads per caliper
2 calipers = 2 packages
Gen James Mattis
Re: Brake pads
« Reply #2 on: February 11, 2019, 11:23:26 pm »
I plan on trying the latest OEM pads next time, but a great pad set, from Murph, i a major reduction in cost when using EBC's, which work great.. at least mine have, They have a tendency to "hiss" a bit, but they are very reliable...
https://www.murphskits.com/product_info.php?cPath=130_157&products_id=357&osCsid=gKipNE4ov5HWtaCOSZPU1
as I say, on my '08, back then the OEM's were problematic, and deposited "sticky stuff" on the discs, but have since been changed 2 upgrades in formulation, and I think they corrected that issue...
Re: Brake pads
« Reply #3 on: February 12, 2019, 12:45:16 pm »
JDSCO has it correct.   :great:
I just swapped my fronts last spring, with OEM's.  I wasn't unhappy with the original set, got about 25k miles, and no complaints in particular with noise or judder.
Only real complaint is with the Linked-ABS on my '12, but not much I can do about that.  Some pretty obvious additional wear on the outside pads on the (right?) caliper....I think that's the one that shares with the rear brake.
Got mine off Partzilla....something like $56 per caliper (pack).
My Horns have Horns.
