I have gotten a number of messages about wanting a set of these so here is the deal.
Details on the brackets.
Made from .80 thick 4130 Aircraft steel.
I make each one by hand and are test fit on my C14.
They are drilled for the 2 mounting holes and a single mount hole for the light attach.
Bead blasted then primed, then painted with rattle can Flat black paint.
I will include 4 plated bolts to replace the 4 original mounting bolts (need a slightly longer grip).
You must mount everything with Blue loctite.
On the bolt that mounts the light I used a low profile lock nut. You could also use loctite but the nut must not be to deep. There is enough room for it between the mount bracket and strut but not much more.
You will have to take the front fender off to mount the bracket but after that you can do everything from the outside with the fender on.
They are solid and have no movement to them, They work great. If you get a pair and do not like them for any reason just send them back at your cost and I will refund all you money minus shipping.
The material gets here tomorrow and I will make 10-15 sets all at once. Should take me 7-10 days to ship them..
Cost for a set (with 4 bolts) is $45 for a pair plus shipping. So I am just going to call it $49 delivered in the CONUS. If you want a pair just PM your shipping info and what you want.I am making these by hand in a basement. And I will not be offended in the least if you do not want them. Like I said if you get them and you think they are not worth it, no probelm just send them back. I will not take any money till they are ready to ship.
If you have any questions just shoot me a email.
Thanks, Lee
