Author Topic: Best throttle lock for C-14  (Read 1582 times)
Offline Mad River Marc
  • COG#: 8442
« on: June 06, 2017, 01:46:39 pm »
So I am thinking of heading out on a weekender trip (Haven't been on the bike in a while)  and my Cruise isn't working.   Can someone recommend a basic throttle lock that works well with the C14?
Offline Goldenhornplayer
  • COG#: 12530
Re: Best throttle lock for C-14
« Reply #1 on: June 06, 2017, 01:59:49 pm »
My favorite so far is the Omni-Cruise. The Go Cruise works OK too as long as you get the aluminum one.
2014 C14 RED, EVO Flash
COG Member 12530
Offline Big Dawg
  • 2013 Goldwing, 2017 Goldwing, 2016 Concours
« Reply #2 on: June 06, 2017, 01:59:59 pm »
I like the Throttle Meister
"I had the right to remain silent, I just didn't have the abliity", Ron White
Offline BerndV
  • COG#: 11937
« Reply #3 on: June 06, 2017, 02:03:36 pm »
Home: Kalispell, MT
My garage:
2015 Kawasaki Concours 14, MC Cruise, V&H CS One, SiSF Flash, Garmin Zumo, EarthX Lithium, etc., etc.
2013 Kawasaki ZX14R, Yoshimura R-77, Ivan Flash, PCV, Rotobox Carbon Fiber Wheels
2016 Mercedes E63 S AMG, AMS ECU Flash, AMS Catless DP's
  • OtP Co-ordinator (USA) (ie: Slave Labor)
« Reply #4 on: June 06, 2017, 02:06:46 pm »
For a quick and dirty, you could use one of these.
http://www.ebay.com/itm/Universal-Motorcycle-Cruise-Control-Throttle-Assist-Grip-Wrist-Cramp-Rest-/272689929081?hash=item3f7d961b79:g:adEAAOSwhQhYxWsB&vxp=mtr
Or you could put an O'ring at the base of the throttle. (Between throttle and vibration Dampener)
I have the Vista Cruise on my C-10 and my C-14, but it takes a little bit of work to install on either.
http://www.ebay.com/itm/NEW-Sound-Off-Recreational-MCVICY-Vista-Cruise-Control-Throttle-Lock-/271136226313?hash=item3f20fa7c09:m:mac8Wgzzf-iVZC-flz_I_Tw&vxp=mtr
« Last Edit: June 06, 2017, 03:06:44 pm by connie_rider »
14 Connie (Traveler II)
03 Connie (Buddy)
  • COG#: 8442
« Reply #5 on: June 06, 2017, 02:12:50 pm »
Thanks guys
I've used the rubber ring and just found it too fiddly,   the Omnicruise looks the easiest to install.. :)
THanks again alL!!
Offline JD
« Reply #6 on: June 06, 2017, 02:51:00 pm »
I have the throttlemeister....not particularly a fan of it. It works, but it is hard to set with the gloves...by the time i set it, the bike is at a completely different speed than intended.
they say the key is to not have it completely disengaged, so it is easy to engage. Either way, not a fan.  :o
Best,
JD
« Reply #7 on: June 06, 2017, 03:08:20 pm »
I like the Vista Cruise because of EZ {1 thumb} operation...
But, I had to invent/fabricate a way to make it work on the C-14..
03 Connie (Buddy)
Offline Goat Sac
  • Cash me Outside. On my C14. How 'bout dat?
« Reply #8 on: June 06, 2017, 04:01:32 pm »
2008 C14 Silver Streak.
1995 GPZ 1100 1997 XR 600 1994 KDX 200 1986 KDX 200 1994 KLX 650
Offline ZXtasy
  • COG#: 12569
« Reply #9 on: June 06, 2017, 05:35:35 pm »
+2 on Omnicruise. I got it at bike show/press pricing and was going to use it on my ZX-10 but it did not fit, grips shorter and the angle did not let it make good contact. The ZG I just bought had the Manic Salamander CC installed, rather like the Throttlemeister concept and I find it hard to use with gloves. Dug out the Omni and it works swell!
Offline TJ
« Reply #10 on: June 06, 2017, 10:08:41 pm »
Brakeaway
Offline Derek
  • COG#: 11636
« Reply #11 on: June 06, 2017, 10:30:55 pm »
As a quick fix till cruise is fixed look into GO Cruise (available at many stores and online).   The newer version looks adjustable, I had a older plastic version when I first got the C14.  worked fine but I found it took up space on the hand grip... more than my big hands wanted to give away.
http://www.ebay.com/itm/NEW-Go-Cruise-2-Universal-Aluminum-Motorcycle-Throttle-Lock-Cruise-Control-/151847654392
2010 C14 Concours
1983 Honda V45 Sabre (sold)
Ottawa, Ontario
Offline Derek
  • COG#: 11636
« Reply #12 on: June 06, 2017, 10:37:18 pm »
Hey JD, I loved my Throttlemiester but had the same problem.... I had to reach over with the left had to set it.  I had heard from my C10 COG group about someone had made a batch of rings to solve this but he wasn't making anymore.  I asked a machinast friend (who also owns a c14) if he mound make me one.... he did  and all is good in the world again!  I installed a Rostra last winter but I still find I use the TM for short holds.
Check this out...  (not sure if he still has any left though)
2010 C14 Concours
Ottawa, Ontario
Offline JD
« Reply #13 on: June 07, 2017, 01:56:12 am »
Looks pretty cool Derek!!
Best,
JD
Offline gtskev
  • COG#: 8081
« Reply #14 on: June 08, 2017, 12:47:39 am »
+1 on the vista cruise.  Best value but does require some engineering to install.  I used a rivet but a small screw could work. Maybe other solutions out there.
Kevin,  No Bucks? No Buck Rogers...  Dick McGehee, HiBay 1, 1986
« Reply #15 on: June 08, 2017, 02:29:53 pm »
gtskev/Kevin, will you be at the National?
Would like to compare how we mounted the Vista..
« Last Edit: June 09, 2017, 03:03:07 pm by connie_rider »
03 Connie (Buddy)
Offline seagiant1
  • COG#: 11323
« Reply #16 on: June 08, 2017, 03:18:29 pm »
Hi,
        I like the Throttle Miester, but..... :great:
You have to supply the brains!!! ;D ;D ;D >:D >:D >:D
Offline Dirtwiz
  • COG#: 12372
« Reply #17 on: June 09, 2017, 02:06:44 am »
In my opinion the Trottlemeister works great. It has to be setup properly with the shims adjusted so it holds the throttle yet the throttle can still be turned by hand easily to adjust the power. Once its right its effortless. I like the look too and the heavy weight ends help with what little vibration there is to deal with.
Offline Fais
« Reply #18 on: June 09, 2017, 05:30:37 am »
^^^ well said  :great: ^^^
Offline kv5e
  • Roll miles, Keep smiles
  • Moderator
  • Push Mountain Road
  • COG#: 5063
« Reply #19 on: June 09, 2017, 02:59:54 pm »
Hi,
Come on now......let's play nice.....
Please,
Craig
South Central Area Director
Offline angelo
« Reply #20 on: June 10, 2017, 04:20:29 am »
Here is my throttlemeister story.  Showed up on my C10 bought used.  Bought a 919 and needed a kit to shift it over - called the shop, paid something like $20 don't remember.  Bought a C14 - went back to the C10 set up.
So I got it for "free."  Have used it on three bikes and 4 sets of grips.  Has worked perfectly on all.  The plastic insert that slides in under the grips is critical for precise use IMO.  I'll keep transferring this from bike to bike forever.  If I get a second bike, I'll buy another.  It just works.  Earlier posted, someone has issues engaging it - just add some friction tape - haven't done it - just guessing.
Have only had vista cruise and those plastic clipons for alternative experience.  To ME, a well set up throttlemeister is perfect for a throttle lock.  Washer. baby, washers.  All just anecdotal experience.
Offline sininja
« Reply #21 on: June 10, 2017, 03:32:04 pm »
I bought a throttlemeister, beautiful machined parts for sure and they function just fine.  However since I installed sure grip covers my hands and wrist never get sore or tired and I haven't used the throttlemeister since (2 years ago)   I've been meaning to take them off and sell them but I keep forgetting they are there lol.
« Reply #22 on: June 11, 2017, 10:47:10 am »
Another thought now that you're probably already away for the weekend. Why not take a few minutes and see if you can figure out what is wrong with your McCruise. The Manual has a trouble shooting section. Maybe it's an easy fix. A functioning CC is almost always better than any type of throttle lock. No matter how good they are. Just a thought.
Offline cuda
  • Ignorance Is Bliss.
  • COG#: 11405
« Reply #23 on: June 14, 2017, 12:18:35 am »
Offline JD
« Reply #24 on: June 14, 2017, 12:56:56 pm »
Nothing wrong with my throttlemeister. It is well machined and works as intended. I just don't enjoy the mechanism; when i have my hand on the throttle, i'm also supposed to turn the 'meister to its locking position, which messes with the selected speed on the throttle...that's why i'm not a fan.
Best,
JD
