Author Topic: Brake Rotor upgrade  (Read 738 times)
Offline att
Brake Rotor upgrade
« on: July 13, 2012, 02:11:02 am »
Hi,
I m planning to upgrade both front and rear rotor of my C14 2010 (ABS).
The problem is Connie is not that popular around in term of rotor upgrading.  Could any of you pls help give me any other sport bike model & year which uses same rotors so i can do a search around.
My target is Brembo rotor front and Braking rotor rear, well ....some info (cat#) of Brembo calipers is also very welcome
at
Re: Brake Rotor upgrade
« Reply #1 on: July 13, 2012, 07:29:26 am »
IIRC, the ZX14 is the same parts. But double check.   Murph sells EBC rotors if they would work for you. They are listed in the C14 farkle (accessories) directory under brakes.
« Last Edit: July 13, 2012, 07:31:47 am by Cap'n Bob »
Offline att
« Reply #2 on: July 13, 2012, 07:59:18 am »
Thanks Captain but i think the stock ones already from EBC, wouldn't be much different to go [again] with EBC, i m aiming for something like Brembo, Brake Tech or Braking, well, a gift from a friend so .... why not  >:D >:D, actually i even think about upgrading the Caliper to Brembo ones too
at
