Author Topic: brighter bulbs for signals and brake light  (Read 11407 times)
Offline RideBellChain
  • I ride because I can...
  • Nothing like a good sweeper on an empty road...
    • RideBellChain.com Send a bell, receive a free bell!
  • COG#: 10039
Re: brighter bulbs for signals and brake light
« Reply #25 on: May 22, 2013, 09:43:35 pm »
This is either the same one or similar to the one I bought: http://www.ebay.com/itm/Kawasaki-07-08-ZX-6R-08-11-ZG1400-Chrome-LED-Tail-Light-II-Turn-Signal-Clear-/221016011872?pt=Motorcycles_Parts_Accessories&hash=item337594b460&vxp=mtr
I have this one too, I've had it for a couple years now and no issues!  :great:
Question for ya, guys - I followed the link and bought the same one. Just pulled the tail apart...silly question: do I need to cut/splice, or does the plug it comes with plug in somewhere?  I can't seem to find where it terminates under the seat.  Looks like it goes into a larger, main wire harness...maybe I'm blind, too!  :)
Any help is appreciated!  Thanks in advance.
« Last Edit: May 23, 2013, 05:46:31 am by RideBellChain »
Ride Safe!
Mark
http://www.RideBellChain.com
Road Captain SCRC 456 - West Palm Beach, FL
ROK ROK100028857
Offline jonathan
« Reply #26 on: May 23, 2013, 01:05:05 pm »
The plug is tucked into a large rubber boot. Trust me it's in there. The new unit plugs in to the OEM harness in the same place as the OEM tail light. The yellow signal light wires need to be spliced in.
Calgary, Alberta
  • COG#: 10039
« Reply #27 on: May 23, 2013, 06:50:38 pm »
Where exactly is it? Under the toolbox? I'm ready to just cut and solder...ugh.
Looking at the shop manual, schematics, it doesn't show it...and the tail removal/install doesn't show it either.
I'm a 'tard I guess... thanks  :)
Ride Safe!
Mark
ROK ROK100028857
Offline jonathan
« Reply #28 on: May 23, 2013, 08:40:44 pm »
If I remember it's behind the ECU in the tail, so you will have to remove the tool box and flip the ECU out of the way.
Calgary, Alberta
  • COG#: 10039
« Reply #29 on: May 23, 2013, 10:55:48 pm »
OK, I'm going in.....again!
Thanks Jonathan - if I don't find it, I'm cutting and soldering...which I can do in 2 minutes.  :)
Ride Safe!
Mark
ROK ROK100028857
Offline David
  • COG#: 10605
« Reply #30 on: May 31, 2013, 12:50:54 am »
Remove the seat, remove the plastic cover -2 screws - remove the tool box and fuse box 4 screws inside the tool box - move the ECU out of the way (pull back and up - disconnect nothing) the wiring bundle and connector to the tail light is located in the tail in a rubber boot.
"Speed is fine but accuracy is final"
1976 BMW R90 RS
1992 BMW K100 RS
2000 BMW K1200 RS
2011 Kawasaki C 14
Offline jwolffie
  • COG#: 10509
« Reply #31 on: May 31, 2013, 03:43:31 am »
Also located in the rubber boot is the rear accessory plug which can come in handy for other projects too. ( 2 loose bullet connectors )
Offline firehawk618
« Reply #32 on: June 02, 2013, 04:22:51 am »
To those of you who bought the brake light with integrated turn signal, does yours use the top row of led's for the stop / parking lights and the bottom row for turn signals?
This is how mine works and I don't care for it.  I was thinking both rows would function as brake / parking lights then flash yellow when using the turn signal.....
Thanks.
2012 C14 Black
Offline Larry
  • COG#: 9359
« Reply #33 on: June 02, 2013, 08:41:19 am »
Mine uses all
10 Kawi Concours 14 ABS
Offline firehawk618
« Reply #34 on: June 03, 2013, 04:20:59 am »
Mine uses all
Where did you get yours?
I hate the way mine works and want both rows to illuminate under all circumstances.
2012 C14 Black
Offline Larry
  • COG#: 9359
« Reply #35 on: June 03, 2013, 07:07:43 am »
eBay
Offline jonathan
« Reply #36 on: June 03, 2013, 01:14:54 pm »
Mine uses a field of evenly distributed red LEDs which all function as tail and stop lights and in between the red LEDs are a field of yellow which act as turn signals. So the entire unit lights up, no matter what you are doing.
Calgary, Alberta
Offline Larry
  • COG#: 9359
« Reply #37 on: June 03, 2013, 01:48:40 pm »
Same here
Offline firehawk618
« Reply #38 on: June 03, 2013, 04:57:24 pm »
I bought mine off ebay also.
If either of your purchases isn't too old do you mind linking me the exact one you bought?
PM if you'd rather.
Thank you. :))
2012 C14 Black
Offline jonathan
Calgary, Alberta
Offline Larry
  • COG#: 9359
« Reply #40 on: June 04, 2013, 01:20:23 pm »
I couldn't find mine either, however the one I purchased used all the led's not just a row for each.  I also got the smoked tail light.  Very nice indeed.   ;D
