Author Topic: C-14 Radiator Gaurd  (Read 1158 times)
Offline Nickrides
  • Nickrides
  • Nickrides
C-14 Radiator Gaurd
« on: August 20, 2019, 02:34:34 am »
Hi Gents
Where can I find a radiator guard for my 2014 C-14?
And a Fender extender?
Sounds like cheap insurance too me
Thanks in advance!
Offline Gumby
  • Black 2011
  • COG#: 10640
Re: C-14 Radiator Gaurd
« Reply #1 on: August 20, 2019, 02:53:54 am »
Offline Nickrides
  • Nickrides
  • Nickrides
« Reply #3 on: August 20, 2019, 09:28:09 pm »
Arashi guard for 26 bucks   Whaahoo
That's just what I was looking for!!
Thank you for posting!
« Reply #4 on: August 27, 2019, 08:27:40 am »
Does that Arashi Logo come OFF???  :-\
My Horns have Horns.
Offline Gsled
  • COG#: 12448
« Reply #5 on: August 27, 2019, 01:48:35 pm »
 The only time that logo can be seen is when you're on the ground ( you not the bike) working around the front end.
« Reply #6 on: August 27, 2019, 06:39:40 pm »
No, the Logo doesn't come off.
Very difficult to see, almost invisible.
No one has ever mentioned it to me and I've had it on the bike for years.
"Arashi Racing" is a pretty famous race team in other parts of the World. :motonoises:
I have no problem having their Team Logo on the bike..
      ie; It gives me an extra 2 HP..  <sly grin> :great:
PS: Unlike Cox/etc, this Guard has rubber standoffs {seen as blue dots in the add}.
      They hold the guard away from the radiator for additional protection. {and it cost only $27  :great:}
https://www.ebay.com/itm/Arashi-Radiator-Grille-Cover-Guard-Screen-For-07-16-KAWASAKI-GTR1400-Concours-14/352240487217?fits=Model%3AConcours+14%7CMake%3AKawasaki&epid=10007590045&hash=item52032b4b31:g:39cAAOSw4T5XHfrM
« Last Edit: August 28, 2019, 03:27:18 pm by connie_rider »
Offline Road Runner
  • Beep! Beep! ... YeeHa!
  • COG#: 12399
« Reply #7 on: August 27, 2019, 10:25:55 pm »
I purchased a guard from Projekt D, but it was more than $26. A couple of different metal logo options too (like GTR 1400, etc.).
David L. Hamil
Offline ZXtasy
  • COG#: 12569
« Reply #8 on: August 27, 2019, 11:45:45 pm »
I made one out of powder coated expanded metal from the garbage at work, cost 0.00. Made a cardboard template and skinny wheel, so there was some cost I guess.
Online MAN OF BLUES
« Reply #9 on: August 28, 2019, 08:36:49 pm »
that's my kind of spirit... I like that....
 :great: :great: :great: :great: :great: :great: :beerchug: :beerchug: :beerchug: :beerchug:
we actually used that material where I worked, to cover the internal areas over the punched louvers in our large enclosures, to make them "vermin proof".. I wish I would have grabbed some before I stopped working there...
I like the one Ted noted tho, for the $... I bought some "paint roller" screens years ago, to make some, but I have no idea where I put them...
I wish I could also find the picture I took of a fellows ZX1400, with that COX mega $$$ screen, showing a kicked up 1/2" x 3" long bolt, sticking thru it, and the screen... he was very unhappy...  :rotflmao: :rotflmao:
Offline Tundra
  • 2012 Candy Arabian Red
  • "SPORT" tourer
« Reply #10 on: August 28, 2019, 10:25:30 pm »
Being cheap/poor, :truce: I bought this guard, thinking it was worth a try.
Was pleasantly surprised; It fit great and cost about $75 less than the Cox Racing guard.  :great:
https://www.ebay.com/itm/Cox-Radiator-Guard-113-11064-Kawasaki-Ninja-ZX-14-Concours-14/333290253759?fits=Model%3AConcours+14%7CMake%3AKawasaki&epid=171197217&hash=item4d99a5adbf:g:vnAAAOSwephdSlVp:sc:UPSGround!77067!US!-1
I also purchased this guard, I was not so fortunate with the fit. Mine was horrible, None of the mounting points aligned properly, but I made it work. I found the rubber bumpers that position the guard off the radiator useless and kept falling out of the screen. When replaced several times the rubber nubs that fit in the screen were cut by the sharp screen and fell out for good. I also overcame this with high temperature 1/8" rubber strips fastened between the radiator and the guard. Mine was a lesson in patience which worked out okay and looks good. I feel better about the protection coupled with the Fenda Extenda. If I had it to do again, I would spend more and get one that fit properly.
« Reply #11 on: August 29, 2019, 01:10:58 am »
Tundra has a valid point.
           I "did" have to do some work to make mine fit as I wanted.
           I'm not pushing this as perfect. Just a cheaper option that works fine.
           I like to tinker and the work to make it fit, didn't bother me. {and saving $75 appealed}
             If you want a direct bolt on, this may not be for you.
Work involved;
  Mine was delivered flat.
      I formed the curvature around the O.D. of a tire.
       {I assumed "all" the guards are delivered flat?}
  The 3 mounting points were not exact.
       I had to tweak them a bit. {and I think I made 1 bigger}.
  I had no problems with the blue standoff's. But that is a possibility.
      NOTE: I just looked at mine. All the rubber standoffs are still in place.
Offline otter
« Reply #12 on: September 02, 2019, 06:36:23 pm »
I ordered mine from projektd dot com
Stainless steel. Lips at the top, perfectly lined up bolt hole at the bottom and rubber on the perimeter to keep it from rubbing through the rad.
99 bucks US.
So simple to install that a monkey could do it.
Offline Road Runner
  • COG#: 12399
« Reply #13 on: September 03, 2019, 07:26:39 pm »
99 bucks US.
Yep; excellent choice. I did the same early in year after having a leak caused by something (rock?) cause a slight but damaging hole to my radiator. If you need to, you can use extra large alligator clips (from school supply) to hold the guard closer to the radiator. Once in place, I removed the metal handles that you use to open and close the clip. Work like a champ!
David L. Hamil
Offline Markybarky
« Reply #14 on: September 06, 2019, 02:03:40 pm »
I bought a ABS plastic extender from a guy in Edmonton, Alberta, Canada. I'm in Calgary just south of there. You can glue or bolt it on(I glued) and am very very happy with the protection.
Offline AmphibSailor
  • Cibolo, TX Hooligan
  • COG#: 12210
« Reply #15 on: September 06, 2019, 11:01:06 pm »
That would be Larry, the Blue One. He's an industry member.
« Reply #16 on: September 06, 2019, 11:55:34 pm »
The fender Extender helps prevent rocks being thrown up by the front tire.
But it does not protect the radiator from rocks that are thrown up by another bike or car.
Buddy had the Extender and still got a rock into the upper section of his radiator.   :'(
« Last Edit: September 10, 2019, 12:32:39 pm by connie_rider »
Offline Road Runner
  • COG#: 12399
« Reply #17 on: September 09, 2019, 08:35:53 pm »
Buddy had the Extender and still got a high rock thru his radiator.   :'(
Exactly. I opted for the radiator guard over the fender extender. I could have put the fender extender on, but believe it would be overkill iMO...but that's me
David L. Hamil
