Author Topic: C14 Accessories Quick Search Directory for Help and/or How To  (Read 682558 times)
« on: September 19, 2012, 08:39:01 pm »
   I figured that I would start a thread for folk's looking for information, help or instruction with C14 accessories. This is only a starting point that may answer a question or how to. These links are to past threads on the forum itself. I suggest using the search feature to do full searches on topics that you may be interested in. Obviously this will be limited in the topics and links that it provides. So doing searches might provide you with more or other information on a subject.
   Like other directories, I will lock this to keep it organized. If there's a link that you think should be included. Please PM me with the pertinent information about subject and the link itself. Also mention which directory since there are a few directories and it's not always easy to tell which one folks are referring to.
Thanks,
Bob
Auxiliary fuse panels
C14 Fuse Block Options  :     http://forum.cog-online.org/index.php/topic,28591.15.html
Battery
Shorai Battery :    http://forum.cog-online.org/index.php/topic,34208.0.html
Brakes
Braided lines questions... need your help :  http://forum.cog-online.org/index.php/topic,33063.msg165904.html#msg165904
Installed - braided brake & clutch lines! :  http://forum.cog-online.org/index.php/topic,33424.msg169378.html#msg169378
Cruise Control
Aftermarket Cruise Control? :   http://forum.cog-online.org/index.php/topic,31042.msg154858.html#msg154858
Rostra Parts :           http://forum.cog-online.org/index.php/topic,37282.0.html
Rostra Cruise Control Wiring Diagram :     http://forum.cog-online.org/index.php/topic,37149.0.html
C14 Rostra Wiring Outline :   http://forum.cog-online.org/index.php/topic,40407.0.html
Throttlemeister Instructions :       http://forum.cog-online.org/index.php/topic,25075.0.html
ECU - Reflash
guhl ecu reflash question :     http://forum.cog-online.org/index.php/topic,36819.15.html
Engine heat
Gen1 heat issues & fixes. :   http://forum.cog-online.org/index.php/topic,35217.msg187134.html#msg187134
Exhaust
STOCK EXHAUST MODIFICATIONS :   http://forum.cog-online.org/index.php/topic,39802.0.html
C14 with ZX14 exhaust :  http://forum.cog-online.org/index.php/topic,25929.0.html
Foot pegs
Buell Pegs ??  :    http://forum.cog-online.org/index.php/topic,33695.0.html
Fuel tank stuff
Auxillary Fuel Tank:   http://forum.cog-online.org/index.php/topic,36101.0.html
Motor's Auxiliary Fuel Tank:   http://forum.cog-online.org/index.php/topic,32047.0.html
Handlebar options
Adjustable handlebars :   http://forum.cog-online.org/index.php/topic,27496.0.html
Helibars Horizon ST :  http://forum.cog-online.org/index.php/topic,33835.0.html
New multi-adjustable handle bars from Precision Engineering:     http://forum.cog-online.org/index.php/topic,36950.15.html
Hand-wing/deflectors
Pope’s Ram Mount Hand Wings Design :   http://forum.cog-online.org/index.php/topic,37481.0.html
Heated Clothing
Gerbing Heated Gear Control Install  :      http://forum.cog-online.org/index.php/topic,35831.0.html
Strategies For Wiring Heated Gear?  :   http://forum.cog-online.org/index.php/topic,34938.0.html
Horn upgrades
yet another horn upgrade/install :          http://forum.cog-online.org/index.php/topic,37230.0.html
Lighting
Auxiliary LED controller :     http://forum.cog-online.org/index.php/topic,37069.0.html
Running Light/Signal LEDs :   http://forum.cog-online.org/index.php/topic,37055.15.html
Tail Light wire colors??? :    http://forum.cog-online.org/index.php/topic,34992.0.html
Luggage rack
Givi top case rack install :  http://forum.cog-online.org/index.php/topic,39267.0.html
Saddle Bags/Panniers
Bag retaining clips or pins :   http://forum.cog-online.org/index.php/topic,36592.0.html
Bag retaining Pins) :  http://forum.cog-online.org/index.php/topic,27049.msg108065/topicseen.html#msg10806
Seats
Help me, will a kawasaki zx-14 corbin seat fit a 2008 concours 14 :     http://forum.cog-online.org/index.php/topic,36047.0.html
Tip Over Protection
Top-Block Instructions in English :          http://forum.cog-online.org/index.php/topic,29494.0.html
« Last Edit: January 21, 2013, 09:11:12 am by Cap'n Bob »
Re: C14 Accessories Quick Search Directory for Help and/or How To
« Reply #1 on: November 26, 2012, 10:48:06 pm »
I decided to add a section of actual C14 problems or questions. Yes I know this should be in the general section. But I thought it may be better keeping all topics in one thread (even if technically in the wrong section).  If you want to add or make changes, please PM an existing moderator with the particulars. But please give all the information as to what directory and what you're looking to do, since there are multiple directories.
Bob
C14 general questions or problems
C14 parts and accessories
C-14 Emporium :   http://forum.cog-online.org/index.php/board,39.0.html
Concours14 Farkle (Accessories) vendor directory :   http://forum.cog-online.org/index.php/topic,27354.0.html
C14 OEM Parts Directory  :    http://forum.cog-online.org/index.php/topic,27750.0.html
GTPP 36 month extension for $339.... :   http://forum.cog-online.org/index.php/topic,27046.0.html
Oil Filters and Oil that meets Kawasaki's specifications for the C14 :   http://forum.cog-online.org/index.php/topic,33283.0.html
Body parts
mirror panel removal:   http://forum.cog-online.org/index.php/topic,47615.0.html
Diagnostics
08-09 C14 Self-Diagnosis Service Code Reading codes :   http://forum.cog-online.org/index.php/topic,26973.0.html
Engine Misc.
Engine Mount Torque:   http://forum.cog-online.org/index.php/topic,40127.0.html
What rpm should the idle be set at? :    http://forum.cog-online.org/index.php/topic,38900.0.html
Fuel Injection
autotune installation (power commander):  http://forum.cog-online.org/index.php/topic,47576.15.html
fuel injection warning :    http://forum.cog-online.org/index.php/topic,38818.0.html
Power commander V problems :   http://forum.cog-online.org/index.php/topic,39825.0.html
PC-V purchase question.. Maps publicly available v. Fuel Moto map library:   http://forum.cog-online.org/index.php/topic,47545.0.html
Gear Shift / shift Indicator
Gear Shift Indicator :   http://forum.cog-online.org/index.php/topic,39450.0.html
Rough Shifting Misc threads:
http://forum.cog-online.org/index.php/topic,39757.0.html
http://forum.cog-online.org/index.php/topic,26765.msg105997.html#msg105997
http://forum.cog-online.org/index.php/topic,37987.msg215140.html#msg215140
http://forum.cog-online.org/index.php/topic,36951.msg204469.html#msg204469
http://forum.cog-online.org/index.php/topic,36078.msg195238.html#msg195238
http://forum.cog-online.org/index.php/topic,30298.msg136692.html#msg136692
Handlebar / Handlebar controls
Hand numbness :   http://forum.cog-online.org/index.php/topic,27550.0.html
Raised and bent bars:  http://forum.cog-online.org/index.php/topic,47382.45.html
OEM Heated Grips
Heated grip question :    http://forum.cog-online.org/index.php/topic,39371.0.html
Need picture OEM right heated grip :    http://forum.cog-online.org/index.php/topic,39074.0.html
KIPASS
KiPASS Issue :   http://forum.cog-online.org/index.php/topic,39483.0.html
Kipass things to know...(Beginners should start here...) :   http://forum.cog-online.org/index.php/topic,38101.0.html
Programming C14 FOB Keys :   http://forum.cog-online.org/index.php/topic,27128.0.html
Secondary "Flies"
Flies? :    http://forum.cog-online.org/index.php/topic,19573.0.html
Secondary Butterfly Maps Revealed :   http://forum.cog-online.org/index.php/topic,28657.0.html
Suspension
Are the Ohlins ZX14 forks a direct swap? :   http://forum.cog-online.org/index.php/topic,34582.45.html
Fork Oil Change :   http://forum.cog-online.org/index.php/topic,13081.0.html
Houston - we have a problem: C-14 lowerring questions- time sensitive :   http://forum.cog-online.org/index.php/topic,37929.0.html
Lowering Bike :   http://forum.cog-online.org/index.php/topic,38404.0.html
lowering, my experience :   http://forum.cog-online.org/index.php/topic,30815.0.html
Ohlins Rear Shock update :   http://forum.cog-online.org/index.php/topic,27403.0.html
Penske shock from Traxxion :   http://forum.cog-online.org/index.php/topic,30732.0.html
Rear shock preload adjuster :   http://forum.cog-online.org/index.php/topic,38512.15.html
Setting the suspension on the C14 :   http://forum.cog-online.org/index.php/topic,35183.0.html
Stock spring rates :   http://forum.cog-online.org/index.php/topic,35890.0.html
Tracking rear shock settings :   http://forum.cog-online.org/index.php/topic,37690.0.html
ZG's full Ohlins setup and powder coat project :   http://forum.cog-online.org/index.php/topic,36666.75.html
Tires
Car Tire update:  http://forum.cog-online.org/index.php/topic,40491.msg245456.html#new
Tire Pressure Sensor
Cool weather and Low Battery warning :    http://forum.cog-online.org/index.php/topic,38384.15.html
Replacing the tire pressure sensor batteries. :   http://forum.cog-online.org/index.php/topic,37344.0.html
Running without TPMS sensors :    http://forum.cog-online.org/index.php/topic,39086.0.html
Tire Pressure Monitor question :   http://forum.cog-online.org/index.php/topic,16664.0.html
Tire Pressure Sensor Shelf Life? :   http://forum.cog-online.org/index.php/topic,38135.0.html
Triple Tree / Stem Bearing
Triple Clamp Stem Cap came loose...anything to check for? :   http://forum.cog-online.org/index.php/topic,39230.0.html
Valve Clearance
Valve Shim Calculator :   http://forum.cog-online.org/index.php/topic,34643.0.html
09 Service Manual Valve Clearance instructions :   http://forum.cog-online.org/index.php/board,1.20.html
« Last Edit: December 22, 2013, 02:10:39 pm by Cap'n Bob »
