Author Topic: Murph's lowered driver pegs  (Read 1847 times)
Offline UP
« on: November 27, 2009, 12:46:00 pm »
Got a pair of Murph's lowered driver pegs and like them a lot for the additional leg room, however, I'm having problems adjusting the rear break pedal low enough so I don't have to lift my foot to apply the break. I've raised the adjusting nut as far up as it will go. Is there something else I can do?    UP
Offline norm-9688
  • COG#: 7011
« Reply #1 on: November 27, 2009, 03:49:00 pm »
You might need to remove the pushrod and shorten it slightly and I have read where you might also need to remove one of the lock nuts to get the pedal low enough for your liking. The pegs are probably from Steve from sunny Florida if they use the Gold Wing foot peg, shoot him an email or check his site at http://www.shoodabenengineering.com/
« Reply #2 on: November 30, 2009, 09:56:00 am »
The best answer would probably come from BDF. But I don't think he's on this forum. You may have to contact him through Rick's forum. But Brian helped in the design and evaluation of Murph's new pegs. So I guarantee you that he'll be able to tell you exactly what to do.    Bionic Bob  COG & AMA member  First C14 CDA member #0220  2008 C14 & 2003 Mean Streak
Offline UP
« Reply #3 on: December 06, 2009, 05:16:00 am »
removing 1/4" from the post and the upper nut did the trick! Much improved.    UP
