Author Topic: Cold Weather Gear  (Read 1062 times)
Offline joliver
    • My former biking days.
  • COG#: 10420
Cold Weather Gear
« on: September 24, 2018, 06:23:24 pm »
A few years ago, I purchased First Gear Cold Weather Gear and wish to share my thoughts.
I got the jacket, gloves, pants and socks. Each set has a separate remote control: one unit controls the pants and socks and the other controls the jacket and gloves. I place the remotes in the little "cage" on top of Kawasaki's gas tank bag. I had mounted them on top of the fluid reservoirs. I took them off as I only use them a few days a year.
Yesterday I used the gear. I was going to the Pine Pass and being up North, it is obvious that "Winter's Coming." It was +4C which is just under 40 F. I had them cranked on full for a few minutes and had to adjust them to the lowest setting and I was plenty warm. Can't imagine how cold it would have to be to leave it on full. I start the bike before I plug them in they start to work right away.
Positives: You are warm when your buddies are turning blue. It is super easy to install. The new remotes come "programmed" so it is basically plug and play. The gloves heat mostly on the back of your hands which works well with the grip warmers. The jacket seems extra warm at the back of your neck an the small of your back. Two places that you will appreciate being warm. The pants lessen the need for a heated seat.
Negatives: You are "wired" to your bike. I got the "extensions." They give you another foot from each of the 2 cords. If you have a senior moment and forget you are connected you will likely just pull them apart. Don't do that.
Recommendations: I don't have any comparisons to other products but First Gear Cold Weather Gear works for me.
15 1400 ABS
75 Suzuki GT 550
72 Suzuki T500
69 Suzuki 250
Re: Cold Weather Gear
« Reply #1 on: September 26, 2018, 10:17:33 am »
Nice Review, and timely.  :great:
Pretty sure Warm-n-safe makes the gear for First Gear, so we know it's good stuff.
I'm looking forward to some colder weather to break mine out again.   :beerchug:
My Horns have Horns.
Offline Rob T
« Reply #2 on: December 16, 2018, 07:35:54 pm »
I've been riding in New Hapshire with the same First Gear system, down to 25* indicated and at interstate speed in full comfort. It's awesome to tour through the snow covered hills, frozen lakes, all while getting the thumbs up from guys that you know have put their cycles up for the season. I have a single dual controller so pant liner and socks on one, with jacket liner and gloves on the other.
Offline Daboo
  • COG#: 12797
« Reply #3 on: December 16, 2018, 08:20:28 pm »
The only caution I have, is if you are out of the immediate area for home, bring some warm gear for an emergency situation.  By itself, the heated gear has very little insulation.  It's great as long as it is working.  But if a wire breaks, or you blow a fuse, you now have no heat.
A spare fuse would be smart too.
Chris
John 14:6
« Reply #4 on: December 17, 2018, 10:11:53 am »
Ive also noticed another downside to owning heated gear:
If the people you ride with don't also own heated gear.....you're going to be riding alone in the winter ALOT more often.  :-[
Offline AwesomeDad
« Reply #5 on: January 03, 2019, 05:33:17 pm »
So what I’m hearing is your gifting me a set of heated gear so we can be riding buddies?
JJ
