Author Topic: CONCOURS 1400 TRIPLE TREE RAM BALL NUT  (Read 9291 times)
Offline 4Bikes
Re: CONCOURS 1400 TRIPLE TREE RAM BALL NUT
« Reply #25 on: November 19, 2014, 11:23:18 pm »
To clarify, when you say socket are you referring to the socket that fits on the new nut they ship as the solution?  I have that one.  I was asking about the size of the Hex socket needed to remove the original nut that gets replaced.  Is that also 26 mm?  Thanks for the info.
I put an inside caliper on the OEM hex bolt and measured 12 mm.  It will take a 26 mm standard socket to install the new bolt the the Ram mount attaches to.  I answered my own question!   :16: Hope this helps someone else.
I was thinking the same thing! Thanks for measuring it out, 4Bikes!!
Glad I could help. March of 2013 seems so long ago. The ram mount at that location IMHO is a great if not perfect spot to mount a GPS. It works with the tank bag too.
Offline JS_racer
« Reply #26 on: November 23, 2014, 01:00:43 pm »
Make sure you get the 26mm and the huge allen head for that mount... it's on there TIGHT too. other than that it works well.
You will come out A LOT cheaper going this route:
http://www.ebay.com/itm/RAM-Mounts-Ball-Base-Street-RAM-B-342-/251716478317?pt=Motorcycles_Parts_Accessories&fits=Make%3AKawasaki&hash=item3a9b78a56d&vxp=mtr
it simply goes in where the plastic plug is and expands. there's a youtube video for the install, it's not hard at all.
started with the ram squishy stem one, wobbled, spun, didn't work great, and was a huge pita removing and re installing.
the motorcycle lary one is much better,
Offline Robert
  • COG#: 11970
« Reply #27 on: March 24, 2018, 01:33:46 am »
MCL doesnt sell this triple tree ram ball nut anymore
Offline Colt45
  • COGnito Ergo Zoom
  • COG#: 7914
« Reply #28 on: March 24, 2018, 06:40:53 pm »
It's a great product.  Write him and ask him to make more and to make them with a 27mm hex, a more easily obtained socket.
'00 748/853 "Rosetta"
Offline Gumby40
  • I'm Gumby dammit! (Eddie Murphy, SNL)
  • '98 Conrad
  • COG#: 11474
« Reply #29 on: May 27, 2018, 01:05:23 am »
MCL customer service is nonexistent, good luck!
'74 CR125,'78 CR250,'79 YZ400, '78 Yamaha 650 Special, '80 Yamaha Maxim, '80 Honda CM400a,'85 Ninja 600,'86 CR250,'98 Suzuki Bandit 1200,'98 C-10, 2013 C14
