Concours 14 Discussion (C14 / ZG1400 / 1400GTR) => Accessories C14 => Topic started by: ChrisB on March 27, 2013, 09:19:10 pm
Title: CONCOURS 1400 TRIPLE TREE RAM BALL NUT
Post by: ChrisB on March 27, 2013, 09:19:10 pm
Trying to figure out where I want to put a ram mount for my Iphone. Anyone have any experience or opinion on using this location/ram mount?
http://www.motorcyclelarry.com/index.php?main_page=product_info&cPath=46_59&products_id=260 (http://www.motorcyclelarry.com/index.php?main_page=product_info&cPath=46_59&products_id=260)
Title: Re: CONCOURS 1400 TRIPLE TREE RAM BALL NUT
Post by: PaleRider on March 27, 2013, 09:25:59 pm
I use it for my GPS.   good spot.
Post by: stl-cards on March 28, 2013, 02:32:35 am
I have this and it works great!  I don't like lots of stuff mounted on the bars so this mount works well for me.
I have a Ram X-Grip mounted for the cell phone.  This combo seems to work like a charm.  I was very skeptical at first, but I have no worries at this point.
All in all, seems like a good option.
Post by: stl-cards on March 28, 2013, 02:52:55 am
Here is my setup with out the phone.
Post by: ZG on March 28, 2013, 03:01:18 am
It's a good mount IMO, looks even better in black!  :great:
(http://i1200.photobucket.com/albums/bb336/jaywilcox/blacknickel1_zpse9c042f0.jpg)
Post by: ChrisB on March 28, 2013, 10:49:58 am
Thats exactly the set up I was thinking about. Thanks for everyone's feed back going to order one today.
Post by: 4Bikes on March 28, 2013, 11:23:53 am
This looks like a clean solution.  Does anybody know the size of the Hex socket required to remove the original Steering Stem head bolt? It’s much bigger than the largest Hex socket that I own.
Post by: stl-cards on March 28, 2013, 12:03:37 pm
26mm   Picked up a single socket at Autozone for pretty cheap.
Post by: 4Bikes on March 28, 2013, 01:31:19 pm
To clarify, when you say socket are you referring to the socket that fits on the new nut they ship as the solution?  I have that one.  I was asking about the size of the Hex socket needed to remove the original nut that gets replaced.  Is that also 26 mm?  Thanks for the info.
Post by: Mad River Marc on March 28, 2013, 03:16:44 pm
I have the techmount.  works great :)
Post by: Gumby on March 28, 2013, 04:01:55 pm
Mine now  :nananana:
(http://i286.photobucket.com/albums/ll112/tomdvaughan/IMG_3429.jpg)
Post by: ZG on March 28, 2013, 06:08:24 pm
Mine now  :nananana:
Indeed! Pay it forward brutha!  :beerchug:
Post by: Cwo2mustang on March 28, 2013, 06:28:35 pm
I use the Ram mount reseroir cover.
http://www.motorcyclelarry.com/index.php?main_page=product_info&cPath=46_59&products_id=186 (http://www.motorcyclelarry.com/index.php?main_page=product_info&cPath=46_59&products_id=186)
and the Ram X-grip for the Iphone, it works great.
http://www.rammount.com/NewProducts/RAMxgripmount/tabid/4515/Default.aspx (http://www.rammount.com/NewProducts/RAMxgripmount/tabid/4515/Default.aspx)
Post by: 4Bikes on March 29, 2013, 05:17:51 pm
I put an inside caliper on the OEM hex bolt and measured 12 mm.  It will take a 26 mm standard socket to install the new bolt the the Ram mount attaches to.  I answered my own question!   :16: Hope this helps someone else.
Post by: Bruce_Reafsnider_TN on March 30, 2013, 12:15:10 am
Mine now  :nananana:
([url]http://i286.photobucket.com/albums/ll112/tomdvaughan/IMG_3429.jpg[/url])
What is that on the right side?  A cupholder?
Post by: Gumby on March 30, 2013, 01:02:19 pm
Yep,
http://projektd.com/product_info.php?cPath=27_39_46&products_id=183 (http://projektd.com/product_info.php?cPath=27_39_46&products_id=183)
Post by: Gigantor on March 31, 2013, 11:26:45 pm
ChrisB,
I had the stem mount and  I didn't like it, it wasn't sturdy enough.  Try the Ram mount that replaces one of the riser bolts with a ram ball with a hole in the center.  I have it on my C14 and it's rock solid.
Post by: 4Bikes on April 01, 2013, 04:03:26 pm
I put an inside caliper on the OEM hex bolt and measured 11 mm 12 mm.  It will take a 26 mm standard socket to install the new bolt the the Ram mount attaches to.  I answered my own question!   :16: Hope this helps someone else.
I corrected this post. The OEM hex nut is actually 12 mm.  When you install the new steering stem nut, it calls for a 26 mm socket, but if you wrap the bolt with one layer of duct tape, the 27 mm fits fine and will protect the finish on the bolt.  The 27 mm socket is the same one used for the real axel nut.
I just finished installing it, and it works great.
Post by: Poorboy on April 02, 2013, 02:19:19 pm
Thanks everybody!!!!  This was exactly what I was looking for.  I like things symmetrical/centered.  LOL
Post by: JS_racer on April 03, 2013, 11:43:11 am
ChrisB,
must have been the rubber deal one you slide in the hole and crank down. Not ML replacement one.
had/have both. the ML is super stable, no regrets
Post by: 4Bikes on April 03, 2013, 01:45:44 pm
ChrisB,
I was wondering about that comment too.  The replacment nut with the Ram Ball mount from Motorcycle Larry is rock solid.
Post by: PaleRider on April 03, 2013, 01:53:06 pm
ChrisB,
I also have the MCL and it is rock solid. The only thing I can think of is on a 6 or 8 inch extension they can move a little.
Post by: iMotoPilot on November 18, 2014, 08:47:01 pm
Chris,
Hoping this gets to you.   Did you go with the Moto Larry Ram Ball?  If so did you like it?
How do you undo the steering stem bolt?  From the top?  It appears smooth vs a traditional nut.
Thx
[url]http://www.motorcyclelarry.com/index.php?main_page=product_info&cPath=46_59&products_id=260[/url] ([url]http://www.motorcyclelarry.com/index.php?main_page=product_info&cPath=46_59&products_id=260[/url])
Post by: Skiee on November 19, 2014, 06:10:44 pm
I was thinking the same thing! Thanks for measuring it out, 4Bikes!!
Post by: rmills944 on November 19, 2014, 08:44:56 pm
Make sure you get the 26mm and the huge allen head for that mount... it's on there TIGHT too. other than that it works well.
You will come out A LOT cheaper going this route:
http://www.ebay.com/itm/RAM-Mounts-Ball-Base-Street-RAM-B-342-/251716478317?pt=Motorcycles_Parts_Accessories&fits=Make%3AKawasaki&hash=item3a9b78a56d&vxp=mtr (http://www.ebay.com/itm/RAM-Mounts-Ball-Base-Street-RAM-B-342-/251716478317?pt=Motorcycles_Parts_Accessories&fits=Make%3AKawasaki&hash=item3a9b78a56d&vxp=mtr)
it simply goes in where the plastic plug is and expands. there's a youtube video for the install, it's not hard at all.
Post by: 4Bikes on November 19, 2014, 11:23:18 pm
Glad I could help. March of 2013 seems so long ago. The ram mount at that location IMHO is a great if not perfect spot to mount a GPS. It works with the tank bag too.
Post by: JS_racer on November 23, 2014, 01:00:43 pm
[url]http://www.ebay.com/itm/RAM-Mounts-Ball-Base-Street-RAM-B-342-/251716478317?pt=Motorcycles_Parts_Accessories&fits=Make%3AKawasaki&hash=item3a9b78a56d&vxp=mtr[/url] ([url]http://www.ebay.com/itm/RAM-Mounts-Ball-Base-Street-RAM-B-342-/251716478317?pt=Motorcycles_Parts_Accessories&fits=Make%3AKawasaki&hash=item3a9b78a56d&vxp=mtr[/url])
started with the ram squishy stem one, wobbled, spun, didn't work great, and was a huge pita removing and re installing.
the motorcycle lary one is much better,
Post by: Robert on March 24, 2018, 01:33:46 am
MCL doesnt sell this triple tree ram ball nut anymore
Post by: Colt45 on March 24, 2018, 06:40:53 pm
It's a great product.  Write him and ask him to make more and to make them with a 27mm hex, a more easily obtained socket.
Post by: Gumby40 on May 27, 2018, 01:05:23 am
MCL customer service is nonexistent, good luck!
