Author Topic: CONCOURS 1400 TRIPLE TREE RAM BALL NUT  (Read 10476 times)
Offline ChrisB
  • COG#: 10840
« on: March 27, 2013, 09:19:10 pm »
Trying to figure out where I want to put a ram mount for my Iphone. Anyone have any experience or opinion on using this location/ram mount?
http://www.motorcyclelarry.com/index.php?main_page=product_info&cPath=46_59&products_id=260
Offline PaleRider
Re: CONCOURS 1400 TRIPLE TREE RAM BALL NUT
« Reply #1 on: March 27, 2013, 09:25:59 pm »
I use it for my GPS.   good spot.
Have Owned 2004 Honda VFR, 2004 Honda ST1300, 2000 Triumph Sprint ST.
Now 2012 ZG1400 in Pearl Arabian Red
Offline stl-cards
« Reply #2 on: March 28, 2013, 02:32:35 am »
I have this and it works great!  I don't like lots of stuff mounted on the bars so this mount works well for me.
I have a Ram X-Grip mounted for the cell phone.  This combo seems to work like a charm.  I was very skeptical at first, but I have no worries at this point.
All in all, seems like a good option.
2011 Kawa C14
2009 Kawa C14
2006 Suzuki c90t
Offline stl-cards
« Reply #3 on: March 28, 2013, 02:52:55 am »
Here is my setup with out the phone.
2011 Kawa C14
2009 Kawa C14
2006 Suzuki c90t
Offline ZG
  • COG#: 9735
« Reply #4 on: March 28, 2013, 03:01:18 am »
It's a good mount IMO, looks even better in black!  :great:
Offline ChrisB
  • COG#: 10840
« Reply #5 on: March 28, 2013, 10:49:58 am »
Thats exactly the set up I was thinking about. Thanks for everyone's feed back going to order one today.
Offline 4Bikes
« Reply #6 on: March 28, 2013, 11:23:53 am »
This looks like a clean solution.  Does anybody know the size of the Hex socket required to remove the original Steering Stem head bolt? It’s much bigger than the largest Hex socket that I own.
Offline stl-cards
« Reply #7 on: March 28, 2013, 12:03:37 pm »
26mm   Picked up a single socket at Autozone for pretty cheap.
2011 Kawa C14
2009 Kawa C14
2006 Suzuki c90t
Offline 4Bikes
« Reply #8 on: March 28, 2013, 01:31:19 pm »
To clarify, when you say socket are you referring to the socket that fits on the new nut they ship as the solution?  I have that one.  I was asking about the size of the Hex socket needed to remove the original nut that gets replaced.  Is that also 26 mm?  Thanks for the info.
Offline Mad River Marc
  • COG#: 8442
« Reply #9 on: March 28, 2013, 03:16:44 pm »
I have the techmount.  works great :)
Offline Gumby
  • Black 2011
  • COG#: 10640
« Reply #10 on: March 28, 2013, 04:01:55 pm »
Mine now  :nananana:
Offline ZG
  • COG#: 9735
« Reply #11 on: March 28, 2013, 06:08:24 pm »
Mine now  :nananana:
Indeed! Pay it forward brutha!  :beerchug:
Offline Cwo2mustang
  • COG#: 9927
« Reply #12 on: March 28, 2013, 06:28:35 pm »
Offline 4Bikes
« Reply #13 on: March 29, 2013, 05:17:51 pm »
I put an inside caliper on the OEM hex bolt and measured 12 mm.  It will take a 26 mm standard socket to install the new bolt the the Ram mount attaches to.  I answered my own question!   :16: Hope this helps someone else.
« Last Edit: April 01, 2013, 03:50:41 pm by 4Bikes »
Offline Bruce_Reafsnider_TN
« Reply #14 on: March 30, 2013, 12:15:10 am »
Mine now  :nananana:
What is that on the right side?  A cupholder?
Offline Gumby
  • Black 2011
  • COG#: 10640
Offline Gigantor
  • COG#: 9242
« Reply #16 on: March 31, 2013, 11:26:45 pm »
ChrisB,
I had the stem mount and  I didn't like it, it wasn't sturdy enough.  Try the Ram mount that replaces one of the riser bolts with a ram ball with a hole in the center.  I have it on my C14 and it's rock solid.
1988 CBR600  Long Gone, 1985 VF750   Sold
1996  Royalstar Sold, 1993 CBR1000F  Sold
2003  C-10  Sold
2008  C-14  Destroyed, 2008  C-14  So Far So Good
COG 9242   AMA 1082581  ROK ROK100028645
Offline 4Bikes
« Reply #17 on: April 01, 2013, 04:03:26 pm »
I put an inside caliper on the OEM hex bolt and measured 11 mm 12 mm.  It will take a 26 mm standard socket to install the new bolt the the Ram mount attaches to.  I answered my own question!   :16: Hope this helps someone else.
I corrected this post. The OEM hex nut is actually 12 mm.  When you install the new steering stem nut, it calls for a 26 mm socket, but if you wrap the bolt with one layer of duct tape, the 27 mm fits fine and will protect the finish on the bolt.  The 27 mm socket is the same one used for the real axel nut.
I just finished installing it, and it works great.
Offline Poorboy
  • COG#: 10571
« Reply #18 on: April 02, 2013, 02:19:19 pm »
Thanks everybody!!!!  This was exactly what I was looking for.  I like things symmetrical/centered.  LOL
2012 Concours.... "Connie the Tramp"
CDA#0430
She will lay down with the least amount provocation and doesn't care where she's at. LOL
Offline JS_racer
« Reply #19 on: April 03, 2013, 11:43:11 am »
ChrisB,
must have been the rubber deal one you slide in the hole and crank down. Not ML replacement one.
had/have both. the ML is super stable, no regrets
Offline 4Bikes
« Reply #20 on: April 03, 2013, 01:45:44 pm »
ChrisB,
I was wondering about that comment too.  The replacment nut with the Ram Ball mount from Motorcycle Larry is rock solid.
Offline PaleRider
« Reply #21 on: April 03, 2013, 01:53:06 pm »
ChrisB,
I also have the MCL and it is rock solid. The only thing I can think of is on a 6 or 8 inch extension they can move a little.
Offline iMotoPilot
    • www.imotopilot.com
« Reply #22 on: November 18, 2014, 08:47:01 pm »
Chris,
Hoping this gets to you.   Did you go with the Moto Larry Ram Ball?  If so did you like it?
How do you undo the steering stem bolt?  From the top?  It appears smooth vs a traditional nut.
Thx
Lucky has got me this far and tricky will get me in... apc
2009 Kawasaki Concours C14 ABS
Offline Skiee
  • COG#: 11459
« Reply #23 on: November 19, 2014, 06:10:44 pm »
I was thinking the same thing! Thanks for measuring it out, 4Bikes!!
2009 Concours 14 (Francis)
AMA# 3044870
CDA# 510
Offline rmills944
« Reply #24 on: November 19, 2014, 08:44:56 pm »
Make sure you get the 26mm and the huge allen head for that mount... it's on there TIGHT too. other than that it works well.
You will come out A LOT cheaper going this route:
http://www.ebay.com/itm/RAM-Mounts-Ball-Base-Street-RAM-B-342-/251716478317?pt=Motorcycles_Parts_Accessories&fits=Make%3AKawasaki&hash=item3a9b78a56d&vxp=mtr
it simply goes in where the plastic plug is and expands. there's a youtube video for the install, it's not hard at all.
