Author Topic: Corbin 70 liter rear trunk arrived!!  (Read 18300 times)
Re: Corbin 70 liter rear trunk arrived!!
« Reply #25 on: April 25, 2015, 11:27:33 am »
SWEET BABY JEBUS!!!  :-\
In all seriousness....I had issues on my 14 trip, overloading my GIVI 55l.
I'd get a shake in the bars below 35mph.
Took me a few stop to figure out that I had a bit too much weight in the tail end of the trunk, and it
was throwing-off the balance of the front end.
I even stopped at a kawi dealership to get the tire rebalanced and doublechecked.  ::)
Big trunk hold lots of gear, but overloaded big trunk become big a** boat anchor.  :-X
My Horns have Horns.
Offline Gumby
  • Black 2011
  • COG#: 10640
« Reply #26 on: April 25, 2015, 11:49:09 am »
Load it up and throw a tire on top, you'll be fine. :great:
Offline Not So Wild Turkey
  • COG#: 10559
« Reply #27 on: April 25, 2015, 12:20:18 pm »
Truly glad you like it.  Had one and hated it.  Learned to hate Corbin because of how they handled my issues.  Had issues with more than I can list but primarily the thing weighed 35 pounds empty on a stressed member designed for what 22 pounds total.  That being said we all have our own needs and desires so it only thing that matters is it works for you.  Congratulations.
2012 Concours Arabian Red & 80 Suzuki GS1100E
2003 VTX1800R Black / 1979 Suzuki GS1000E / 1969 Norton Commando
Yamaha DT3 250 / Kawasaki 100 G4TR
Offline KnoxSwift
  • COG#: 11037
« Reply #28 on: April 25, 2015, 01:05:02 pm »
I have one of these, 30K miles on it.
If you decide to spray the bottom of the trunk use a undercoat paint. the bottom will eventually become very pitted by thrown rocks form the rear tire.
I've not had any issues with my trunk in 30K except for some paint chips from rocks, if you buy from Color Rite the matching touch up stick, it matches very close.
Good Luck with it, you'll fit everything in that trunk I go grocery shopping every week with it.
Offline ZG
  • COG#: 9735
« Reply #29 on: April 25, 2015, 01:41:14 pm »
Cool, thanks KS for your feedback!  :beerchug:
Offline TJ
« Reply #30 on: April 26, 2015, 02:57:19 pm »
I sold mine to Cuda on the othed site. He was going to make a custom trunk but I do not think he did.
Offline ZG
  • COG#: 9735
« Reply #31 on: May 03, 2015, 11:31:18 pm »
Update time...  :beerchug:
The trunk is still up at the painters unfortunately but should be done any day now!  >:D
I opted to have the bottom and lower inch or so of the sides and back done in a textured black to help minimize rock chips, everything else on it is being painted matching Kawi Passion Red as my current body work.  :great: :great:
The Corbin latch-n-lock is currently at my coaters getting blacked out in ceramic coating.  :great: :great:
Now for the best part, check this out, I just couldn't wait for the trunk to mount this bad boy and check out the fit and adjust ability... Our very own Phil (aka Phil's Rack) made a custom setup for me and it is absolutely awesome IMO!   :great: :great:
He made these rails that bolt on top of my Phil's Rack (using Phil's Rack for added stability vs the Corbin mounting option directly to the passenger grab rails) and these sliders that bolt on top of the rails, the sliders are angled so that the Corbin trunk will match the same atheistic lines as the oem Kawi side cases. By sliding the sliders forward or backward will allow me to position the Corbin trunk more forward when having mama on the back or more rearward for when I have my Corbin Smuggler trunk on, and as you can see gives me multiple adjustment increments.
The fit and finish of these rails and sliders are absolutely beautiful custom craftsmanship right down to the matching black powder coat.  :great: :great:
Thank you, thank you, thank you Phil!!!  :beerchug: :beerchug: :beerchug: :beerchug: :beerchug:
I'm not worthy..  :allhail: :allhail: :allhail: :allhail: :allhail: :allhail: :allhail: :allhail: :allhail:
« Last Edit: May 10, 2015, 02:45:00 am by ZG »
Offline cuda
  • Ignorance Is Bliss.
  • COG#: 11405
« Reply #32 on: May 04, 2015, 12:38:27 am »
Someday, someday ... I'm going to mount mine in place of the smuggler
ZG was trying to steal mine ... low life  :a102:
I really don't need it yet , no time for any bike touring , I have a conversion van... I guess I'm not a REAL biker, more of a day  rider  :beerchug:
By the way TJ where do those adjustable mounts go? on  Phil's rack like ZG's ??
Offline ZG
  • COG#: 9735
« Reply #33 on: May 04, 2015, 01:09:18 am »
I'm not trying to "steal" yer's CD, but I am looking for another used one to pickup for my next paint set, hence why I pm'd ya because I knew you bought TJ's, if you're using it no worries bro, I just thought you weren't...
If anyone else has one they aren't using or want to sell please pm me, I'm paypal ready, thanks!  :beerchug:
Offline TJ
« Reply #34 on: May 04, 2015, 04:40:44 pm »
I mounted the rails directly to the supports.  Phil had not begun to produce the additional rails Jay also purchased.  He did however combine the two ideas of you look at your rails, you will see they are grooved to allow adjustment, unlike what Jay has.
When I got the Corbin I attempted the move the box forward to move the center of gravity more forward to reduce stress on the bikes supports and wanted the angle adjusted so the backrest was more upright.  I also noticed the box lines didnt match the bag lines so Phil compensated for that with the angle change on the new blocks.  I came up with a crude wooden design and the master Phil perfected things, later making the basic rails that work on all boxes.  Jay combined both for more adjustment.   Jay, be careful using both together.  You do not want the box to far aft as it may stress the bike supports.
« Last Edit: May 04, 2015, 05:20:11 pm by TJ »
  • COG#: 10559
« Reply #35 on: May 04, 2015, 04:44:12 pm »
Please forgive my rudeness but if you set the Corbin on the bench next to the bike it's likely to stress the supports.  Another opinion where nobody asked.  Does look good though.
Offline ZG
  • COG#: 9735
« Reply #36 on: May 04, 2015, 05:18:17 pm »
Huh? Sorry, I'm not following what you're saying?  :017:  ???
Offline ZG
  • COG#: 9735
« Reply #37 on: May 04, 2015, 05:20:33 pm »
Yep, noted TJ, and thanks for blazing the trail on this setup bro!  :beerchug:
  • COG#: 10559
« Reply #38 on: May 04, 2015, 05:21:16 pm »
I'm just being a D**K and overstating the excess weight issue.
Offline ZG
  • COG#: 9735
« Reply #39 on: May 04, 2015, 05:22:33 pm »
oh   ::)
 ;D  :beerchug:
Offline Dave Scott
  • COG#: 8603
« Reply #40 on: May 04, 2015, 06:27:33 pm »
so...pretty much you'll be going down the road like this?
Offline ZG
  • COG#: 9735
« Reply #41 on: May 04, 2015, 06:46:56 pm »
Looks like fun to me, and save $ on front tires!!  :motonoises: :great: :great:  :beerchug:
Offline ZG
  • COG#: 9735
« Reply #42 on: May 04, 2015, 08:17:19 pm »
 :whoo:
I just swung by my ceramic coaters place and picked up the new latch-n-lock for this big trunk, he matched it out in the same black ceramic as the latch-n-lock he did for my Corbin smuggler trunk!!  :great: :great:
« Last Edit: May 04, 2015, 08:21:04 pm by ZG »
Offline backoutonthehighway
  • ATGMOTT/MOTGAOTT
    • Back Out On The Highway
  • COG#: 9952
« Reply #43 on: May 04, 2015, 11:06:05 pm »
My, my. Baby do got back!
2011 Kawasaki Concours 14
2006 Kawasaki 1500 Vulcan Clasic
2003 Yamaha Star 650 (Sold)
Offline ZG
  • COG#: 9735
« Reply #44 on: May 05, 2015, 12:47:44 am »
Junk in da trunk for sure brother!  ;) :)  :beerchug:
Offline Bobby Lee
  • 2010 Neptune candy blue
  • South central
  • COG#: 11740
« Reply #45 on: May 07, 2015, 08:37:28 pm »
cant wait to see the finished product.
just to get an idea of size put a helmet in there and take a pic.
Love the change
Offline ZG
  • COG#: 9735
« Reply #46 on: May 07, 2015, 09:36:37 pm »
Picking it up from the painter tomorrow!  >:D
Offline ZG
  • COG#: 9735
« Reply #47 on: May 09, 2015, 02:53:23 am »
Sorry guys n gals, too much work at the office today and didn't make it to the painters until late...  :'(
Sneak preview is all ya get for tonight, loosing light and steam...  :truce:
I did go with a textured bottom for rock chips and had it color matched to the bottom part of the side cases, turned out awesome IMO and a nice match!  :great: :great:
I'll finish up tomorrow and post up some pics...  :beerchug:
Offline philipintexas
    • Phils Farkels
  • COG#: 10175
« Reply #48 on: May 09, 2015, 01:05:45 pm »
Unfortunately, you cropped the photo just enough to exclude the "sky-hook" holding the trunk up.
Offline Gumby
  • Black 2011
  • COG#: 10640
« Reply #49 on: May 09, 2015, 02:37:34 pm »
« Last Edit: May 09, 2015, 02:41:45 pm by Gumby »
