Author Topic: Cruise Control, Left or right mount?  (Read 9998 times)
Offline Fais
Re: Cruise Control, Left or right mount?
« Reply #25 on: December 14, 2016, 09:51:31 pm »
As Matt said I have mine on the right - BUt - under the switchgear not on top. A breeze with the right thumb and a balanced look since so many switches are on the left already.
Offline SteveJ.
  • COG#: 5603
« Reply #26 on: December 15, 2016, 12:50:56 am »
I just installed a Rostra on the Versys and used this SPDT momentary rocker switch as a controller for it and it works well and it is waterproof. Mounting involved no drama.
https://smile.amazon.com/ATV-Rocker-Switch-Handlebar-Control/dp/B000P0RT36/ref=pd_sim_263_9?_encoding=UTF8&pd_rd_i=B000P0RT36&pd_rd_r=JS8G5RD0D8CVMH4SRMPD&pd_rd_w=FZacO&pd_rd_wg=B3axB&psc=1&refRID=JS8G5RD0D8CVMH4SRMPD
Tick Tock, baby (Ironbuttal)
Offline Rick2world
« Reply #27 on: December 15, 2016, 01:33:27 am »
All you need is a vise, a hammer, and a piece of 3 or 4 inch wide aluminum flat stock about 1/8 inch to 5 /32 inch thick. This can be easily made into a bracket to mount over or under the handgrip on the left or right side. I made mine for the right side. with a little planning you can position the switch assembly EXACTLY where you want it to be.
I think i will take your advice and build my own bracket
Offline Rick2world
« Reply #28 on: December 15, 2016, 01:40:22 am »
IMO no it's not worth buying murphs.  It only fits on the right side and in one place. You will be required to remove the cover for the heated grip wire (if you have HG).
I brought  it and will be making my own over the winter... with -22c predicted tonight and for a few days... I got time!
Same temp here :??:
So no rush for now . I will take my time and make one that fits perfectly on the left side  ;) and doesn"t conflict with the heated grips.
Offline Fais
« Reply #29 on: December 15, 2016, 05:04:12 pm »
Found this pic. Thanks again Matt! Now I can eat pistachios, get passed by Altimas and wave at the ticketers without worry . . . Still beats a cage but dang I miss cruising at 105 . . .
Offline Derek
  • COG#: 11636
« Reply #30 on: December 17, 2016, 02:23:30 pm »
Template Done!
I chose the left and it will be where the upper orange button resides... when you have all that fancy ABS/traction control stuff!
Now to get some metal stock at a metal supply place next week.... no scraps in the garage since I moved.
2010 C14 Concours
1983 Honda V45 Sabre (sold)
Ottawa, Ontario
Offline C14lvr
« Reply #31 on: December 17, 2016, 02:36:46 pm »
That should work fine.
Mine differs in two ways...
My switch had two plastic barbed studs on the back that went through two holes, one on either side of the center slotted hole. This is how my switch is held to the plate.
My plate does not have the bracket stem.
My bracket fastens to one of the handlebar clamp bolts, (using a longer tapered head screw.) There's a tapered hole drilled in the lower left hand corner.
The replacement screw will flush out with the mounting surface, once installed.
Other than those 2 things, looks similar to mine.
2011 C14 ABS (current bike)
1982 Yamaha XJ1100J (sold)
Offline Derek
  • COG#: 11636
« Reply #32 on: December 17, 2016, 03:23:21 pm »
Bob,
I have the two plastic barbed studs on the back as well, I just didn't transfer them to this latest template as I want to measure the location a bit better.
Just looked at your picture again.... hmm will have to go retry the location, I like your location.  Back out to the cold cold garage.
2010 C14 Concours
Ottawa, Ontario
Offline Derek
  • COG#: 11636
« Reply #33 on: December 17, 2016, 03:47:29 pm »
Sticking with my plan Bob, my GPS blocks the line of sight where yours is.
thanks
2010 C14 Concours
Ottawa, Ontario
Offline C14lvr
« Reply #34 on: December 17, 2016, 04:58:03 pm »
Cool, Derek...
That's always an important challenge when adding stuff...
 :great:
Offline Rick2world
« Reply #35 on: December 22, 2016, 02:21:04 pm »
Rostra has two models of control pads, CC100 & 250-3592.
The CC100 seems to have 1 led in the center of the pas while the 250-3592 has two leds on top left and right side. Anybody know what are the differences? The CC 100 is slightly cheaper. The 250 3592 is better looking with their keys leds arrangement
Offline Derek
  • COG#: 11636
« Reply #36 on: December 22, 2016, 02:42:16 pm »
Hopefully someone can confirm but I think you are looking at 2 different units... the CC100 is the Audiovox cruise control and the 250-3592 is the upgrade Rostra controller.  the Rostra base controller is 250-3593 (and does look very much like the Audiovox controller) and does not have the "engage light" on it which is useful when running the diagnostics (so I am told).
Murph's sell both but Rostra is a electric servo controlled and the Audiovox use vacuum to operate and require a vacuum tank to be mounted somewhere.  This is one of the main reasons I choose the Rostra model over the Audiovox.  Cost is the reason I chose the Rostra over the McCruise which is about double the cost but is almost plug and play.
My Rostra is my BIG winter project.
http://forum.cog-online.org/index.php?topic=67881.0 is a good read.
If your ordering from Murph, skip the controller mount he sells, you going to want to make your own unless you want to mount it in the only position it fits.
2010 C14 Concours
Ottawa, Ontario
Offline Rick2world
« Reply #37 on: December 22, 2016, 03:09:45 pm »
Thanks Derek
This will be my concours 1400 winter project. Looking to order the Rostra cruise very soon. Like you I will be making my own bracket.
Looked at a 3 part YouTube video on this install . It gave me some good insight of the work involved.
Will need to find some good schematic diagram for this install .
I'm from Montreal btw. Not to far from you!
Offline Derek
  • COG#: 11636
« Reply #38 on: December 25, 2016, 08:53:11 pm »
Well Santa left a guitar, a video game and other noise makers under the tree this morning for the kids.... so to escape and for some real music (sound of tools making something is the real music to me) I headed to the garage.  Controller bracket build step 1, version 1 is complete!  Still have to clean and round the edges, drill the correct size for the friction pins, and paint it.  But the -6c and the smell of turkey  brought me inside!
Notice I don't have to worry about covering that pesky orange button!  :-[  Wish I did though.
And the real reason I stayed in.... my new camping tea mug.... and that's not tea in it right now!  Merry Christmas everyone!  :beerchug:
2010 C14 Concours
Ottawa, Ontario
Offline Derek
  • COG#: 11636
« Reply #39 on: January 04, 2017, 02:56:06 pm »
Getting there....  Suffering through a bad head cold so not clear enough thinking to work on wiring so doing the next best thing...
2010 C14 Concours
Ottawa, Ontario
Offline Rick2world
« Reply #40 on: January 06, 2017, 01:14:12 pm »
Hi Derek,
From the picture, it looks like you created a throttle arm extention. It the reason to get more levelage from the throttle arm?
Great work on your module bracket 👍
Keep to install pictures coming 😉
They're a great help 😀
Offline Derek
  • COG#: 11636
« Reply #41 on: January 06, 2017, 01:23:01 pm »
The extension is suppose to smooth out the engagement and acceleration.
2010 C14 Concours
Ottawa, Ontario
Offline Fais
« Reply #42 on: January 06, 2017, 05:02:35 pm »
And it will.
If I press the accell or decel button mine acts jerky. Matt suggested tapping the buttons instead and now I can control my speed smoothly. I'm sure I'll extend mine in the future = good idea.
 :beerchug:
Offline RodneyW
« Reply #43 on: January 06, 2017, 05:07:12 pm »
I put an extension on my last install, and it made a huge difference, butter smooth compared to the previous install without the arm.  It is only a tiny bit of trouble to tap a couple of holes and add the extension.  Highly recommend.  It is close quarters in there, so you can't add much without hitting something!
Offline mattchewn
  • COG#: 10993
« Reply #44 on: January 07, 2017, 12:28:56 am »
All you need is about 3/4 of an inch to make the Cruise silky smooth. This will smooth out the speed compensations for grade changes as well as button inputs. I added an extension arm to mine this go 'round and couldn't be happier with how well it works.
2018 H2 SXSE.  (FAT SXSE)
2011 GSX1250 FA
2009 Ninja 500R. (wifes')
2001 Bandit 650  (kids')
Offline JimBob
  • Woman...WHOAAAA MAN!
« Reply #45 on: January 18, 2017, 03:47:42 pm »
I mounted mine on the left and I find it works well for me.
So did Yamaha:
Dan
What model bike is that in the pic?
