Author Topic: Motorcycle Larry Passenger Peg Extenders  (Read 1637 times)
Offline HGP Connierider
  • 2012 Connierider
« on: October 05, 2014, 10:49:18 pm »
I added the Extenders to my C14. Right side hit the heat shield (or whatever it is called). Had to remove it to allow enough clearance. Anyone else have this problem?
Own a 2012 Concours currently. Owned a 2005 Concours from 2005 to 2013.
Offline Ratherberiding
  • COG#: 10482
Re: Motorcycle Larry Passenger Peg Extenders
« Reply #1 on: October 05, 2014, 11:08:01 pm »
No issues at my house, I also have a 2012 .
Offline Aussie
  • The Engineer
  • COG#: 10853
« Reply #2 on: October 06, 2014, 01:26:58 am »
No issues here either ... It is about 0.25" away from the exhaust on my 2012.
Suggestion ... Is the peg lower-er rattling? Did you clamp down the screws? I have canyon cages and I added a washer in at the top mounting point to ensure a snug fit.
2012 Kawasaki Concours 14 - Candy Arabian Red
Oviedo (near Orlando) FL
Wherever you go, there you are!
Offline Gypsy JR
  • American Gypsy
  • Living the Gypsy Life
  • COG#: 9279
« Reply #3 on: October 06, 2014, 03:47:45 am »
I had the same problem. I had to stick 2 really thin (.032) stainless steel washers in and really tighten it down to get it to stay off the front muffler cap.
If I have the problem again, I'll take it off and grind the section that is making contact. There is plenty of metal there so it won't weaken the extension.
Offline Aussie
  • The Engineer
  • COG#: 10853
« Reply #4 on: October 06, 2014, 10:58:11 am »
Hmmmm ... Is there any chance that you mounted the wrong one? There is a left and a right mount ...
  • 2012 Connierider
« Reply #5 on: October 06, 2014, 02:10:54 pm »
Ausie I have the candy Arabian red one too. The right side has more play, so when someone puts foots on pegs, it bends down enuff and back to tap on the exhasust cover. Remove the cover and there is plenty of clearance. I could not find metal washers thin enough  to shim the mounts up. Made some nylon washers. Need to drive it some to see if they rattle. Doesnt look too bad without the ehaust shield.
Offline Aussie
  • The Engineer
  • COG#: 10853
« Reply #6 on: October 06, 2014, 02:43:16 pm »
10-4 ...I'll chek the play in mine and report back ...
Offline SWOJO95
  • COG#: 190
« Reply #7 on: October 06, 2014, 04:20:59 pm »
I was looking at these online and noticed that it states "New design":
"PASSENGER FOOT PEG LOWERING BRACKETS
8018   New design. Fits all model years.   Finally relief for your passenger. They will thank you for the extra leg room. Helps relive hip,..."
Maybe you have the older design?
Offline Aussie
  • The Engineer
  • COG#: 10853
« Reply #8 on: October 06, 2014, 09:44:37 pm »
OK ... photo isn't brilliant ... but after putting 170lbs on the peg ... I am 2mm away from the exhaust. Potentially putting the "shim" washer on top (instead of underneath) probably didn't help. Upshot is that it doesn't appear to hit the muffler. time will tell.
