Author Topic: Delkevic slip on question  (Read 2984 times)
Offline Hawk600
« on: July 29, 2019, 02:04:44 am »
Hey guys, is anybody here running Delkevic 14" slip on with the bags mounted? Any concern about the heat?
I just ordered the 14" CF oval slip on but after reading the melted bag thread plus seeing most here using the 18"version instead I am started to get concerned and thinking if I should swap it for the 18"model.
https://delkevic.com/stubby-14-carbon-fiber-oval-muffler-to-fit-concours-1400-2008-2019/
I like the looks of the 14" better it is lighter and it produces slightly more power. It has a tip that is horizontal not shooting to the bottom of the bags so I imagined it should be ok, but if the case I might change it for the 18"
 :beerchug:
56taskforce
  • Guest
Re: Delkevic slip on question
« Reply #1 on: July 29, 2019, 02:24:08 am »
I have the same 14' slash cut slip on  that is on the bike in the melted bag thread. My 14' Delkalvic has been on my bike for 20,000 miles now without any sign of any more heat to the bag than the stock muffler, in fact even after a hard long ride there is no significant temperature difference between the left and right bag. If one looks at the picture in the melted bag thread I think you'll see the slip on isn't in line with the bottom of the bag and even points at the point where the bag melted. This being said it appears that care must be taken to ensure a good straight install.
Offline Charliedog
« Reply #2 on: July 29, 2019, 02:47:37 pm »
+1 to what Grant said.  I have the same silencer with the slash cut outlet on my bike with no saddle bag problems.  I wish it was a tad quieter, but I'm getting used to it after 8000 miles.....
Offline Hawk600
« Reply #3 on: July 30, 2019, 12:47:30 pm »
Thank you guys for the feedback, I am still torn between 14"or 17"/18" models.
I am watching youtube videos and reading the forums and I like the looks of the14"models over the longer ones but not sure if it will  be too loud for me.
The feedback I have from Delkevic is that 17"/18" models will not be louder than stock but will have that low frequency growl and 14" models will be a little louder than stock.
Offline Charliedog
« Reply #4 on: July 30, 2019, 11:28:25 pm »
IMHO I think the sound level difference is in the tips.  I have a 14" oval on my '06 FZ1 with the old/retro/smaller tip, and it is quieter than the 14" round I have on my C14 with the new/slash cut tip.  Both with the db-killers installed.  Both stainless silencers.
« Reply #5 on: July 31, 2019, 11:03:44 am »
 Maybe this info will help. I have heard most all of the available slipons. I will tell you the delkevics and the 2 brothers are the loudest / raspiest. I really don't like the shorty delkevics, they are LOUD.
  I also want to address the issue of running with the DB silencers installed DON'T DO IT. They are power killers.  I'm going to attach a with silencer  and without silencer dyno comparison to prove it. This is the same bike, look at the dyno run times. A fellow COG member. we put the bike on my dyno, made a couple runs, and pulled the silencer out for another couple runs. NO OTHER CHANGES.
   With the silencer, a net LOSS OF 14 HP.
  I have also done dyno work comparing stock and slip ons, and the slip ons (with no silencer) gain about 3 hp. So a delkevic with the silencer in delivers about 11HP LESS THAN STOCK.
   Steve
Offline Hawk600
« Reply #6 on: July 31, 2019, 11:32:51 am »
Thank you guys for the feedback, very informative!
Offline otter
« Reply #7 on: July 31, 2019, 07:53:01 pm »
I ordered a 14" slash cut CF yesterday before reading about the heat issue.
Called Delkevic to talk about it and they were willing to ship the slip on with an extension pipe or ship me the one with the turn down tip for less money.
I opted for the turn down tip.
I'm going to cover my bases by installing a rectangle of foil insulation (thin sandwich of foil and fibreglass) on the underside of the pannier.
« Last Edit: August 04, 2019, 07:35:10 pm by otter »
Offline Jim Snyder
  • COG#: 7055
« Reply #8 on: July 31, 2019, 08:52:20 pm »
MODIFY THE BAFFLE !!!
Offline otter
« Reply #9 on: August 02, 2019, 08:45:09 pm »
2 days from Colorado to my front door in The Great White North.
Will be installing on Sunday.
Took a close look at the can and price point vs quality: no complaints.
Online connie_rider
« Reply #10 on: August 03, 2019, 08:21:08 pm »
When you do the install, check that the tip does not direct exhaust at your rear bag hinge and you should be fine.
NOTE: Buying a muffler with a turn down tip will allow the muffler to set closer to the bag.
If it is too close or the wrong angle simply replace the frame to muffler attachment piece with a longer one and push the muffler down...
I think you'll find the 14" to be pretty loud.
I suggest; If not installed yet, exchange for the 17" or 18".
Offline otter
« Reply #11 on: August 04, 2019, 07:42:28 pm »
Did the install this morning, too easy. Fit and finish is great, looks fabulous on the bike.
14" too loud? Not at all. With the baffle in, it's still quieter than my wifes stock N1K, those shorties BARK.
The sound: now theres a nice rumble at idle, a bark when I hammer the throttle, a hint of a howl up over 7000.Burbles on slow down, no popping. I don't care about the HP loss with the baffle in, I can't really feel it, the bike is still a missile.
There's good clearance between the can and the bag, no real heat issue at all. I had opted for the turn down tip. Thought it would look goofy compared to the slash cut, but nope, it fits the bike very well.
« Last Edit: August 04, 2019, 07:56:28 pm by otter, Reason: content »
Offline angelo
« Reply #12 on: August 06, 2019, 05:47:39 pm »
I slipped on the 8" slash.  Run the bags occasionally.  Once with this pipe for a trip to the Rockies, once to Arkansas, and several weekends with my wife to Wisconsin.  Usually just use the top bag.  I bought 3M heat resistant shield tape - whatever it is called - because I was concerned of the melting stories.  Did the bottom of that bag.
No issues.  No melting or deformation.  However, a wipe down of the tape does remove some black soot.  The reflective tape looks like new when wiped off.  All just one man's anecdote.
BTW - this is the shorter of the two slash cuts.  While it certainly can get loud and obnoxious when jumping on it in the country, the cat really does keep the bike at a reasonable sound level when being mellow to get out of the neighborhood or through little downtowns / subdivisions.
Offline otter
« Reply #13 on: August 06, 2019, 10:24:58 pm »
Do you run with the baffle out? If so, do you get decel popping?
Offline angelo
« Reply #14 on: August 06, 2019, 11:21:14 pm »
Yes --- and ohhhhhh yes!  Pop pop pop.   :motonoises:  Love it for cranking in the country.
Bought it used (just the 8" slash pipe) from a guy bought for a sportster of all things.  It came without a baffle and hardly used.  Still looked clean inside!  I kept the delkevic mid pipe I had on there and just slipped this one on.  What I took off is a 17" tri oval with less than 1,000 or so miles on it.  Just not enough popping for my tastes!
If anyone wants it, It may be for sale.  All the delkevic mid pipes work with all their exhausts so one would have to see what delkevic sells the C14 (or any other bike you are interested in ) mid pipe, do the math and see what price is a good deal.  The trioval hangar would come with it.
If you care about popping and don't feel like doing pair valves, this exhaust is not for you.  The 17" tri oval burbled some in a MUCH more reserved way.  This one pops in a way some find exciting at high load / rpm engine braking.  Again, not a hassle to keep it reasonable in town or neighborhood - mostly due to the cat I am sure.
« Last Edit: August 06, 2019, 11:28:13 pm by angelo »
Offline Hawk600
« Reply #15 on: August 07, 2019, 04:39:51 pm »
Angelo, PM sent....
Offline otter
« Reply #16 on: August 07, 2019, 07:15:43 pm »
What year is yours? I'm concerned that disabling the air injection system could trigger an FI fault... Mine's an 18 with an oxygen sensor.
Online connie_rider
« Reply #17 on: August 07, 2019, 08:33:26 pm »
Can someone post the process for overriding the pair valve?
Tried to do a search. No luck so far.
Update: I found Steve's step by step to do it electrically, but seem to recall an alternative way is to block a hose below the airbox?
« Last Edit: August 07, 2019, 08:44:42 pm by connie_rider »
Offline angelo
« Reply #18 on: August 08, 2019, 12:17:09 am »
Mine is an 08.  Certainly on for over 20K miles.  Probably over 30K.  No issues.  But also not messing with any sensors.  It is from the mid pipe back to the muffler.  No messing with Cat or anything forward from there like sensors.  Hope this helps.
Offline angelo
« Reply #19 on: August 14, 2019, 03:33:30 am »
So this stuck in my mind and glad I actually remembered to post.  Anyone doing a Delkevic, the mid pipe is a straight pipe.  Meaning it get's VERY hot.  I did melt a bit of my  winter riding pants on it.
Do your self a favor, and, if you get a Delkevic, also get a silly little chrome heat shield off amazon.  I think I spent something like $15 total (shipping too) for one.  It certainly works and looks totally in place.  Otherwise, be careful when coming to a stop and putting that right foot down.   :great:
Online connie_rider
« Reply #20 on: August 14, 2019, 11:48:08 am »
My bike has 2 Area P mufflers on it. Both mid pipes have heat shields like angelo suggests.
Before the shields, my wife would melt the soles of her boots on the pipes.
I also damaged riding pant legs..
With the shields, no more melting.
Offline otter
« Reply #21 on: September 01, 2019, 05:51:50 pm »
So. I stopped being a chicken and pulled my baffle out. And I LOVE the way she sounds, deep, gutteral idle, moans at under 4k and then HOWLS when you open her up. And she sounds very reasonable under 4K.
Love the sound of it, especially the lumpy, unhappy idle when she's cold.
Online connie_rider
« Reply #22 on: September 01, 2019, 06:10:43 pm »
Congrats..
By installing slip-on's or doing a baffelectomy, you actually gain a little hp/torque.
   Not a lot, but some...  I have dyno numbers somewhere that show it.
Offline I Feel Fizzy
« Reply #23 on: September 02, 2019, 02:43:58 pm »
Can anyone comment on the Delkevic full system vs the slip on, as far as the sound level?  I don't want to make noise for noise's sake and don't want to wake the neighbors when I go to work at 6:00 a.m.  I am at least getting the slip-on, but if I buy the full system it is about $86 cheaper than buying them separate.  I am going for the 18" muffler, probably stainless.  I have a 2018.  Thanks.
Online connie_rider
« Reply #24 on: September 02, 2019, 06:26:06 pm »
Of the 2, the full system will probably be a bit louder than just the slip-on, as the Full System does not have a Cat in it.
« Last Edit: September 02, 2019, 06:36:29 pm by connie_rider »
