Author Topic: Does anyone have a Kawasaki KQR 47L top case mounted on an after-market Rack?  (Read 1138 times)
Offline philipintexas
    • Phils Farkels
  • COG#: 10175
I’m having problems occasionally with fitment of the OEM KQR top case on the Givi MonoKEY mounting kit. Anyone have the OEM trunk mounted on my rack (with the SW-MOTECH kit), or another brand rack with the MonoKEY system. Anything OTHER THAN the OEM KQR Carrier-Plate ?  I’d like to hear if it fits correctly.
Offline gilbysan
  • The Fat Ninja Rides Again!
  • COG#: 12764
Phil,
Sorry for the delay in response, I just came across your post/question. I have a '12 with this exact mounting plate the one on the right of your pic and the factory trunk.  What about your does not fit quite right?  To be clear, my trunk has a plate that bolts to the aluminum base plate using hex heads and fender washers then the trunk locks in place to the this plate.
Is this what you are wondering about?
Cheers!
Gilbysan
gilbysan
Offline ron203
  • COG#: 9847
And while we're talking Phil's products, does anyone have a Givi 52L mounted on Phil's Rack on a C-14 with the rail extenders? Phil and I were talking about that earlier today, so this is only a LITTLE hijack. :-) Thanks.
2014 C-14
2008 Goldwing
    • Phils Farkels
  • COG#: 10175
GILBYSAN:
 "my trunk has a plate that bolts to the aluminum base plate using hex heads and fender washers then the trunk locks in place to the this plate.”
That would be the older OEM trunk that was a MonoLOCK system. The KQR is the latest offering from Kawa. that is supposed to be a MonoKEY. It is sold with it’s own KQR mounting plate that replaces the stock rack. Even though it is supposed to be a Monokey, I’ve found a couple that don’t fit MY rack with the Monokey mount I sell. Thanks for the info.
Phillip, I met another COGger that told me you now offer a Monolock mount for the older OEM Monolock trunks.
Do I have correct information?
    • Phils Farkels
  • COG#: 10175
I have one left, they are not always available and I have to make mods to the rack & kit. That adds $60 to the price of my rack. Here’s a photo of the results.
I don’t know how THAT happened..???  --------------------------------------------------------------------------->
« Last Edit: May 06, 2018, 09:30:14 pm by philipintexas »
Thanks Phillip. That's exactly the mount I installed on my bike w/your rack.
I had to order the mount from Australia when I did mine...
To any that are considering a Phil's rack and have the Monolock trunks.
This mount is far superior to the one offered by Kawasaki with the earlier OEM Trunk.
« Last Edit: May 02, 2018, 04:59:58 pm by connie_rider »
