Author Topic: who is the guy that sells the aluminium bracket to replace the plastic one  (Read 1954 times)
Offline luckyman60
I do not know how to find an old post that has the info on the guy who sells this bracket.
This luggage bracket is directly behind the passenger seat.  It's plastic and you can buy this piece for $147.00
anyone know?
Offline easy_rider
are you talking about Phil's?
http://www.philsfarkels.com/
From the Concours14 farkle directory:
Luggage Racks
Philip in Texas  http://www.philsfarkels.com/
Premier Cycle Acc  http://www.premiercycleaccessories.com/Kawasaki_Concours14_Topbox_Ribbed_Rack_p/pcac14rack.htm
Offline tjhess74
  • COG#: 8406
you wont go wrong getting one of phils racks to replace that stock plastic pos.
Tom Hess  North Charleston, South Carolina    COG #8406  IBA #30337  CDA #248 (C10)    97 c10 (former)  08 c14 (current), 2007 Honda VFR800 RWB
Offline ZG
  • COG#: 9735
+1...  :iagree:
Offline ConcoursKZ
+1...  :iagree:
What is wrong with the stock one and why should I change it?
+1...  :iagree:
IMO, the OEM rear rack is cheap looking (plastic), weak and doesn't have an option to mount a top case directly to it. Where as the other racks are good looking, strong and can mount a top case directly on to it (with the mounting kit installed) without a mounting plate.
Offline ZG
  • COG#: 9735
+1...  :iagree:
Too much flex, the rear trunk will wobble...
