Author Topic: Wiring connectors  (Read 1473 times)
Offline Alan
  • COG#: 11662
Wiring connectors
« on: July 12, 2014, 11:42:25 pm »
I want to add a secondary brake light below the license plate, I use them on my other bikes, dual intensity LEDs low intensity running that flash several time when the brakes are applied and stay on steady high intensity till brakes are released. The unit is a three wire device, ground, running wire and brake wire.
I know the brake light connector is under the seat behind the tool tray and ECU.
My question is does someone know what kind of connector it is?
Also where they can be obtained?
Would like to get some and make up a plug and play harness and have it ready before I go to install it.
TIA
Alan
Don't Panic!
AMA Charter Life 34 years
GWRRA Member 3 years
LIMNCS #147
'77 BMW R100/7 Manfred
'79 Yamaha MX175
'00 Yamaha YZ250
'01 Yamaha TTR125
'04 Yamaha YZ250F
'08 Suzuki DR650SE Mootzimo
'09 Honda GL1800Navi/XM HAFACAR
'12 Kawasaki ZG1400 Concours
Highly recommend http://letsrideclyde.com/
Offline SWOJO95
  • COG#: 190
Re: Wiring connectors
« Reply #1 on: July 12, 2014, 11:56:21 pm »
Admore lighting makes a connector, may be a little overkill for just the brake light? I would just use some positaps? Here's a link to the Admore connector:
http://admorelighting.com/store/index.php?route=product/product&path=62&product_id=137
Offline Redgecko
« Reply #2 on: July 13, 2014, 12:21:44 am »
Too new to the Concours to know what the connector is but when you find out chances are you can get them here...
http://www.cycleterminal.com/motorcycle-connectors.html
Offline gPink
  • MMVIII C XIV
« Reply #3 on: July 13, 2014, 12:34:20 am »
Very good site! Thanks for the link.
Offline Redgecko
« Reply #4 on: July 13, 2014, 01:11:49 am »
No problem.  :great: Good place to deal with, I've used them a few times for the R1.
Offline Alan
  • COG#: 11662
« Reply #5 on: July 13, 2014, 01:16:53 am »
Based on the Admore photo and website they look to be Hitachi style connectors.
EasterBeaver.com has them as well.
http://easternbeaver.com/Main/Elec__Products/Connectors/110_Connectors/110_connectors.html
Thanks I wanted to know the style.
Will get some on order.
Don't Panic!
LIMNCS #147
'79 Yamaha MX175
'00 Yamaha YZ250
'01 Yamaha TTR125
'04 Yamaha YZ250F
Offline Redgecko
« Reply #6 on: July 13, 2014, 02:03:43 am »
Yeah I've used Eaton Beaver before too but CT has a larger range, is cheaper on prices and shipping and doesn't have a $20 minimum order but both are good to deal with.
Offline C. Moore
  • COG#: 6662
« Reply #7 on: July 13, 2014, 10:20:51 am »
I recently added hyper lights to my rear brake light. They came with a tap connector that seems to be working just fine. I was also able to mount the hyper lights horizontally on each side of the brake light. The cagers get blast of light now when the C14 slows down.
'10 C14  Dallas, Texas
CDA #523
COG# 6662
Offline Alan
  • COG#: 11662
« Reply #8 on: July 13, 2014, 02:14:37 pm »
[/quote]
[/quote]
Thanks Redecko,
Pricing and shipping are both better than EB even with meeting the $20 min.
I will give CT a try.
Don't Panic!
LIMNCS #147
'79 Yamaha MX175
'00 Yamaha YZ250
'01 Yamaha TTR125
'04 Yamaha YZ250F
