Author Topic: fender extender  (Read 1276 times)
Offline streetglide
fender extender
« on: July 19, 2011, 07:17:21 pm »
Has anyone tried to install the fender extender with ABS glue and without removing the fender for the install although I would think it can't be that hard to remove the fender.
Offline Bobby_Cassell_GA
  • 2004 Connie
  • COG#: 7432
Re: fender extender
« Reply #1 on: July 19, 2011, 07:32:36 pm »
I removed the fender with the wheel still on.  4 bolts on the inside.  It takes a little bit of dexterity and holding your mouth right but persistance pays off and it will come off.  I didn't use ABS glue though, I drilled 4 holes and used 4 small screws.  I'm sure the glue route will look nicer and more factory but i don't even notice the screws. Good luck.
Offline Skeeter
Re: fender extender
« Reply #2 on: July 20, 2011, 12:49:33 pm »
I wouldn't do it without removing the fender. Comes off easy enough.
You have to clean and lightly sand the mating surfaces to get best adhesion.
Make sure you align the extender carefully before the glue grabs.
Skeeter
Re: fender extender
« Reply #3 on: July 20, 2011, 11:19:08 pm »
I'm sure it could be done without fully removing the fender. But it's so easy to yank the fender, why not just remove it?
Offline streetglide
Re: fender extender
« Reply #4 on: July 21, 2011, 12:45:09 am »
Thanks, that's what I'll do
