Author Topic: Flash to Open (Garage Door Opener)  (Read 1418 times)
Offline MikeL_NJ
« on: October 04, 2017, 09:57:53 pm »
I bought it and installed the receiver without any issues but now I am working on installing the transponder to the bike. I am trying to hook the two wires to the HI (beam) headlight fuze block wires under the seat. I attached one side to the white (black stripe) wire and one to the big red wire. It's not working. Anybody else has any ideas/better install ideas? I'm all ears!
Mike
« Last Edit: October 04, 2017, 10:26:24 pm by MikeL_NJ, Reason: Wrong title name! »
Re: Flash to Pass
« Reply #1 on: October 04, 2017, 10:03:23 pm »
I'm not getting what you are asking about... transponder? What transponder?
Doesn't your bike already have a flash to pass trigger switch on the left hand grip?
Mine does... came like that from factory......
Did they do away with it on post '09 models?
What gives... or did you just never know what that trigger switch was....????
Offline Turtle
Re: Flash to Pass
« Reply #2 on: October 04, 2017, 10:14:48 pm »
My '11 has it too
Offline gpd323
Re: Flash to Pass
« Reply #3 on: October 04, 2017, 10:16:00 pm »
My 2013 has flash to pass. I toggle it over and over and the left lane huggers move right over, mostly.  ::) If they are watching their mirrors (highly doubtful) they see a cop looking bike coming up they immediately move over, of course after hitting the brakes and slowing down 20 mph under the speed limit. Then they move over!
Offline Turtle
Re: Flash to Pass
« Reply #4 on: October 04, 2017, 10:18:07 pm »
Maybe the OP means something else?  A quick part number search shows the same switch used from 2010 to current.
Offline MikeL_NJ
Re: Flash to Open (Garage Opener)
« Reply #5 on: October 04, 2017, 10:24:06 pm »
Sorry guys They apparently call it a Flash to Open thing now. It's a Garage door opener! So after reading more, I found that it's better to tap into the HI (beam) relay. I have a 2012 with the relays supposedly under the black tank cover. Does anybody know what the Hi (beam) and ground wire is into the relay?
Mike
Re: Flash to Open (Garage Door Opener)
« Reply #6 on: October 04, 2017, 10:33:48 pm »
Ahhh
I get it now...
Personally id never give up my flash to pass switch to a garage door opener... id mount a small waterproof momentary switch in the left plastic panel.. and wire it accordingly...
That flash switch has saved me 1000x from having people pull out in front of me from a sidestreet... its like a lazer beam, when popped multiple times it wakes up the idiot in the car, and says... "DONT DO IT...."...
Offline MikeL_NJ
« Reply #7 on: October 04, 2017, 10:42:22 pm »
Ahhh
I get it now...
NONO it's not replacing it or anything. It taps into the flasher and when I tap the flasher twice in front of my garage, it opens the garage door for me! I still have full function of the headlight flasher!!!!
Mike
Offline gpd323
« Reply #8 on: October 04, 2017, 10:48:52 pm »
Ok, thanks for the clarification.
I have a garage door opener right in front of me in my tank bag. Tap it coming up the hill and the garage door is open for ingress. cheers
Offline MikeL_NJ
« Reply #9 on: October 04, 2017, 10:52:59 pm »
So here's what I think. For a 2012 connie, the switched hi beam wires to the relay are white (red stripe) and black (yellow stripe). Am I correct?
Mike
« Reply #10 on: October 04, 2017, 11:47:40 pm »
Mike
No
W/R is hot
W/B is common
Y/B is a ground for the coil part of the relay..
The switch connects the first two wires I noted, if you are at that relay
Page 16-62 in FSM .... buy one, FSM that is, you will need it.....
Offline Egodriver71
  • I'm in here somewhere
  • COG#: 8321
« Reply #11 on: October 05, 2017, 10:28:51 am »
I use F2P
I tapped in on the headlight wires in the left fairing area, quick easy, keeps the transmitter out away from other electronics.
Thomas Mann
Jacksonville, FL
COG #8321
Offline Egodriver71
  • COG#: 8321
« Reply #12 on: October 05, 2017, 10:30:48 am »
Thomas Mann
Jacksonville, FL
COG #8321
Offline cappyg
« Reply #13 on: October 05, 2017, 11:18:48 am »
Ahhh
I get it now...
Amen to that, just used it yesterday coming home from work. Lady was stopped at side street getting ready to pull out in front of me.  I typically watch the front tires of the car for movement.  Sure enough she started her move and I beamed her back with 5 to 6 flashes!
Greg in Cincinnati
GTR1400 08' "Holy Kaw" Shoodaben EVO Flashed
T500 75' Suzuki Titan
XR400 98' Honda "Tractor"
Offline JDSCO
  • 2016 C14
« Reply #14 on: October 05, 2017, 12:31:22 pm »
2016 C14
Flash-to-pass "trigger" is now the LCD display toggle for various readouts.
Bummer!
Flash-to-pass "toggle" is now a third, spring-return detent on the Hi Lo toggle switch.
« Last Edit: October 05, 2017, 12:37:58 pm by JDSCO »
"Horsepower sells cars, Torque wins races!"
Jay Leno
Offline Jerdurr
« Reply #15 on: October 05, 2017, 12:45:49 pm »
Looks like a cool gadget; however, I can't help but wonder... Is it worth the 50 usd, plus installation (and possible electrical issues), vs just using a plastic remote stuck to the underside of the right or left plastic fairing with some doublesided tape? That's what i have, and it works quite well...
Just my $0.02, YMMV.
Best,
JD
« Reply #16 on: October 05, 2017, 08:25:30 pm »
I use F2P
I was going to suggest doing that also, tapping into the actual high beam wires up front, as I don't like the idea of attaching buried wires to relays and such, just my preference...
As for the 2016 models new scheme on switches... bummer, ... I love my 08's "Lazer beam trigger" ... :rotflmao: :rotflmao:
Offline NukeWorker
  • COG#: 11420
« Reply #17 on: October 05, 2017, 09:37:03 pm »
MikeL, I have a similar item, I will look when I get off work and send you a picture of how mine is wired if I can find it. I wired mine into the headlight wiring coming from the switch that's in the wiring bundle under the left top plastic panel (where the little locking box is) wasn't terribly difficult. The only issue I ran into is the crappy tap connectors do a terrible job. At some point I plan to rip them out and use Posi-Taps
2013 Concours 14 Black
Previous Bikes:
2002 V-Star 1100 Classic Silverado
1990 Kawasaki Vulcan 500
Offline Derek
  • COG#: 11636
« Reply #18 on: October 06, 2017, 08:37:35 am »
I made my own high beam garage door opener years ago and have move it along when I get a new bike.  All I needed was a universal garage door remote, a standard relay and some wire (extension came later so I didn't have to splice the wires on the bike).
Only issue I have had recently is at my new home the original garage door was too old to work with the new rotating  code version.  Newer universal remote solved that problem.
As for wiring it in... years ago I built a short 3 prong headlight extension that I take the feed from.  for the C14 I unplugged one headlight, plugged it into the extension then the other end into the back of the bulb.  Done!
2010 C14 Concours
1983 Honda V45 Sabre (sold)
Ottawa, Ontario
Offline Egodriver71
  • COG#: 8321
« Reply #19 on: October 06, 2017, 10:17:23 am »
Installation isn't difficult and very much worth it.
But if you're happy with your current setup, that's fine too...
Thomas Mann
Jacksonville, FL
COG #8321
Offline Egodriver71
  • COG#: 8321
« Reply #20 on: October 06, 2017, 10:18:44 am »
It started with the fairing redesign in 2010
Thomas Mann
Jacksonville, FL
COG #8321
Offline MikeL_NJ
« Reply #21 on: October 06, 2017, 03:20:48 pm »
YES PLEASE I'M STILL STUCK!!!!
Mike
Offline MikeL_NJ
« Reply #22 on: October 06, 2017, 03:21:46 pm »
I use F2P
Do you remember which two wires you tapped? I'm stuck and my brain has decided to stop working for me here lol
Mike
Offline MikeL_NJ
« Reply #23 on: October 07, 2017, 03:18:11 am »
Whelp thanks to everybody for their input. I got it all working! One of the positaps that I used was broken internally and was not completing the connection! For future reference at the hi beam relay, you can tap the black (yellow stripe) wire and the white (red stripe) wires. Thanks!
Mike
Offline NukeWorker
  • COG#: 11420
« Reply #24 on: October 07, 2017, 03:25:42 am »
I have a different device, an Autoswitch.  I attached one side to the Red with Black stripe wire that goes to the Hi Beam passing lamp. it runs next to a green wire. I attached the other side to the solid black accessory plug that is in the wire cluster up under the front/top/left fairing.
Photo Album
Previous Bikes:
