Author Topic: Garmin Nuvi 265 with TechMount Center GPS Mount  (Read 1761 times)
Offline aftp302
  • COG#: 9723
« on: July 26, 2011, 02:49:43 am »
So I just started the process of adding a few things to my new C14.  I bought the TechMount GPS mount along with the Quick Release plate and installed this past weekend.  Then I went to see about mounting the cradle from my Nuvi 265 to the Quick Release plate, and voila an issue.  I did not realize the "amps" bolt pattern on the Quick Release plate was not compatible with all GPS (silly me for assuming).  The cradle for my Nuvi has no bolt holes at all, nor is it even flat so that I could drill the holes myself.
Seeing as I can't be the first person to try this install, I figured I'd turn here and see if anyone had mounted this type of GPS using the TechMount system.
It would be nice to just be able to purchase a second (flat) cradle that I could mount so the GPS unit was truly interchangeable between car and bike.  I can't seem to find any cradles online other than the direct factory replacement which would be like the one I have, not flat on the back.
Thanks in advance!
Offline Rash
Re: Garmin Nuvi 265 with TechMount Center GPS Mount
« Reply #1 on: July 27, 2011, 10:46:58 am »
I use the Ram Mount and they have the cradle for all the models of GPS's. I bought two cradles for my two bikes that are fixed mounted and I use the standard mount that came with the unit for the cars. My GPS is a 265W.
www.ram-mount.com
Rash
Offline Thedugger
« Reply #2 on: August 02, 2011, 02:03:22 am »
I just posted some pictures of my Garmin 205 Nuvi.  I used the RAM mount.  As of 7/1/2011, look on page one in this forum.  It's titled Satellite Radio, Radar, GPS, and Power Socket Install.
Doug
Ride Till You Can't....
Offline looper
  • dont fear me,I am not a threat
  • COG#: 5442
« Reply #3 on: August 02, 2011, 03:07:55 am »
there is a great site called themountguys.com    check it out  I found a powerd mount for a nuvi 500 and with an easy mount mod it works great,lots of miles,no trouble.
2013 c14 ,1982 kz 1000,2008 klr ,cog #5442; sold my 2002 c10 want to buy it back ;.1969 w2 ss deceased
