Author Topic: Givi E55 Maxia 3 Tech Edition arrived.  (Read 15742 times)
Offline kilofoxtrot
« on: April 04, 2012, 05:08:05 pm »
Just got my E55 Maxia 3 Tech. Looks great on my black Connie!
« Last Edit: April 05, 2012, 12:18:54 am by kilofoxtrot »
Offline ZG
  • COG#: 9735
Re: Givi E55 Maxia 3 Tech Edition arrived.
« Reply #1 on: April 04, 2012, 05:55:37 pm »
 8)
Looking good all black KFT!  :great:
Offline JQ
« Reply #2 on: April 04, 2012, 07:43:16 pm »
Sweet looks just like mine but mine is red. Same pipe too good choice.
Offline kilofoxtrot
« Reply #3 on: April 04, 2012, 08:10:07 pm »
@JQ
I have a back rest coming. Does the back rest shove the passenger into you? Or is there still room for them to be comfortable?
kilo
Offline Larry
  • COG#: 9359
« Reply #4 on: April 04, 2012, 08:15:43 pm »
Here's mine....with the Admore light kit brake/running/turn signals...with the backrest.  Let me know what you think.  I didn't think my wife was going to like the backrest on the trunk, but she loves it.  I also have a Corbin backrest for when we are riding without the trunk.
Enjoy!
10 Kawi Concours 14 ABS
Offline JQ
« Reply #5 on: April 04, 2012, 10:21:50 pm »
@JQ
kilo
Depends on what you used to mount it. I used and adjustable PCA rack and have it all the way back. Works fine for me but my daughter is the only one that ever rides back there and she is 5'06" 125lbs. She has no issues and said it was comfy...
Offline kilofoxtrot
« Reply #6 on: April 05, 2012, 12:41:52 am »
How are you guys wiring juice to the case? I ordered the case with a remote lock. There is a quick connect/disconnect plug that is on the bottom of the case, but my SW-MOTECH rack blocks plug.
Offline JQ
« Reply #7 on: April 05, 2012, 01:57:58 pm »
Haven't yet wired anything.....I don't use it all the time but If I were I would probably use a 4 pin trailer connector for quick disconnect.
Offline DanL
« Reply #8 on: April 05, 2012, 02:37:27 pm »
that is the motorcycle equivalent to the old Lincoln mobster 2 body trunk! It's huge! Looks great too!
Offline wendel
« Reply #9 on: April 07, 2012, 01:33:41 pm »
Enjoy!
Maybe I missed it. Where do you have the Admore mounted? In the trunk? If so, I have the E55 and would be interested in more pictures of the installation.
Offline Ratherberiding
  • COG#: 10482
« Reply #10 on: April 09, 2012, 11:33:33 pm »
I had a Admore Lit on a E 470 and received nothing but compliments, Posi Tap 's come with the Kit and very simple to wire . I kept the wire harness under the seat until I had to case on .Ran up the front and plugged in to case with a 90 deg connector, very clean and awesome lights.      www.admorelighting.com
Offline OregonLAN
« Reply #11 on: April 10, 2012, 10:03:08 pm »
Here's mine:
I routed the Admore wire through the hole that the tail light uses. I used a Dremel to create a small notch in the tail light assembly, so I could fish the wire back in when not in use.
Offline ZG
  • COG#: 9735
« Reply #12 on: April 10, 2012, 11:02:24 pm »
Offline Larry
  • COG#: 9359
« Reply #13 on: April 11, 2012, 01:45:18 pm »
I mounted mine almost identical to OL....here is a little video so you get the idea.....enjoy.
http://s167.photobucket.com/albums/u149/ljcorby/?action=view&current=GiviCasewithLights4.mp4
« Reply #14 on: August 01, 2014, 02:49:50 pm »
Old thread, but going to bump it since this is Givi Maxia specific question:
For you guys (or any others) that bought and mounted a Givi Maxia e55 top box, did you find it necessary to upgrade the base rack from OEM to Phils' all metal plate??
I GET that I need to buy the Givi specific plate for the attachment, but want to know if I should or WANT to upgrade the base as well??
Sorry for the old post bump.
My Horns have Horns.
Offline Larry
  • COG#: 9359
« Reply #15 on: August 01, 2014, 04:31:12 pm »
Enjoy!
If you look in the first pic, you will see the plug for Admore light kit.  My wife and I always use the case.  I originally went with Phil's rack which was not adjustable front to back and this is before he offered the rails for moving the rack back, so at the time went with the Premier Accessories rack that was adjustable.
Offline Larry
  • COG#: 9359
« Reply #16 on: August 01, 2014, 04:38:09 pm »
If you are getting the Givi E55NT MAxia trunk, do yourself a favor and definitely replace the stock rack, you will be glad you did.  Some are also getting the GIVI mounting kit to make it even sturdier, but I didn't do that.  You can go with either Phil's rack with the Givi mounts provided by Phil, or you can go with the PCA rack again with the Givi mounts.  If you do this, you don't need any GIVI supplied rack.  Make sense?
« Reply #17 on: August 02, 2014, 12:44:02 am »
Yes. Got it!
And thank you.
I found the add-on for the monokey plate on Phils's site, which is what I think I'll do.
Any other tips of tricks for the 55??  Planning on Admore lights for sure, maybe a tank pad and liners later.  >:D
Offline Brass
« Reply #18 on: August 02, 2014, 12:35:12 pm »
I recommend the Givi bike specific mounting plate for no other reason but that it has rear support arms and the kit provides metal braces for the rear subframe
Shaun - Collegeville PA
2017 Yamaha FZ-07
Offline Fork
  • COG#: 10691
« Reply #19 on: August 02, 2014, 02:02:15 pm »
Larry: What is the imprint on the front of the pillion section of your Corbin seat and how do you get something like that done by Corbin?  Looks neat.
Fork
Offline Bigfoot_16
« Reply #20 on: August 15, 2014, 06:14:49 pm »
Fork
The stitched graphic comes with the Corbin seat by default. It does look sharp.
Jim
2015 Concours 14
Offline ZG
  • COG#: 9735
« Reply #21 on: August 15, 2014, 09:51:51 pm »
Fork
You can ask for it not to be on there, that's what I did...
Offline mattchewn
  • COG#: 10993
« Reply #22 on: August 16, 2014, 01:36:14 am »
GR,
If you can swing the funds, the rack upgrade is a no brainer. The stock rack will allow the top case to wiggle and wobble and the stock rack will eventually crack and break. The Phils' rack is the way to go. Plus it makes for a super clean install and looks great when you leave the case at home as well!
2018 H2 SXSE.  (FAT SXSE)
2011 GSX1250 FA
2009 Ninja 500R. (wifes')
2001 Bandit 650  (kids')
« Reply #23 on: August 17, 2014, 11:03:29 am »
GR,
Perfect. Sold!
Thanks Matt, and everyone.
Offline Lablank
  • COG#:10624
  • COG#: 10624
« Reply #24 on: August 21, 2014, 06:29:42 pm »
I'm using the metal rack from AST (I know some people are having issues with AST service quality!) with the monokey fittings, but it's the same idea as Phil's rack - way more solid than the plastic OEM rack. You need the upgrade because the OEM plastic is not up to par for a box the size of the E55.  With regards to the back rest, my SO prefers riding without because it gives her more space - it is still comfortable because of the back protector in her Rev'it jacket.  I like the monokey fittings to the upgraded metal rack better than the add-on givi template - looks cleaner, even if the givi template is possibly more sturdy.
Good luck.
Rene
2012 C14 Candy Arabian Red
2005 Hayabusa Red/Black
1988 Katana 1100
1990 Intruder 800
1979 GS1000E
1978 GS750E
1973 CB350
