Author Topic: Givi55 + Admore LED Lights + ROSTRA rear brake relay  (Read 1665 times)
« on: March 06, 2016, 03:41:18 pm »
Another Rostra Install question:
For those who have a Givi(55) Top case with the Admore LED lighting package, and integrated lighting Harness from Admore.....
Have any of you had ANY issues tapping the rear OEM brake light power line to use for the Rostra de-activation Relay???
I have not TRIED this yet, but wanted to see if anyone else has to ensure that I'm not going to get any feedback/crosstalk between the units that could cause a malfunction in either.
I already had ONE Admore harness with Integrated circuit FAIL due to poor wiring from Admore, which fried the board and Admore was unwilling to replace gratis.  No matter.
Just want to be sure that this install won't do any harm to either Admore or Rostra.
Thanks!
My Horns have Horns.
Offline Sailor Rich
  • COG#: 9318
Re: Givi55 + Admore LED Lights + ROSTRA rear brake relay
« Reply #1 on: March 06, 2016, 05:25:37 pm »
I also have the same light package in my 55 and it works fine. but not the intergrated harness.
« Last Edit: March 06, 2016, 05:32:18 pm by Sailor Rich »
« Reply #2 on: March 09, 2016, 03:23:21 am »
C'mon guys.....88 views and NOBODY has the same setup with a Rostra?!?!
i call b.s.  :pokestick:
Offline Zarticus
  • COG#: 10785
« Reply #3 on: March 09, 2016, 03:59:31 am »
I have the 47L Trunk with admore lighting kit. When I installed my Rostra I tapped the brake from the front of the bike & have had no problems. Just tap it from the front " ::)" & you will have no problems  :beerchug:
1986 Honda V65 Magna, Black
1984 Honda V65 Magna, Black
1983 Honda V45 Sabre, Red
Offline Bigfoot_16
« Reply #4 on: March 09, 2016, 05:20:22 am »
I have the same Admore and Rostra setup and agree with Zarticus. There's no need to run the Rostra wiring all of the way to the back of the bike. Tap into the front brake wire. It's much easier and closer.
Jim
2015 Concours 14
« Reply #5 on: March 10, 2016, 12:28:37 am »
Thank you all for replying.  ;D
I was going to tap this wire originally, but couldn't find anybody that had posted-up a pic, or which wire (color) that was correct up front??
Naturally - I went to great lengths to splice and RUN a wire all the way to the back of the bike already, but hadn't tapped it yet.
Okay -- I am CONVINCED!!!
Now can one of you kind kIND people tell me which wire to TAP!?!  ;-)
thanks,
Offline luv2fly
« Reply #6 on: August 21, 2018, 11:23:43 pm »
Thread resurrection.  In the midst of putting the Admore kit in my E55.  So far, not thoroughly impressed with the kit.  The only meaningful instructions are the wire chart showing which wires do what from the bike.  Support has been great, ended up using glue to hold the LEDs in place per their suggestion to get the lenses in place and the LEDs staying put.  Looks like a quality kit, but wish for more instructions.  trunk is done, tearing into the tail to find tailight wires now.
Loud pipes save lives but helmet laws suck - Its a safety issue
« Reply #7 on: August 23, 2018, 01:47:37 am »
Holy resurrection!! :-\
