Author Topic: GoPro mounting with Ram Ball in a unique location  (Read 531 times)
Offline Howiehere
« on: January 02, 2019, 12:34:17 am »
After much thought I decided to mount my Ram Ball on the left fairing cover. It’s positioned perfectly for my camera to peer out between the mirror and windscreen, and the second ball will hold my phone/GPS.
Because of the slight curvature of the cover, I needed to fill the gap between it and the mount base. I chose a 1/8” thick foam rubber harvested from a flag from Hobby Lobby for $1.29, should be able to handle moisture just fine and was easy to cut. I cut the circle just a bit smaller than the diameter of the mount base, thought it would look better that way. I also put a little Loctite on each of the nuts to counter any vibrations.
The one downside to placing it here: restricted access to that bolt in the cover (you can just see it in the pic beyond the second ball, as well as the close-up side shot). I had to use the short end of a hex wrench instead of my powered screwdriver, took a few minutes to do a half turn each time. But, it’s right where I wanted my GoPro and GPS to be, so the positives outweigh the negative.
2009 C14 ABS Candy Diamond Red
“I too am not a bit tamed—I too am untranslatable; I sound my barbaric YAWP over the roofs of the world.” - Whitman
Offline robertv
  • Go Hawks!
Re: GoPro mounting with Ram Ball in a unique location
« Reply #1 on: January 02, 2019, 04:27:06 pm »
Definitely unique and interesting! Will it have a clear view if hand deflectors are installed there? I know some folks used the Ram mounts for hand deflectors instead in that same area. I have the GoPro mount installed on the right brake reservoir mount and you're right, the view was obstructed by the windshield depending how much I raised it. I'm now testing the mount on my helmet and you can see the old location near my right hand.
https://farm5.staticflickr.com/4826/31632262067_fafcea2d08_b.jpg
2008 C14, silver [current]
2000 C10, red [sold]
