Author Topic: GPS Mounting  (Read 6868 times)
Offline gpd323
Re: GPS Mounting
« Reply #25 on: January 17, 2016, 07:52:06 pm »
I have 2 AST Ram ball mounts that replace a clutch/brake master cylinder bolt. Then I use a short 3" Ram ball extension to both the GPS and radar detector. Both clear the windscreen full lock to lock on the stock screen. I currently have the CB Euro short version and plenty of room lock to lock.
View from the seat
close up of the Ram setup on the GPS from the side
Offline szunker
Re: GPS Mounting
« Reply #26 on: January 17, 2016, 11:35:29 pm »
After reading all the helpful posts and sitting on the bike yesterday visualizing both mounting possibilities up top at handlebar and low between them I decided that down low would be more practicable so I ordered the Ball I need to screw in the heilbar threaded boss  via Amazon  RAM-B-236U i know other parts still needed but not in a hurry, too cold to ride now.
2012 Concours 14 ABS Black
Offline antibus
  • COG#: 11339
Re: GPS Mounting
« Reply #27 on: January 18, 2016, 01:12:19 am »
I use MC Enterprise brake and clutch reservoir Ram Mounts. It places stuff where I can see it just below my speedometer and not in my way.
CDA #0542
Offline Andrew
  • 92.5% chance of a Piano falling on you
Re: GPS Mounting
« Reply #28 on: January 18, 2016, 06:46:52 am »
MC Larry stem bolt with a Ram ball. It puts the GPS dead-center between the handlebars. I have to reach around the GPS a bit to get to the key, but it's not awful. Be aware that if you go this route you need a major-league 12mm allen driver, and a 26mm socket to put the bolt back on. But once it's done it's a nice clean installation.
« Last Edit: January 18, 2016, 06:56:04 am by Waldron »
This is not a novel to be tossed aside lightly. It should be thrown with great force.
- Dorothy Parker
Offline szunker
Re: GPS Mounting
« Reply #29 on: February 13, 2016, 10:25:13 pm »
This is what I came up with for mounting hand held GPS ( no need to buy a new one)  Parts used : RAM-B-236 U, RAM-HOL-GA41U, RAM- 238U & Ram-B-201U ( Maybe change to the shorter arm?)  and here are some pics.
Offline JPavlis_CA
  • San Jose CA
  • COG#: 2293
Re: GPS Mounting
« Reply #30 on: February 13, 2016, 10:51:34 pm »
After driving at 70 mph into the grass median between the north and south lanes on I-5 while looking at the GPS mounted low between the bars, I decided to get it up higher, more in my line of sight.
I use a RAM-B-231-1U 1" Ball base that fits over the brake master cylinder clamp. A couple of longer bolts from the hardware store and it mounts right up in less than a minute. It's great for the GPS because there's less sun glare, but I also use it occasionally for a GoPro.
http://www.rammount.com/part/RAM-B-231-1U
« Last Edit: February 13, 2016, 11:08:49 pm by JPavlis_CA »
Offline JTX
  • TEXAS 2015 ZG14
    • 2015
Re: GPS Mounting
« Reply #31 on: February 13, 2016, 11:24:26 pm »
And the good part is murph said black bar risers will be available soon for us 2015 C14 owners. ;D
Offline Sailor_chic
Re: GPS Mounting
« Reply #32 on: February 14, 2016, 01:38:54 am »
Powder coating is also an option.
Nicole     Port St Lucie, FL.
2013 C14 Black
2006 Vmax
IBA # 60267
Offline JTX
  • TEXAS 2015 ZG14
    • 2015
Re: GPS Mounting
« Reply #33 on: February 16, 2016, 11:48:47 am »
Yep.  And Murph is gonna do it so I Wont have to mess with it  ;D
Online gsun
  • CDA #560
  • COG#: 9127
Re: GPS Mounting
« Reply #34 on: February 17, 2016, 02:50:37 am »
I just mounted mine on a stick mount (can't remember what they actually call it) that goes on the inside of the bars. I know the OP has Helis but thought I would show it anyway. In the pics, the view of the gauges is not blocked and it is up high to see easier. I also have four inch risers so it's really in my face. The ram ball mount in the center is for a cell phone. I ordered an X grip and it's not here yet. I had a Garmin there but it was too low. One picture is with the GPS off the mount.
