Author Topic: Grip replacement help  (Read 3133 times)
Offline Yellow Jacket
« on: May 21, 2015, 02:44:05 pm »
Hello riders!
I ordered a pair of gel grips (Kawi green even) THEN I noticed today the wire coming from my stock throttle grip.
Is this the grip heater wire?  Obviously I haven't (yet) had experience with heated grips.  What's under there?
Looking for advice from those of you who have replaced their grips with aftermarkets if it's even possible.
1990 Yamaha YX600 Radian, 1999 Kawasaki ZG1000 Concours, 2002 Honda VT750 Shadow Spirit, 2002 H-D FXDL Low Rider, 2005 H-D FLTRI Road Glide, 2012 Kawasaki ZG1400 Concours
Offline SilverConnieRider
  • COG#: 11953
Re: Grip replacement help
« Reply #1 on: May 21, 2015, 02:53:37 pm »
Yes that is the wire for the heated grips.  What's under there - there is a cover that can be removed with one screw.
It's there (the cover) to help protect the wire because on the throttle side it twists.
Most people including myself just add covers over the grips instead of replacing the whole grip.
I believe that wire goes down quite a ways and connects down under.  ;D
So I don't think you can just disconnect it at the grip - but I could be wrong.
If you haven't got your order or you haven't opened the package I would look it over real good before I decided to replace the stock ones.
Then again if you are NOT interested in heated grips - go for it.  >:D
Otherwise I would look for heated grip replacements.
« Reply #2 on: May 22, 2015, 01:27:17 pm »
Thank you SilverConnieRider.
In my mind the grip heaters were in the bar, not the grips.
Definitely going to keep the heated grips.  Although I haven't used them yet, a January ride on my old C10 from OK to LA taught me I need them.
« Reply #3 on: May 23, 2015, 11:47:31 am »
grip buddies!!!
My Horns have Horns.
Offline mehush
  • COG#: 11038
« Reply #4 on: May 23, 2015, 06:36:36 pm »
Offline Alan
  • COG#: 11662
« Reply #5 on: May 24, 2015, 01:37:09 am »
If I am not mistaken the heating element is molded inside the grip itself.
+1 on Grab On
http://www.amazon.com/Grab-On-Grips-Grip-Cover/dp/B00230P2E4
Don't Panic!
AMA Charter Life 34 years
GWRRA Member 3 years
LIMNCS #147
'77 BMW R100/7 Manfred
'79 Yamaha MX175
'00 Yamaha YZ250
'01 Yamaha TTR125
'04 Yamaha YZ250F
'08 Suzuki DR650SE Mootzimo
'09 Honda GL1800Navi/XM HAFACAR
'12 Kawasaki ZG1400 Concours
Highly recommend http://letsrideclyde.com/
  • COG#: 11953
« Reply #6 on: May 24, 2015, 12:59:47 pm »
I tried the grips in the link above and they were too tight.
I reordered theses http://www.amazon.com/Grab-On-Grips-Grip-Cover/dp/B00230H508/ref=pd_sim_263_4?ie=UTF8&refRID=0NGSB7X6NDKH7KKK0AZ5
Just trying to help you NOT make the same mistake I did.   :-[
Offline sininja
« Reply #7 on: May 24, 2015, 05:39:18 pm »
I just ordered the ones in your link silverconnierider hope your right ;)   I've been looking for covers for a while can't wait to try them
Offline Jon
« Reply #8 on: May 27, 2015, 12:58:33 am »
I just measured my stock grips (heated) at 1.3"
When you say too tight?  Explain....
  • COG#: 11953
« Reply #9 on: May 27, 2015, 01:34:18 am »
I guess it depends on how accurate your measurement was but the pair in the link above mine are 1.25 -1.45.
I tried and got them on about half way and just couldn't get them any farther.
The 1.45 -1.65 were snug but I got them on all the way and they fit great.
There wasn't much price difference between the sets.
I was just telling what worked for me.  If you want to order the smaller set - go for it.
I have 2 bikes and they both required the larger set.  Your results may vary.  ;D
Offline Bruiser
  • Bruiser
« Reply #10 on: May 29, 2015, 03:23:35 am »
 I have had the GrabOns on several bikes, and love them. And you cant beat the price
Bruiser
2012 Kawasaki C14
93 Kawasaki C10
1982 Honda CX500 Turbo
1980 Kawasaki KZ1000ST
1978 Honda CB750F
1976 Kawasaki KZ400
1976 Honda 750K
1973 Honda CB500K
1973 Honda SL175
1972 Honda SL125
Offline Jon
« Reply #11 on: May 30, 2015, 12:55:06 am »
I ordered up the smaller set and installed tonight no problem.   Of course using a little compressed air under it makes it super easy to install or remove.   :great:
Offline sininja
« Reply #12 on: June 01, 2015, 08:52:59 pm »
Got my set today.  I ordered the 1.5 - 1.65"OD recommended on this thread and they are loose with no amount of hairspray going to take up the gaps.  I should have got the originally recommended size of 1.25-1.5.  I can definitely see where these things are gonna help though, just sucks I gotta order another set in the correct size!  EDIT: I should clarify it's completely my own fault I knew I should have measured.  Just a reminder that there are tolerances and everyone should check first!  My grips might be worn down already.  No disrespect intended to anyone, for the price these things are amazing!
« Last Edit: June 01, 2015, 10:53:45 pm by sininja »
Offline Jon
« Reply #13 on: June 02, 2015, 12:32:52 am »
when you install, they are tight...but if you use your air compressor to "inflate" the grip while you are sliding it on it goes on super easy.    Just keep the tip of the nozzle under the edge as you slide it on and presto.    I also cut almost an inch off the length of the grip cover so it does not foul my throttle.
My grips were 1.3" and are almost new (2600 miles).   I knew the larger ones were never work and be loose.   Bummer you took the bad advice.    :-[
Offline Alan
  • COG#: 11662
« Reply #14 on: June 02, 2015, 01:00:47 am »
Buy the 1.25 to 1.5 set wipe the grip with rubbing alcohol  and the inside of the grab on, push and twist they will slide on. Wipe more alcohol on the grip if needed. Once in place and the alcohol evaporates the grab on will not move no matter how hard you twist it.
PS I also took off the bar end weights to get them out of the way.
« Last Edit: June 02, 2015, 01:05:43 am by AlanS »
Don't Panic!
LIMNCS #147
'79 Yamaha MX175
'00 Yamaha YZ250
'01 Yamaha TTR125
'04 Yamaha YZ250F
« Reply #15 on: June 02, 2015, 01:41:45 pm »
Installed Grab Ons and don't like them.  The fit is fine, but I tore a bit of the foam on installation. So now I get to feel it every time I ride.  I'll probably try then Grip Buddies next, wish they had different colors.
Offline Jon
« Reply #16 on: June 07, 2015, 04:19:08 pm »
won't tear them if you install using the compressed air trick.    Literally a 1 minute job for both if that. :great:   AND won't tear them at all.
