Author Topic: I'm sure these have been reviewed before but  (Read 969 times)
Offline Lentz
  • COG#: 12724
« on: April 03, 2018, 12:46:31 am »
I bought a Murph's shifter kit while I was waiting on my bike to come in. Bike shifts great without it and it's a 5 minute job to grease it every Summer. The bearings would have to be loctited in. I thought it was a waste of $20 considering how the bike shifts.
Put on a McCruise. It took a while because I'm particular with wire routing but I thought the instructions were excellent and the product is great.
I used Murph's handlebar rises and they help quite a bit but aren't quite enough. He sells a gadget that angles them back toward the rider. I thought the risers were worth the money.
I mounted a GPS and radar detector using a PDM 60. It's small and will be easier to find a place to mount than a Denali Power hub. I used a Chinese lithium battery that has plastic risers to space the battery up to stock height. I put a thin aluminum plate between the risers and mounted the PDM 60 there. I was happy with the way it turned out and the wiring was shorter.
I used the Kawasaki accessory GPS mount and was happy with it. I mounted the radar detector off a ram mount going into the brake lever clamp.
That's it so far. Header, Ivan reflash and Russell seat after riding season. I think I will go with the Russell sport because it doesn't raise you up any and I don't want to hunch over to the bars.
  • COG#: 13095
Re: I'm sure these have been reviewed before but
« Reply #1 on: April 04, 2018, 02:34:55 pm »
Why?? What header?
Offline Lentz
  • COG#: 12724
« Reply #2 on: April 04, 2018, 09:30:13 pm »
Ivan has an Area P header and is doing a dyno test on it and developing a flash for that header. I'll either go with that or his reflash for the Arkrapovic slip on.
