Author Topic: Installation instructions for Projekt D Extreme Frame Sliders  (Read 669 times)
Offline jhancelot
« on: August 17, 2018, 02:33:27 pm »
Hi everyone
I have a set of (lightly used) frame sliders that I bought online. Anyway, they didn't come with instructions. Does anyone have the PDF instructions to install the Projekt D Extreme Sliders for a 2015 Concours? thanks, J.
Offline Guest
Re: Installation instructions for Projekt D Extreme Frame Sliders
« Reply #1 on: August 17, 2018, 03:06:53 pm »
Isn't it just two bolts?  Shouldn't really require any special instructions.  Factory Service Manual will have torque specs.
Installation is easy and fast.
* original bolts will be loosened and then removed.
* install the frame slider using the bolts which are provided in the set.
IMPORTANT : Only remove the front engine mounting bolt one side at a time. This item needs to be installed by professionals and correct tightening torque has to be respected.
Offline jhancelot
« Reply #2 on: August 17, 2018, 03:23:25 pm »
Well there must be some sort of instructions. I see on the forum there's 2 ways to install... one involves removing all the plastic and the other doesn't. As well, I read something about a "breaker bar" to initially remove the engine mount. As far as the Connie factory manual goes, I don't have one, so if anyone knows the torque specs for these two mounting points it would be appreciated. thanks!
Offline jhancelot
« Reply #3 on: September 10, 2018, 01:22:51 pm »
Further to my inquiry, I purchased a used set of Projekt D sliders from Kijiji (yes, I know, "buyer beware"). They seem like they are in new condition... but the only parts that came with it are pictured in the attached photo. Its basically the rubber slider and the rods. I obtained an installation manual from Projekt D (see attached) and it looks like there's quite a few more parts involved. Perhaps the parts in this manual area already on the bike under all that plastic? Has anyone installed these sliders before or recognize these other parts as OEM parts? thanks, J.
