Author Topic: Installation of TechSpec Tank Protectors  (Read 10329 times)
Offline thundermax
  • COG#: 11055
« on: February 13, 2013, 02:52:53 pm »
Just received the tank protectors for my 2009. The only instruction was to apply in 80 degrees or higher temperature day.
Just asking for comments that have applied the protectors to their bike, do's and don'ts.
Looks like I will have to wait until May-June to apply?
Riding since 1966 at 13. Just purchased my tenth bike in my life. Now have two at same time. 2009 C14 and 2012 C14. Here are bike I have owned: 1958 Cushman model 721 Highlander, 1960 Cushman Super Eagle, 1971 Honda SL 100, 1974 Yamaha RD350, 1975 Honda 750 Four, 1971 Honda SL 175, 1998 Vmax, 2005 Vmax, 2009 C14, 2012 C14. COG#11056, South Central Area, Oklahoma.
Offline Robert
Re: Installation of TechSpec Tank Protectors
« Reply #1 on: February 13, 2013, 03:07:26 pm »
It was cold out when I installed mine. I just left my bike out in the sun to get warmed up a bit. Also laid out the tank protectors out on the driveway for a while to get warmed up by the sun a bit as well.
Offline devilboy
  • COG#: 10552
  • Membership Level: Terminated / Expired
« Reply #2 on: February 13, 2013, 03:24:55 pm »
You can also use a hair dryer or real heat gun (WARM AIR) to heat up tank. and it couldnt hurt to clean areas to be applied with Preps-all and allow to fully dry...
Offline Connie4Jim
  • COG#: 10627
« Reply #3 on: February 13, 2013, 03:27:25 pm »
I just installed mine on my 2010 a few days ago.  I used a hairdryer to heat up the area and it worked great.  BE CAREFUL - the adhesive on the back of the rubber grip can get peeled off pretty easily so when you start to peel the white covering off, be sure you're leaving the adhesive on the rubber.  Also, be sure that you start in the corner and press firmly as you peel the white covering off.  Sort of roll the rubber on as you pull the white covering away.
Good luck.  They look and feel great.
2010 Concours 1400
2003 Suzuki SV650 naked
2009 KLX250
CDA # 0443
"Like your own personal roller coaster..."
Offline ZG
  • COG#: 9735
« Reply #4 on: February 13, 2013, 03:46:07 pm »
 :iagree:
Offline Poorboy
  • COG#: 10571
« Reply #5 on: February 13, 2013, 03:47:32 pm »
+1  This is what I did too.  Or, I guess you could wait for May-June.  LOL
2012 Concours.... "Connie the Tramp"
CDA#0430
She will lay down with the least amount provocation and doesn't care where she's at. LOL
Offline Squid
  • COG#: 10582
« Reply #6 on: February 13, 2013, 05:29:43 pm »
Applied mine Monday night. Using a hair dryer is the way to go.
Offline thundermax
  • COG#: 11055
« Reply #7 on: February 13, 2013, 05:42:40 pm »
Guess I will wait for a 70 degree day, might have one in a few weeks. Live in central Oklahoma.
One other thing. My crotch area protector does not look like the one in the picture on their website. Does anybody else have a 2008-2009 that looks a little different too?
Offline Conrad
« Reply #8 on: February 13, 2013, 06:02:21 pm »
Here's what mine looks like.
2008 C-14 ABS
Northern Illinois
Offline Deepsea
« Reply #9 on: February 13, 2013, 06:12:10 pm »
I put the same set on my 09 and yes the center is different but IMHO looks better. Hair dryer works great for tank and protector just don't over heat the rubber,warm is better than hot.
Retired Navy Saturation Diver
Offline thundermax
  • COG#: 11055
« Reply #10 on: February 14, 2013, 12:16:32 am »
Would you mind posting pics of left, right, and top. Like to see your placement. Thanks.
Offline Conrad
« Reply #11 on: February 14, 2013, 02:49:56 pm »
Here you go.
Dang that's a good lookin bike!
2008 C-14 ABS
Northern Illinois
Offline thundermax
  • COG#: 11055
« Reply #12 on: February 14, 2013, 03:12:19 pm »
Nice, really like it. Really adds to the looks. Can't wait to get mine on. Thanks for posting.
Offline thundermax
  • COG#: 11055
« Reply #13 on: February 14, 2013, 10:41:56 pm »
Here is a pic of my tank protectors. The center piece is different than the pictures posted earlier. Trying to find the perfect spot for the center. Seems it is a little at odds with the tank as far as laying down flat. Hoping someone will post picture of protector like mine and where they placed it.
Offline noodle
« Reply #14 on: February 14, 2013, 11:00:22 pm »
I had the same issue with the center piece not conforming to the tank as well. It could be rubbed down but would lift back up. I don't think the thickness of the material can take that tight of a bend. I contacted Tech Spec and they were happy to send me a new piece, but I'm thinking of cutting it to ease the bend.
Offline TJ
« Reply #15 on: February 14, 2013, 11:21:10 pm »
That center looks identical to the BMW RT center, not at all like what we have.  I would verify with Tech Spec
Offline Mark D
« Reply #16 on: February 15, 2013, 12:13:06 am »
Thundermax I just received mine a couple of weeks ago for my 09 and mine is exactly as yours is WRT to the crotch area. Will put them on once the weather warms up which will be a while by the looks of things  :'(
Offline thundermax
  • COG#: 11055
« Reply #17 on: February 15, 2013, 12:25:12 am »
If I spend $90 on this, I would like it to fit perfect. Little bit disappointed. May cantact them.
Offline notsluggo
  • COG#: 10187
« Reply #18 on: February 15, 2013, 01:31:18 am »
That's the kit I put on my '11 and it fits perfectly.
Ride safe(r).
- notsluggo
2011 Concours 14 - The Silver Bullet!
2014 KLR650 - Kelly
Parker, CO
Offline Mark D
« Reply #19 on: February 15, 2013, 02:41:58 am »
What's the success rate in removing and reapplying at a later date. I guess one has to be careful not to remove the sticky backing on the rubber. Sounds easy enough but I've heard of the odd issue now and again. I paid $70 on an ebay auction. Are they up to $90 now???
Offline ZG
  • COG#: 9735
« Reply #20 on: February 15, 2013, 02:51:18 am »
That's the center piece I have too, and I like it much better than the smaller one Conrad shows, the larger one provides more coverage/protection IMO.  :great:
Offline ZG
  • COG#: 9735
« Reply #21 on: February 15, 2013, 02:54:04 am »
I had no problem peeling mine off and re-applying almost a year later. I had a Targa tank bra on the tank but the TS on the sides, I later added the center piece from TS and had to adjust the side pieces to line up with it, no problem at all. The key is to drink a couple beers prior and make sure they are warm (the TS, not the beer...  ;D).
:great: :beerchug:
Offline Conrad
« Reply #22 on: February 15, 2013, 10:34:10 am »
Hmmm, I kinda like the larger protector for the back of the tank too. It looks like the top of that protector would line up with the side pads nicer. I may see about getting the larger one, just for looks cuz the smaller one that I have does the job just fine. The only issue that I have with the center pad is that I have a hiviz jacket and where my jacket rubs on the pad it's leaving a small dark patch on my jacket.
Here's a silly question.
Hey J, you gotta pic of that center pad on your bike?    :))
« Last Edit: February 15, 2013, 10:37:30 am by Conrad »
2008 C-14 ABS
Northern Illinois
Offline Brass
« Reply #23 on: February 15, 2013, 11:04:10 am »
I had no problem getting the peice to stick down.  I don't have a pic available right now but i placed it about an inch above where the seat and tank meet
Edit
Here is the only pic i have right now
« Last Edit: February 15, 2013, 11:09:32 am by Brass »
Shaun - Collegeville PA
2017 Yamaha FZ-07
Offline Larry
  • COG#: 9359
« Reply #24 on: February 15, 2013, 01:30:10 pm »
Nice.....
10 Kawi Concours 14 ABS
