Author Topic: Installation of TechSpec Tank Protectors  (Read 10182 times)
Offline ZG
  • COG#: 9735
Re: Installation of TechSpec Tank Protectors
« Reply #25 on: February 15, 2013, 03:05:19 pm »
Here is a pic of my tank protectors. The center piece is different than the pictures posted earlier. Trying to find the perfect spot for the center. Seems it is a little at odds with the tank as far as laying down flat. Hoping someone will post picture of protector like mine and where they placed it.
That's the center piece I have too, and I like it much better than the smaller one Conrad shows, the larger one provides more coverage/protection IMO.  :great:
Hmmm, I kinda like the larger protector for the back of the tank too. It looks like the top of that protector would line up with the side pads nicer. I may see about getting the larger one, just for looks cuz the smaller one that I have does the job just fine. The only issue that I have with the center pad is that I have a hiviz jacket and where my jacket rubs on the pad it's leaving a small dark patch on my jacket.
Here's a silly question.
Hey J, you gotta pic of that center pad on your bike?    :))
 :truce:
hahaha... Ironically I don't have any pics of it C, I did check though, but I can take one if you need. Yes you can buy just that larger center pad from TS, that's what I did.
Offline fartymarty
  • COG#: 9712
« Reply #26 on: February 15, 2013, 04:14:45 pm »
I had the same issue with the center piece not conforming to the tank as well. It could be rubbed down but would lift back up. I don't think the thickness of the material can take that tight of a bend. I contacted Tech Spec and they were happy to send me a new piece, but I'm thinking of cutting it to ease the bend.
I had the same problem with the center piece (the wider one) a little pucker up at the bottom center. I kept pushing it down with my thumb and eventually it gave in.
 It took a few months before it surrendered to my will. Looks good now. I love it when my determination to procrastinate becomes patience.  :)
Offline Deepsea
« Reply #27 on: February 15, 2013, 04:30:46 pm »
Here are the pics of how they look on my 09. I used a hair dryer to warm both the tank and the rubber pads. It made them much easier to apply. I didn't get them hot, just warm.
Retired Navy Saturation Diver
Offline Conrad
« Reply #28 on: February 15, 2013, 05:05:17 pm »
Nice! Thanks Deepsea.
2008 C-14 ABS
Northern Illinois
Offline thundermax
  • COG#: 11055
« Reply #29 on: February 15, 2013, 09:33:16 pm »
Have to admit I do like the bigger center protector, the way it looks as compared to the thinner one. Contacted the retailer today, told them about this, they indicated the incorrect one was sent, were sending the correct one, guessing the smaller center one. The one I have now says 2007-2009 on it. When it arrives will have to make a decision on which one to put on.
For the price I feel the manufacturer should have done a better job molding the fit in the center rather than just cutting the rubber flat. IMHO.
Riding since 1966 at 13. Just purchased my tenth bike in my life. Now have two at same time. 2009 C14 and 2012 C14. Here are bike I have owned: 1958 Cushman model 721 Highlander, 1960 Cushman Super Eagle, 1971 Honda SL 100, 1974 Yamaha RD350, 1975 Honda 750 Four, 1971 Honda SL 175, 1998 Vmax, 2005 Vmax, 2009 C14, 2012 C14. COG#11056, South Central Area, Oklahoma.
Offline devilboy
  • COG#: 10552
  • Membership Level: Terminated / Expired
« Reply #30 on: February 15, 2013, 10:16:38 pm »
I received the same one (wider and shorter) and applied it roughly even with the tops of  upper left and rights.
I would send a picture but they are off right now for a little paint touch up... I am repainting a portion of tank where I dropped handle bar on it when I was putting in risers.... I painted it once and screwed it up so I will give it one more shot before I  bring in a real painter...  The Arabian Red on the 12 is beautiful  BUT  it is a multi level paint process.
Base coat, Main coat  and then Clear coat.. I did it the first time  medicated on pain killers, I thought it looked great until I saw it  the next day :rotflmao:  By the time I finish this I should have just had it painted by a pro.
Offline Brass
« Reply #31 on: February 16, 2013, 02:05:26 pm »
Why it lays flat on the tank when applied and stay in place
Shaun - Collegeville PA
2017 Yamaha FZ-07
Offline Larry
  • COG#: 9359
« Reply #32 on: February 16, 2013, 04:05:17 pm »
[/quote]
+1 Agree, mine have been on the bike for 2 years, look great and haven't moved at all.
10 Kawi Concours 14 ABS
Offline Shredran
« Reply #33 on: May 04, 2018, 12:59:00 am »
Is it OK to ride the bike immediately after applying these?
Offline Conrad
« Reply #34 on: May 04, 2018, 09:28:54 am »
Yep, they stick tight right away.
2008 C-14 ABS
Northern Illinois
Offline Shredran
« Reply #35 on: May 04, 2018, 11:31:00 pm »
Just finished mine, they look great
