Author Topic: does anyone have instructions for Kawasaki top box  (Read 1437 times)
« on: November 23, 2017, 11:26:57 pm »
I bought a nice red 09 top box off of ebay. Nice box for about half of a new one. Mounting parts were in a box with the top box. Problem is there are no instructions. I downloaded instruction's for a Givi mono mount but there is on paragraph in English with everything else in languages I can't read. Looking at the instructions I have though it says to mount the bikes rear plate and remount it upside down. The pictures doesn't reflect this.
Does any one have a set of instructions for the Kawasaki top box along with required parts?
A search did nothing for me. Could be someone else might have better luck. Thanks, Tim
« Last Edit: November 24, 2017, 02:35:58 am by TimR »
Re: does anyone have instructions for Kawasaki top box
« Reply #1 on: November 24, 2017, 02:08:15 pm »
Don't have instructions.
But I originally mounted mine on the stock plate and used the universal adapter.
No reason to turn the plate over.
I later moved to Phil's rack on mine and I'm glad I did!!!!
« Last Edit: November 26, 2017, 11:12:41 pm by connie_rider »
Offline gsun
  • CDA #560
  • COG#: 9127
« Reply #2 on: November 25, 2017, 02:51:24 am »
This is my setup. The first is the complete mount. The next is from underneath. The last is with the cover off to see the bolts. I don't have instructions as far as I know either. I will look.
« Reply #3 on: November 25, 2017, 04:26:36 pm »
Thanks for the pics Gregg. My instructions show a couple of external brackets that I don't remember seeing on other bikes but I wasn't looking for them either. I could bolt everything together but I want it to be as stable as a couple pieces of plastic can be. Tim
Offline olie
« Reply #4 on: November 25, 2017, 04:50:13 pm »
...these are the new instructions from Kawasaki for the new bracket...
https://www.kawasaki.com/Accessories/Item/ZG1400EGFL/999940620
2013 C14, blue
2016 V1K, green
Offline philipintexas
    • Phils Farkels
  • COG#: 10175
« Reply #5 on: November 25, 2017, 11:15:19 pm »
ITMR: sounds like the instructions you have are for the Givi SR-410, it has support braces that can be a pain to attach. The KQR base plate is completely different.
« Reply #6 on: December 01, 2017, 03:29:04 am »
Wouldn't you know it. I went to remove the rear mount and stopped before I completely stripped the bolts. I will get some new ones on order before getting nasty with them. Tim
Offline roy826
« Reply #7 on: December 01, 2017, 02:04:00 pm »
Stock bolts are really soft and round out easily. Just as bad if not worse than the bolts used on the front calipers which are junk.
