Author Topic: Kawasaki Top Case  (Read 18841 times)
Offline Larry
  • COG#: 9359
Re: Kawasaki Top Case
« Reply #50 on: November 11, 2016, 01:10:25 pm »
I have the Givi E55NT with Admore Lighting kit, on Phil's rack.  Awesome.
10 Kawi Concours 14 ABS
Offline N/a
« Reply #51 on: November 11, 2016, 04:59:37 pm »
You got a back pic?
Offline Larry
  • COG#: 9359
« Reply #52 on: November 11, 2016, 06:45:50 pm »
Yes, here it is.  I also have a video of the admore lighting kit as well.  Just give me a little time to find the video.
« Last Edit: November 11, 2016, 06:52:55 pm by Larry »
Offline Larry
  • COG#: 9359
« Reply #53 on: November 11, 2016, 06:56:07 pm »
Here is the video of the Admore light kit installed.
https://1drv.ms/v/s!Ah8toFn97XNlz2Zxioms6CrXB5PX
« Last Edit: November 11, 2016, 07:05:49 pm by Larry »
Offline N/a
« Reply #54 on: November 11, 2016, 07:46:02 pm »
That is nice looking what base plate did you get for the case?
Offline Larry
  • COG#: 9359
« Reply #55 on: November 11, 2016, 08:28:16 pm »
Phils Rack....
Offline N/a
« Reply #56 on: November 11, 2016, 10:10:08 pm »
So is his rack a direct connect to it? do we not need to get the extra plate they say you need?
Offline Larry
  • COG#: 9359
« Reply #57 on: November 11, 2016, 10:58:13 pm »
I removed the stock rack and purchased Phils metal aluminum rack which is a direct bolt on replacement.
« Reply #58 on: November 11, 2016, 11:47:33 pm »
The stock rack is a bit flexy.
Many replace it with the Phil's Rack (or other) to decrease the Rack flexibility.
The replacement racks are also a bit lower than the stock rack.
There are many replacement racks available. I think Phil's Rack is the most common.
Some type of adapter is mandatory.
The extra plate they say you need is the Universal Adapter.
It mounts between the rack and the Trunk to mount the trunk.
All adapters make it possible to remove the trunk easily.
The Universal Adapter works, but is a bit flexy and adds a little height.
The SW-Motech Adapter is an improvement as it decreases that height and flexibility.
Not sure of any other options for an adapter.
Some have avoided the adapter by bolting the trunk, directly to the rack.
But the trunk can not be removed easily.
NOTE: The Universal Adapter is not needed if you buy the SW-Motech Adapter or bolt directly..
Hope that helps?
« Last Edit: November 11, 2016, 11:57:44 pm by connie_rider »
Offline Larry
  • COG#: 9359
« Reply #59 on: November 11, 2016, 11:50:55 pm »
What Ted said.
Offline N/a
« Reply #60 on: November 12, 2016, 01:15:42 am »
Hope that helps?
Thank you I was a little lost.  :beerchug:
