Author Topic: Auxiliary lights DX & D4, SoundBomb, Fuse Block/  (Read 3012 times)
Offline Rony6ble
  • COG#: 12513
« on: November 06, 2016, 07:22:03 am »
Today I need some good advise to add some auxiliary lighting and other electronics to my bike. 40+% of the time is riding at night and not really interstate.
I have Denali's DX (dual intensity 1.5 amps per pair), D4 (3amp per pair) and a SoundBomb (20 amps) (total of 24.5 Amps) that I want to install. I also would like to add 1 gps and probably a phone and/or a tablet (say 2-3 amps each = 2-3x3=6-9 amps).
I could wire the SoundBomb independently since it is the one that draws the most amps and leave all other farkles go through the block.
One option is to run the lights using the stock low/high beam switch: in low beam DX 40% D4 off; in high beam DX 100% D4 on. They come with a switch that can cancel the lights completely. This will make operation easier.
A good friend tells me that he would rather use a complete independent on-off-on switch and don't touch the motorcycle wiring.
3 options: (1) Fuzeblock FZ1 $89.99 (30 amps, max 10 amps circuit), (2) DENALI PowerHub2 Fuse Block $129.99 (30 amps, max 15 amps circuit) and (3) PDM60 Power Distribution Module $199.99 (60 amps, max 20 amps circuit). Big difference in cost between the first and last.
Question #1: Low/High beam option (easy operation) or use separate switch (don't mess with bike's wiring)?
Question #2: Fuzeblock FZ1, DENALI PowerHub2 Fuse Block or PDM60 Power Distribution Module?
Thanks...
Concours 14 2011
Concours 14 2009 RIP
GPZ 400 & Ninja 250
IBA# 57875 COG# 12513
Offline Sailor_chic
  • COG#: 11610
Re: Auxiliary lights DX & D4, SoundBomb, Fuse Block/
« Reply #1 on: November 08, 2016, 10:41:56 am »
I have a Fuzeblock and it works great.
Nicole     Port St Lucie, FL.
2013 C14 Black
2006 Vmax
IBA # 60267
Offline mattchewn
« Reply #2 on: November 08, 2016, 11:40:37 am »
Rony6ble,
I have used the D4 lights on my KLR. I use the PDM 60 on my C14 to run the GPS, CC, Denali D2 lights, Auxiliary power let outlet, and heated gear circuits, AND a Stebel air horn, (18 amps).  A nice thing about the PDM is you can program the cutoff amperage for each circuit individually. I dropped the GPS down to 2 amps and bumped the air horn circuit up to 20. Simple. No fuses to worry about and operation is seamless. Circuits can be switched or unstitched easily. It is more money up front but I have been very pleased with mine for 3 years now.  If you only use the D4 lights you will probably never need anything more than that, they are incredibly bright and have a fantastic spread out in front of you. Aimed properly you won't be blinding other traffic either. Using the small lights on a low setting seems to be a waste to me as they are not all that bright on low. I run my D2's on the high setting all the time. Since I have Cyclops LED headlamp bulbs I rarely use my high beams, no need to.
2018 H2 SXSE.  (FAT SXSE)
2011 GSX1250 FA
2009 Ninja 500R. (wifes')
2001 Bandit 650  (kids')
Offline Max
  • CDA 264
  • COG#: 8762
« Reply #3 on: November 08, 2016, 03:06:40 pm »
I have the  FZ1 fusebox on my klr. works great.  one caution, use #12 wire for the power leads and grounds. the charts will tell you you need #10 for 30 amps.  #10 wont fit in the terminals of a fusebox. since I work construction getting  a few pieces of wire for projects is literally picking it up off the floor  it didnt cost me anything but a minute of grumpiness when the 10 wouldnt fit.
Still it works well enough that theres one waiting to be installed on the concours 14 to run my yet to be wired optimius led driving lights.
that is if I ever get off these crutches and can get around to doing something useful again.
Offline JTX
  • TEXAS 2015 ZG14
    • 2015
Offline Rony6ble
  • COG#: 12513
« Reply #5 on: August 10, 2017, 08:44:21 am »
This past weekend I finally got to do some work on the bike.
PDM60
Different mounts
Dx dual intensity over the mirror
D4 under the mirror
Soundbomb: horn in stock bracket, compressor under left fairing
Zumo 395LM hard wired
Lots of wiring, it was tight. The output is amazing.
Dx at 40% with low beam, 100% with high beam. D4 on with high beam.
Need to find out a different way to share photos since Photobucket decided to charge w/o notice and I'm not following that game, any advice is welcome.
Concours 14 2011
GPZ 400 & Ninja 250
Offline JTX
  • TEXAS 2015 ZG14
    • 2015
« Reply #6 on: August 10, 2017, 10:30:34 am »
PDM60
Different mounts
D4 under the mirror
Imgur works well.
Or you can resize and upload here.
  • COG#: 12649
« Reply #7 on: August 27, 2017, 10:59:01 am »
NEED PICS!!!!  :-\
Why do I have to be a "Crotch Rocket"??
Offline COGnosticator
  • SE AAD
  • COG 4478
  • COG#: 4478
« Reply #8 on: August 28, 2017, 07:33:25 pm »
Google photo
Amazon photo
Jerry Holland  COG  4478
« Reply #9 on: August 28, 2017, 09:18:45 pm »
Download an ap called IrfanView, been using it for 10 years to reduce file size of a photo, while retaining its original format size.. made for a lot of fun, middle of the night, using an "air card" and my mini laptop (prior to my smartphone) when posting tag o rama pictures up on the ADV site..
With the invention of smartphone tech, and tap a talk.. that's old school now.. shoot picture, post, done...
Wish someone would get hip to this stuff, and make it work here... I know they are currently attempting a new and improved forum software change over.. hopefully its compatable...
 :-X
Not holding my breath tho...
Offline Deepsea
« Reply #10 on: August 28, 2017, 09:45:01 pm »
Oh come on MOB, hold your breath, we'll all watch. :rotflmao:
Retired Navy Saturation Diver
  • COG#: 12649
« Reply #11 on: August 29, 2017, 11:13:42 am »
Will that upgrade include a way to get rid of the constant PM pop-up reminder that I can't get rid of??!!  >:(
And, as far as posting pictures, all you have to do, is use Photoeditor, or a similar piece of pre-installed software on your
PC, to reduce size.  Most have preloaded parameters (160x160) that pass the forum size limit for upload.   :beerchug:
Offline Rony6ble
  • COG#: 12513
« Reply #12 on: September 30, 2017, 02:16:36 am »
Sorry the delay, with Photobucket acting stupid (exactly $399 stupid) and work trips plus a quick trip to visit Grandma in Chile for her 100 birthday and more work trips and the Tour of Honor banquet in Colorado (more on that later)...
This is a Google Photos album link that you can use to see some photos. There is one short video for the lights.
https://goo.gl/photos/6mwM1vYugxvjN6mR8
On my way back from the TOH banquet in Cripple Creek, CO and on a IBA ride called Heaven to Hell (Pikes Peak - Independence Pass - Ely, NV - Badwater, Death Valley, CA) leaving CO around noon and riding through the night in Utah and Nevada somewhere along US6/50 I was able to see an Elk at over 600-700 feet. Couldn't be happier about the lights.
Will check suggestions for posting photos.
Please let me know if the link works
Concours 14 2011
GPZ 400 & Ninja 250
Offline Bowyerv
« Reply #13 on: October 18, 2017, 08:44:58 pm »
 :)  It works.  Thanks.  Great pics!  Did you fabricate those mounts yourself?
Offline Rony6ble
  • COG#: 12513
« Reply #14 on: October 21, 2017, 05:11:10 am »
No Sr.
I used two different mounts for the lights. Under the mirror (Denali D4) I used the PCA mounts and over the mirror (Denali DX) I used the mounts from Beaudry (He preps the C14 for the Police and I got the shelf from him too and some other thing I have not mount)
PCA
http://www.pca-one.com/productDetail.asp?productID=7899
Beaudry (Let me know if you want contact info since he will make them by order)
zeropolice.com
Concours 14 2011
GPZ 400 & Ninja 250
Offline AmphibSailor
  • Hooligan
  • COG#: 12210
« Reply #15 on: October 21, 2017, 05:53:06 am »
The shelf looks like a pretty good idea.  How much was it?
Offline Rony6ble
  • COG#: 12513
« Reply #16 on: October 27, 2017, 03:39:57 am »
......................$49.95 and probably some shipping (I ordered other stuff too.
Concours 14 2011
GPZ 400 & Ninja 250
