I've been an avid PIAA Xtreme White Halogen H4 admirer for over a decade.
I'm not interested in external, add-on lighting and haven't been interested in LED's-in-halo reflector lighting, until now.
A friend has recommended that I demo the PATHFINDER 4000LM LED H4's, being that I'm a PIAA fan.
He claims that LED technology has come a long way for halogen-based reflectors since 2016.
The Pathfinder 4000LM has no external driver and no fan. It does have a cast-aluminum heat-sink.
It comes with the removable H4 base that mounts into the reflector housing and retained by the oem spring-retainer.
No modification to the rubber boot is required.
Install H4 base into the reflector followed by the rubber boot, followed by bulb, through the boot, into the base, and rotate 90deg. to lock and plug-in.
It's typical of other LED bulb installs but no external driver and, what appears to be, a modest heat-sink.
I've never heard of Pathfinder before. It's carried through WPS so it's been around for 2018, anyway.
$110 for two H4's
$145.00 mfr# kwledkt for two H4's and two T10 bulbs, all from Pathfinder. This "kit" has different H4's with external drivers.
Has anyone heard of Pathfinder?
