Author Topic: LED H4 bulb PATHFINDER  (Read 2590 times)
Offline Jorge
  • COG#: 9297
Re: LED H4 bulb PATHFINDER
« Reply #25 on: November 04, 2018, 10:38:27 am »
Ted,
If I understand what you mean by two- or three-sided, mine are two sided. The light is basically made up of a flat stick, with two LED elements on each side.
I've seen some with the little hood, or deflector plate, and some without them. I think this is one item that makes a difference between a decent or good cut-off and a bulb that will bling on-coming drivers. Mine have the hoods.
I think Evitek is gone, and there are two things that make me think this: 1- you cannot find many listed on Amazon any more. Used to be you'd do a search for Evitek, and you'd get back many listings; now, and you get one, maybe a left over. 2- The rest of the story on ours... I ordered two packs of two. Two for my C14, and one for Irene's Vulcan-S. I gave the 4th one to a friend with an old Harley. That light failed within a month - probably couldn't take the Harley's smoothness. I contacted them, and after I sent them a photo of the serial number, and of the wire beign cut, they told me they'd send me a replacement. Then they told me they were having delays, but it was coming, then again, and then nothing.
We are still happy with the three we are using, and if one fails. I will replace with other LEDs.
Offline JDSCO
  • 2016 C14
« Reply #26 on: November 04, 2018, 04:53:50 pm »
I noticed that the ones you have include a deflector plate to keep from blinding other drivers.   :great: :great:
Do you notice that in the light distribution??
Ted, is your "deflector plate" reference the nose of the LED or the "shell"
An interesting discovery, not mentioned in install instructions
The "hood"or "shell", the reflector-looking pan in a halogen bulb low-beam, is engineered to be facing up. The concave side faces up. It's fixed in position
The LED "shell" can be mounted either facing up or down because the LED has symmetric locating pins, 180deg to each other
It should be facing up, concave side faces up as with the halogen shell
I initially installed mine "up"
I just re-installed both facing down to see the difference
There appears to be a difference
I don't know if it's good or bad
I cannot confirm anything with the bike just sitting in the garage
PIAA has their H4 9003 LED
$75ea
It's H4 base is adjustable to obtain best light distribution/beam pattern by rotating the LED's in the reflector
That's actually a nice feature if there is some gain in beam pattern, I suppose
Maybe even "really cool" feature
There's a lot of data to consider
Gen James Mattis
Offline Lee
« Reply #27 on: November 04, 2018, 06:57:32 pm »
I’ve had my cheap eBay led headlights in for about 4 or more years. I have them in all 6 bikes that get parked outside and driven7 days a week sequentially.  Rain, ice. Heat, No problems.  The brightest and best lights. And they use less electricity then stock lights.
Offline JDSCO
  • 2016 C14
« Reply #28 on: November 04, 2018, 07:37:23 pm »
Yes, I get it
You said basically the same thing in your earlier post
You apparently have at least six Led bulbs
"They're the brightest and the best"
What are they H4's H7's, H3's...what are they?
Who makes them?
Are they fan-type, with external drivers...what?
How many LU's and watts?
What bikes are they in?
How much were they? $3, $9, $12? How much?
EBAY has one, 240000LU 700watt
That's 6amps for one LED bulb that cost $12
Let me know
Gen James Mattis
Offline Lee
« Reply #29 on: November 05, 2018, 08:52:29 pm »
Various brands. I just looked for the brightest ones at the time. All have fans. But if fans bother you then there one I found with metal cables coming out where the fans would be for a heat sink. I always get pure white color. It seems to reflect back the best. The ones that say motorcycle are supposed to be the best against vibration. I usually get h4. But the kit comes with various sizes of adapters. If none of the adapters fit then I trim them  to make them fit. It doesn’t seem to matter if the little transformer is separated up the cable or built into the fan. I just zip tie them to something.
Offline oldnslo_MO
  • COG#: 9924
« Reply #30 on: November 29, 2018, 12:38:55 pm »
just installed the pathfinders after 1 philips crapped out after 4000 miles.after reading the info on this sight, i opted for the pathfinders.installed one of the pathfinders and left the still working philips in, started up and the philips looked anemic beside the pathfinder. i mean holy sunspot batman, i couldn't believe the brightness. thanks for the info on this sight... :)
Offline robertv
  • Go Hawks!
« Reply #31 on: November 29, 2018, 03:10:51 pm »
I remember the thread and talk about the Evitek's and at the time, someone suggested the AdvMonster H4 R3's.
http://stores.advmonster.com/h4-r3-led-headlight/
So I bought the AdvMonsters early last year and agree its not necessarily about the lumens, but the beam patterns and cutoff. Lights are exposed enough on the sides during our fall rides very well that I'm able to see deer at a distance. No fans and a mesh heatsink-like which has worked well both in the hot and cold rides. On the summer rides I've been on, I'm been complimented on how bright they are and able to see from a distance where I'm at! They've come down in price and are a better buy over the halogens.
2008 C14, silver [current]
2000 C10, red [sold]
Offline Jorge
  • COG#: 9297
« Reply #32 on: November 30, 2018, 01:28:46 am »
I work with an electrical engineer that had a lot of exposure to bright LEDs in the past. His comment is that LEDs provide 8-10x the light output per Watt as halogens. Based on this, the LEDs in Ted's link are right on.
It claims 1000Lm for 60W halogens, and 4000 Lm for 28W LEDs... the ratio is right where it should be.
I plan to replace our car and Suburban, and motorhome bulbs with LEDs soon...
Offline SVonhof
  • Riding since 1996
« Reply #33 on: December 06, 2018, 02:46:42 pm »
You guys have me considering getting some of these for my 2006 F150.
My wife drives it daily to work and back in 2013 she was in an accident that crunched the front end. The replacement headlights just don't seem as bright as the factory lights, even though they were replaced with OEM. She has complained about it ever since and of course, her eyes are getting older as well.
We need 9008/H13's for the F150 vs the H4 for the Concours.
I can't find Pathfinders that look anything like that in the H13, but there are Beamtech's that look like it for $39 for the pair:
https://www.amazon.com/BEAMTECH-Headlight-8000Lumens-Extremely-Conversion/dp/B06XHCQ8KY
Offline SVonhof
  • Riding since 1996
« Reply #34 on: December 12, 2018, 01:34:16 am »
FYI, I ended up getting the BeamTech LED's for our F150 and it was an easy install. The only issue is that if you turn on the fog lights, the high beams turn on. I contacted BeamTech and they replied within about 15 minutes saying they will send me a resistor to plug in to fix it. That should be here in a few days.
I will report back to see if that fixes it on the truck and after some time passes for longevity, but so far so good.
The light pattern is better and brighter and my wife was impressed.
After seeing how these do, I may order some for the Concours as well. For $30 on the BeamTech web site ($39 on Amazon), it's hard to beat so far.
Offline Egodriver71
  • I'm in here somewhere
  • COG#: 8321
« Reply #35 on: December 12, 2018, 11:06:00 am »
Look into this place
https://headlightrevolution.com/
I haven't bought any from them, but I have watched their videos and they seem to be all about PROPER LED replacements, not just something that fits.
Thomas Mann
Jacksonville, FL
COG #8321
Offline freebird6
  • COG#: 11012
« Reply #36 on: December 12, 2018, 04:52:56 pm »
gooooing on year 4 with the Cyclops. Probably going to jinx my self ....still running the Kisan LED mode modulator with it as well
« Reply #37 on: February 01, 2019, 02:03:52 pm »
I like that little shield. I tried to put a set of HB5 (9007) in my truck and it blew light out everywhere.. Had to send them back.  I am thinking that shield may do what I need it to do - Not blind others.
2000 Red C10 1052 kit
« Reply #38 on: February 01, 2019, 02:44:29 pm »
I think the little shield will make a difference and prevent  blinding others as badly..
Offline Roach
  • COG#: 12979
« Reply #39 on: March 12, 2019, 08:23:42 pm »
Pathefinder LEDs with Switchback signals and LED spotlights.
So...I want to order this set before the boss (wife) finds out but I'm curiuos about something:
Do you think the connection being NON-WEATHER RESISTANT will be a problem????
What's YOUR opinion???? :??:
« Reply #40 on: March 12, 2019, 08:26:22 pm »
It isn't a problem.
Most headlight connections are not much better.
On many, the headlight plug is open to the elements so much you can see the wires inside.
Offline Rexter
« Reply #41 on: March 13, 2019, 12:36:46 am »
I have ridden in light rain and some heavy fog/mist that might as well have been rain. I have had no issues at all.
Offline Roach
  • COG#: 12979
« Reply #42 on: March 13, 2019, 12:56:18 am »
It isn't a problem.
Thanks guys!!!  I think I'll order me some while the wife is out!!!
Offline Roach
  • COG#: 12979
« Reply #43 on: March 27, 2019, 01:47:04 pm »
$75ea
I just installed my set two nights ago and was able to ride to work (at 0'dark thirty) the next morning.  While I was relatively pleased with the change, the aim seemed a little off so I checked them last night against the garage door and made a small adjustment.  I also noticed the CUTOFF for the beam appears to be sharper on the bottom.
JDSCO stated he was able to rotate the LEDs in their housing.  I do notice the small allen type screw at the base but I've yet to access it.  Is that how you rotated yours??  The H4 bulb baseplate is pretty set in how it'll fit in the housing so I'm only ASSUMING that's what you did.  Would you kindly share what size allen you used to access that screw??  I'm trying to fine-tune things now!!!
Thanks in advance!!!
-James
« Reply #44 on: March 27, 2019, 01:58:42 pm »
On one of the lights we were discussing, {I forget which light it was} there is a small plate sticking out from the side that I "think" would block the light beam so that it would not blind oncoming drivers.
Offline Bruiser
  • Bruiser
« Reply #45 on: May 09, 2019, 02:56:11 am »
SoCal offered up these spec's
Pathfinder H4SFS, no external driver, 4000k lumen@6000k color and 2-3amp draw
Pathfinder kwledkt kit, external driver, 4000k@6000k color and 2-3amp draw
The Pathfinder H4SFS doesn't require stowing a driver
EBAY has dozens of H4 LED's for $3.00 each. EBAY Pathfinders are $50+. That's a huge spread!
eBay is your friend!
Bruiser
2012 Kawasaki C14
93 Kawasaki C10
1982 Honda CX500 Turbo
1980 Kawasaki KZ1000ST
1978 Honda CB750F
1976 Kawasaki KZ400
1976 Honda 750K
1973 Honda CB500K
1973 Honda SL175
1972 Honda SL125
Offline Eric
« Reply #46 on: May 17, 2019, 05:20:52 pm »
H4 LED Headlight Bulbs, 7200LM 9003 Head Lamps, Car Replacement Lights of Halogen and Xenon Kit, 6500K White 8V-36V, 2 Lamps
These are waiting for me at home.  Should the "bulbs" be facing left and right, or up and down?  Or, like in a car, they only go in 1 way because of the 3 tabs?
2012 Concours - My new baby!
1981 KL250 - ridden to death
