Author Topic: Luggage rack for kaw monolock case  (Read 12293 times)
Offline 08 Silver Bullet
« on: March 24, 2016, 05:38:37 pm »
I have a Kawasaki monolock top case but want to replace the stock plastic luggage rack with an aluminum one.
I've heard several times that many racks won't work with the monolock case. Does anyone know of an aftermarket rack that will work or possibly have one they want to sell?
I'm mainly looking to make sure the case is mounted solid as it has a backrest and I want to make sure it's safe for my wife to lean against it.
Thanks for any info you can give.
Offline sam_uk
« Last Edit: March 24, 2016, 06:59:16 pm by sam_uk »
Offline AmphibSailor
  • Cibolo, TX Hooligan
  • COG#: 12210
Re: Luggage rack for kaw monolock case
« Reply #2 on: March 24, 2016, 07:41:58 pm »
Super!  Much nicer than the original plastic adapter plate! :beerchug:
Offline Fais
« Reply #3 on: March 24, 2016, 07:52:52 pm »
My rack comes from PCA and I just mounted the Monolock rack securely onto it.
Offline gPink
  • MMVIII C XIV
« Reply #4 on: March 24, 2016, 09:02:36 pm »
Check with Phil... http://www.philsfarkels.com/
« Reply #5 on: March 24, 2016, 09:55:55 pm »
Thanks. I had seen notes on phils site that his rack wouldn't work with the monolock case, but looks like there's some solid options. Thanks.
Offline Fais
« Reply #6 on: March 24, 2016, 10:33:30 pm »
I'm inder the impression that the PCA rack is a simpler 'Phil's Rack' and the PCA backrest is from Cee Baileys.
Whatever the case - you seem to be on track to mount it nicely for the wife :great:
  • COG#: 12210
« Reply #7 on: March 25, 2016, 03:12:22 am »
I just went through this conversation with Phil.  The monolock case comes with the mount shown in Fais' post.  Just use that mount to fit the monolock case to your (Phil's) rack. (Same as in Fais' post.)
 :great:
Offline gsun
  • CDA #560
  • COG#: 9127
« Reply #8 on: March 25, 2016, 03:26:05 am »
I have Phils rack and the mono lock. Works fine.
  • COG#: 12210
« Reply #9 on: March 25, 2016, 04:48:45 am »
You had to use the mount pictured in Fais' post, correct?
Offline sam_uk
« Reply #10 on: March 25, 2016, 05:02:05 am »
hered my mod to fit box to phils rack. made some plates to move the rack back for more room
Offline gsun
  • CDA #560
  • COG#: 9127
« Reply #11 on: March 25, 2016, 06:22:16 pm »
Yes but I do have the smaller OEM case and maybe you would have to move the rack farther back to accommodate a larger case but the base does fit on the rack. The base has a honeycomb under the cover and you can put the bolts through a bunch of different places.
« Last Edit: March 25, 2016, 06:27:07 pm by gsun »
  • COG#: 12210
« Reply #12 on: March 30, 2016, 06:55:44 pm »
Offline gsun
  • CDA #560
  • COG#: 9127
« Reply #13 on: March 30, 2016, 10:54:01 pm »
It says this adapter is no longer available when clicking on the URL.
  • COG#: 12210
« Reply #14 on: March 31, 2016, 01:43:50 am »
The second URL worked fine for me.  Use the key words Givi Monolock on SW Motech's site to search for it.
PATRICK :beerchug:
Offline Zarticus
  • COG#: 10785
« Reply #15 on: April 02, 2016, 03:31:36 am »
PATRICK :beerchug:
The 1st url is for twisted throttle who is the U.S. SW Motech importer & they no longer carry this, The 2nd url is for SW Motech direct from overseas & they still carry them but will not ship to the U.S. because they say you have to go threw their U.S. importer which is full throttle. Kinda like a catch 22, I managed to figure out a way & mine will be here in a couple weeks  :)
1986 Honda V65 Magna, Black
1984 Honda V65 Magna, Black
1983 Honda V45 Sabre, Red
  • COG#: 12210
« Reply #16 on: April 02, 2016, 06:47:47 am »
I just got mine delivered yesterday.  They're about 3 hours up the road from me.  Sent me a nice coffee cup, too! :beerchug:
« Last Edit: April 02, 2016, 10:06:53 am by AmphibSailor »
Offline Zarticus
  • COG#: 10785
« Reply #17 on: April 02, 2016, 01:35:51 pm »
Can you post a picture of the directions ?. It would be nice to see how to install while I wait for mine to arrive from over the pond  :beerchug:
  • COG#: 12210
« Reply #18 on: April 02, 2016, 05:03:49 pm »
To me, replacing the oem plastic gives the whole assembly a more solid feeling.  I think the OP would be satisfied that his wife is going to be able to lean against a solidly mounted trunk with Phil's rack and the SW-Motech bracket.
For Z, the instructions are below...I don't think you'll need them.  It's pretty self explanatory.
Installed.
Included are a handful of rubber bumpers that my rack is not drilled for (Phil's).  I'll probably go ahead and use some thin foam under the top case to prevent any rattles.  The rack was pre-drilled and tapped in all the right places.  :beerchug:
« Last Edit: April 02, 2016, 05:07:16 pm by AmphibSailor »
Offline NYbiomed
  • COG#: 11887
« Reply #19 on: April 02, 2016, 07:44:59 pm »
So wait, where did you get yours from if TT is out of stock? 3 hrs north of where?
I have the nylon Monolock baseplate that came with my block, but it has always been missing the plastic cover that hides the honeycomb, and has always looked ugly, the steel adapter kit is a great solution for me.
2002 Honda VTR1000F SuperHawk
2009 Kawasaki Concours 14 ABS
Offline ChrisD
  • COG#: 12153
« Reply #20 on: April 02, 2016, 08:01:47 pm »
Amphib is stationed in Germany like me.  I just ordered mine direct from SW-MoTech today too.
Offline Zarticus
  • COG#: 10785
« Reply #21 on: April 02, 2016, 10:33:08 pm »
Installed.
Thanks for the pictures  :beerchug:, I have a phils rack also but mine is not pre-drilled. The bottom does have holes started in the locations that look like where this will mount, I think I just have to drill them out the rest of the way. I cant' wait to get this & stop using the crappy plastic plate
Offline NYbiomed
  • COG#: 11887
« Reply #22 on: April 02, 2016, 10:35:00 pm »
PATRICK :beerchug:
Please tell, did you call SW Motech direct? How did you get one to ship if TT not gonna restock?
Any chance one you lucky boys stationed out in Germany can help a fellow 22-yr retired Vet out and ship me one If I PayPal you?
Ret. Master Sgt Rick Lass
« Last Edit: April 02, 2016, 10:50:19 pm by NYbiomed »
  • COG#: 12210
« Reply #23 on: April 03, 2016, 05:34:35 am »
I went straight to SW-MoTech.  The second link was their website.  They seem to be some nice folks to deal with....
 :beerchug:
PATRICK
Offline RobW
  • Vrooom...Braaap
  • COG#: 12099
« Reply #24 on: April 07, 2016, 06:10:43 pm »
Twisted Throttle has discontinued stocking the adapter kit, and SWMotech has an agreement to not ship direct to the USA. If you want this kit and you are in the USA...Order from RDmoto pay in Euro's using PayPal. Cost was less than $45 USD shipped. The link:
http://www.rdmoto.eu/en/standalone/product/35313
Regards,
Rob
09 Kawasaki C14, 09 250 Ninja, 07 HD Wide Glide
07 Suzuki GS500F, 05 HD Road Glide, 03 Ducati M1000S
02 Zuma, 99 Yamaha Vmax, 90 Honda CB1
89 Honda VTR250, 72 Kawasaki GA90SS
