Author Topic: ASV Brake and Clutch levers  (Read 1206 times)
Offline Ridge Runner
  • COG#: 9424
« on: April 30, 2011, 07:44:34 pm »
Hello my fellow COG'S. I'm wanting to install a set of AVS C5 Levers on my 2011 C14 but the problem is with the new 2011 Connie C14 ABS the aftermarket parts are slow to hit the market, My question is this, How far back can I go in years for a proper match? Any help will be great. See you at the Wenatchee WA. Rally....
Offline Tactical_Mik
  • COG#: 9047
Re: ASV Brake and Clutch levers
« Reply #1 on: April 30, 2011, 08:13:06 pm »
No change in clutch lever between the 09 and 10 model.  If all holds the same, 11 will be no different.  13236 is the part number, call a shop and get the part number for the 11 and see if it is the same.
Lonnie
« Reply #2 on: April 30, 2011, 11:49:42 pm »
I'm 99% sure that 2008-2011 levers are all the same!
  • COG#: 9424
« Reply #3 on: May 07, 2011, 10:17:07 pm »
Thanks for the great info, Motomummy.com has a a set of ASV C5 Unbreakable levers, Brake and Clutch for $210.00 you can even pick the color you want for the nurled turn device...
