Author Topic: Mounting a Garmin  (Read 5852 times)
Offline gsun
  • CDA #560
  • COG#: 9127
Mounting a Garmin
« on: March 09, 2013, 11:39:37 pm »
I have a Garmin 3760T. I know, it's a car unit, but don't want to shell out hundreds for a Zumo 660 or other. I have a Tech mount (see pic) and was wondering the best way to attach to it. On the Tech mount web site they have a few things. I think the other two pics will do the trick. The Gripper holder and the adapter to hold it to the mount. Anybody do this?
Offline Gypsy JR
  • American Gypsy
  • Living the Gypsy Life
  • COG#: 9279
Re: Mounting a Garmin
« Reply #1 on: March 09, 2013, 11:52:59 pm »
I used a ProjekD Handi-stick and a Techmount from Twisted Throttle so the GPS sits up just below eye level.
So I don't have to look down to see it, but its not in the way either. Had this arrangement for a year, used it from MD to NW Arkansas for the 2012 National and back, and it worked fantastic.
http://projektd.com/product_info.php?cPath=27_39_46&products_id=162
http://www.twistedthrottle.com/techmount-universal-7-8-22mm-up-to-1-1-4-32mm-handlebar-mount-black-silver-or-chrome
« Last Edit: March 09, 2013, 11:56:55 pm by JR »
Offline TJ
« Reply #2 on: March 09, 2013, 11:58:31 pm »
Pretty sure Ram has a mount that will attach to the base and they sell a cradle for the unit as well.
Offline Russ
« Reply #3 on: March 10, 2013, 12:43:39 am »
I used a Ram mount off of the raisers from Murphs...  I think I'll like it...
Your not the only one that wont shell out the bucks for a Zumo, I'm also using a automotive Garmin.
08 C14
05 Victory Ness Vegas
SOLD - 06 KLR650, 04 VT1100 Spirit, 01 VT750 ACE, 1986 VFR750F, 1991 CBR1000F
AMA# 2794531
Offline Jim M.
  • COG#: 7951
« Reply #4 on: March 10, 2013, 01:14:05 am »
I'm using this exact set up and love it!
Offline gsun
  • CDA #560
  • COG#: 9127
« Reply #5 on: March 10, 2013, 01:45:19 am »
I could only find ball mounts on their web site.
Offline Glenn
  • COG#: 10332
  • Membership Level: Marketing Officer
« Reply #6 on: March 10, 2013, 02:56:57 am »
I use the exact same setup you have here.  I really like the Tech Mount, maybe not as happy with the Gripper.  MY GPS hasn't come loose, it's just that after a year of use, it doesn't open and close as well as it should, and I would prefer something with a more positive hold.  I have a fairly large GPS, and I couldn't fine a holder that would fit.
Offline Pistole
« Reply #7 on: March 10, 2013, 03:25:16 am »
- no worries. I have been using a car unit (an ancient Garmin Nuvi something) for ages and its been reliable through thousands of miles and rain/heat and vibration.
- no issues with accessing the touch screen with a gloved hand either.
cheers.
Offline gsun
  • CDA #560
  • COG#: 9127
« Reply #8 on: March 10, 2013, 03:37:02 am »
Did you try some silicone spray of other? Or is it just worn out?
Offline Glenn
  • COG#: 10332
« Reply #9 on: March 10, 2013, 03:42:36 am »
I haven't, and I do think it would help, but mostly, I would prefer something that holds it a little more securely.
Offline devilboy
  • COG#: 10552
  • Membership Level: Terminated / Expired
« Reply #10 on: March 10, 2013, 12:34:35 pm »
I have the Techmount  like you do and bought the GPS water resistant case for my Automotive nuvi 3590. it is like a fraction of an inch too small.  :'(
http://www.techmounts.com/products/index.php?page_function=detail&product_id=186   the nuvi is 5.4 in wide and case fits up to 5.3
if you have a smaller Nuvi the case would be a slam dunk..  I am still trying to figure out what to do....
Offline TJ
« Last Edit: March 10, 2013, 03:44:04 pm by TJ »
Offline smooth_operator
  • COG#: 10773
« Reply #12 on: March 10, 2013, 04:33:27 pm »
Will you be sporting one of them fancy zip lock plastic bags when it rains? :motonoises: :motonoises: :motonoises:
--Thomas Jefferson
Offline PaleRider
« Reply #13 on: March 10, 2013, 04:52:01 pm »
I do.
Fact is I use the GPS a few times a year so it's hard to justify spending my hard earned Farkle money on a expensive GPS. My $100.00 Nuvi has been on 4 different motorcycles. Ram made a mounting kit for so it works.
The trade off is it wont do routes. This can be a pain in the a** those few times a year I would like it to.
Have Owned 2004 Honda VFR, 2004 Honda ST1300, 2000 Triumph Sprint ST.
Now 2012 ZG1400 in Pearl Arabian Red
Offline devilboy
  • COG#: 10552
« Reply #14 on: March 10, 2013, 05:16:53 pm »
I do not have the measurements for the Tech mount but one of these would possibly mount to your base:
http://www.rammount.com/Products/Components/tabid/798/Default.aspx[/url
I use the 1"
[url=http://www.rammount.com/EmptyPages/COMPONENTS/BCOMPONENTS/tabid/1556/Default.aspx]http://www.rammount.com/EmptyPages/COMPONENTS/BCOMPONENTS/tabid/1556/Default.aspx
3760 cradles
http://www.rammount.com/SearchResults/tabid/38/searchBy/description/criteria/051055054048/Default.aspx
Thanks TJ  I will figure it out. I have the quick release  techmount plate so it has to fit....
RE edit  I believe my ram ball has to be 5/8" . is that diameter or circumference of ball??  It's Diameter  LOL
« Last Edit: March 10, 2013, 05:25:04 pm by devilboy »
Offline TJ
« Reply #15 on: March 10, 2013, 05:51:19 pm »
Offline devilboy
  • COG#: 10552
« Reply #16 on: March 10, 2013, 11:08:00 pm »
This has a 9/16 ball, pretty close.
http://www.rammount.com/CatalogResults/PartDetails/tabid/63/partid/082065077045065045050051056085/Default.aspx
It is probably 9/16 tough to measure exactly. Ram mounts says that  the 9/16 ball is meant for light duty applications (1 lb or less)without much vibration.  I am not sure this is the way to go. I may have to start from scratch >:(
Offline gsun
  • CDA #560
  • COG#: 9127
« Reply #17 on: March 11, 2013, 03:47:55 am »
I looked at that one, but it seems that it would mess up the tough screen with the flexible plastic cover.
Offline gsun
  • CDA #560
  • COG#: 9127
« Reply #18 on: March 11, 2013, 03:48:59 am »
How did you know???
Offline gsun
  • CDA #560
  • COG#: 9127
« Reply #19 on: March 11, 2013, 03:54:17 am »
OK, so I'm a bit slow! There is a Ram ball mount to attach to the Tech mount base. Then get a Ram cradle to fit the Garmin. Cool. Going to look into that one.
Offline devilboy
  • COG#: 10552
« Reply #20 on: March 11, 2013, 08:05:59 am »
The one problem with the garmin connector  is that if you want it powered via mini usb/usb. you need to use the Garmin  cradle that came with the  nuvi.
that has a mini usb that will power unit. if you dont use the cradle piece the other mini usb on the unit itself is only meant to transfer data..
Offline TJ
« Reply #21 on: March 11, 2013, 08:41:30 pm »
I use the Ram Cradle and the cigarette power cable with no issues but your statement is true.   In addition the 765T is an inexpensive unit that WILL do routes.
« Last Edit: March 11, 2013, 08:47:39 pm by TJ »
Offline gsun
  • CDA #560
  • COG#: 9127
« Reply #22 on: March 12, 2013, 03:15:45 am »
Yeah, I figured that but the cradle it came with has a suction cup. Useless on a bike. Found a MC mount store near me. What are the chances of that? :13: Going there tomorrow. Bringing all my crap along.
In case anybody is interested:
http://www.morrisonmotomounts.com/
Offline devilboy
  • COG#: 10552
« Reply #23 on: March 12, 2013, 06:33:16 am »
I would be interested in hearing what they have to say. also 9/16 ram ball is "softer " Material than the hard plastic  ball that comes attached to the suction mount...
Offline gsun
  • CDA #560
  • COG#: 9127
« Reply #24 on: March 13, 2013, 12:58:34 am »
OK. Talked to Peter at morrisonmtotmounts.com He knows his stuff. I ended up ordering this:
http://www.morrisonmotomounts.com/product/garmin-nuvi-34xx-37xx-series-gps-cradle-ga39/
The Garmin, including the Garmin powered cradle, fits into this Ram mount. No adapters needed and it screws directly to the Techmount base. Too simple.
Peter is like Murph. Works out of home and dosen't mind talking.
« Last Edit: March 13, 2013, 01:46:34 am by gsun »
