Author Topic: Which Givi Top Case luggage rack?  (Read 5216 times)
Offline hlh1
  • COG#: 548
« on: May 21, 2016, 05:58:35 pm »
Anyone know which Givi top case luggage rack will work with my Kawasaki 09 top case?  I need more space when the wife rides.
http://www.giviusa.com/givi-products/case-accessories/top-case-luggage-racks
Offline Fais
Re: Which Givi Top Case luggage rack?
« Reply #1 on: May 21, 2016, 07:14:07 pm »
Post a pic of your case or tell us if it's a 39 or 47 liter.
I ordered the wrong lid once even though I had the size right. It seems they did change em up over the years.
Offline hlh1
  • COG#: 548
« Reply #2 on: May 21, 2016, 07:34:26 pm »
How would I know which size it is?
Offline Fais
« Reply #3 on: May 21, 2016, 07:43:32 pm »
I'm not much help - but am also curious about the luggage racks ...
I know this is a 49liter factory case - but there is a newer and older one - not sure which you have or which rack to get for that matter....
Offline Zarticus
  • COG#: 10785
« Reply #4 on: May 21, 2016, 08:35:44 pm »
The factory case is 47 liter & I used the Givi 46 liter rack with no problem  :beerchug:
1986 Honda V65 Magna, Black
1984 Honda V65 Magna, Black
1983 Honda V45 Sabre, Red
Offline Fais
« Reply #5 on: May 21, 2016, 09:10:17 pm »
Thanks Z -  :beerchug:
I'm going to think about going homemade for this before I spend $80. I'll think about it - then I'll spend the $80  :truce:  :)
BTW - that pic is in front of the grocery/deli in Helen. Great place 😋
Offline philipintexas
    • Phils Farkels
  • COG#: 10175
« Reply #6 on: May 21, 2016, 09:24:23 pm »
Since it's a MonoKEY trunk, this will hold it very securely... However it's more than $80. But then again it's 3/8" aluminum instead of plastic.
Offline Fais
« Reply #7 on: May 21, 2016, 09:28:29 pm »
I have had your rack on 3 Connies now  :beerchug:
Worth every penny  :great:
« Reply #8 on: May 21, 2016, 10:42:01 pm »
Concur!
Great product.
Holds my 55Givi rock solid. Even with a full load and Ms. Pillion leaning against it.
 :great:
My Horns have Horns.
Offline hlh1
  • COG#: 548
« Reply #9 on: May 21, 2016, 11:31:20 pm »
That's the info I'm looking for, thanks!
I'll be ordering this shortly:
http://www.giviusa.com/givi-products/case-accessories/top-case-luggage-racks/e107-topcase-rack-v46-case-detail
Offline Zarticus
  • COG#: 10785
« Reply #10 on: May 22, 2016, 03:28:35 am »
The factory trunk is a Monolock
    • Phils Farkels
  • COG#: 10175
« Reply #11 on: May 22, 2016, 01:35:48 pm »
I think last year Kawasaki changed to the MonoKEY system. Everything depends on which trunk the poster purchased.
Offline hlh1
  • COG#: 548
« Reply #12 on: May 22, 2016, 03:44:47 pm »
I'll post some pics in a bit.
Offline hlh1
  • COG#: 548
« Reply #13 on: May 22, 2016, 09:15:16 pm »
Ok, here's the top box and mount:
Offline AmphibSailor
  • Cibolo, TX Hooligan
  • COG#: 12210
« Reply #14 on: May 23, 2016, 03:18:42 am »
Looks like the Monolock.  Phil's Rack will work with the proper adapter.  I believe he will add it to the rack (additional cost) if you order it from him.  Otherwise, either use the plastic piece you already have or buy the adapter discussed the separate thread hyperlinked below. :great:
Monolock Adapter
« Last Edit: May 23, 2016, 03:23:12 am by AmphibSailor »
Offline hlh1
  • COG#: 548
« Reply #15 on: May 23, 2016, 10:18:46 am »
Monolock Adapter
I have Phil's rack for my Monokey box, but I'm not talking about Phil's racks here (as fantastic as they are).  I'm needing a luggage rack on top of my top case and that's what I bought at the above link.
Offline Zarticus
  • COG#: 10785
« Reply #16 on: May 23, 2016, 11:13:01 am »
I have the exact same trunk, It's a Monolock & is a 47 liter Kawasaki factory trunk the same from 2009-2014. 2015 they changed the trunk shape & it's now a Monokey. Phil's adapter for his racks works only with Monokey trunks & will not work with hlh1's trunk. You have to use the adapter PLATE that comes with a Monolock trunk to work on ANY rack. You can get the SW MOTO adapter to use a Monolock trunk on a rack eliminating the need to use the adapter PLATE. As I posted earlier I have a Givi 46 liter luggage rack on my 47 liter factory trunk which is the same as hlh1's & works perfect. Sorry to be long winded but I wanted to make sure the correct information is out there to help everyone out  :beerchug:
    • Phils Farkels
  • COG#: 10175
« Reply #17 on: May 23, 2016, 01:06:08 pm »
I'm sorry, I mis-read the question. He's looking for a rack to go ON TOP OF THE TRUNK.
Offline hlh1
  • COG#: 548
« Reply #18 on: May 23, 2016, 01:20:36 pm »
Bingo!  Thanks Phil.
Offline Jhinderliter
« Reply #19 on: June 01, 2016, 03:39:41 pm »
[/quote]
[/quote]
where do you order this?
Offline hlh1
  • COG#: 548
« Reply #20 on: June 01, 2016, 03:53:20 pm »
[/quote]
[/quote]
I went through www.revzilla.com
Offline denver6
  • COG#: 10119
« Reply #21 on: June 02, 2016, 04:18:05 am »
I have a large CooCase (47 liter maybe?) and I ordered the v46 Givi rack. But the lid of my case is too round making the legs on the rack too short. I think I would have been better off to have ordered the e159 rack - it looks like it has longer legs. I have been messing with some spacers from Ace hardware to extend the legs and raise up the rack. I only need a little less than half an inch on each leg.
'12 Black C14
COG 10119
CDA 506
Highlands Ranch, CO
    • Phils Farkels
  • COG#: 10175
« Reply #22 on: June 04, 2016, 01:31:27 pm »
denver6: If you don't find what you want, contact me directly, I can make almost anything you need.
Offline denver6
  • COG#: 10119
« Reply #23 on: June 08, 2016, 01:09:58 am »
Here are some pics of the v47 rack sitting on my 50L Coocase. You can see that the legs are too short for the dome. I think I can get by with just some extensions in the front. I don't think I need to extend all four legs.
Phil - I have your rack already - my Coocase is mounted on it. I don't think I would even have my case any longer if I did not have your rack. Thoughts on making a top rack for a top box?
No extensions:
Extensions on the front only:
Extensions on all four legs:
'12 Black C14
COG 10119
CDA 506
Highlands Ranch, CO
