Author Topic: Murphs bearing shifter kit  (Read 10619 times)
Offline mrclean
« on: January 14, 2014, 02:06:02 am »
Just installed the bearings and one of the bearings is sticking out of the shifter approximately 1/16" of an inch, I can measure it with calipers to get an exact measurement. Is this normal? Has anyone else experienced this? Thanks, Ken
Offline mrclean
Re: Murphs bearing shifter kit
« Reply #1 on: January 14, 2014, 03:28:27 am »
Went ahead and installed it after giving it some though. The lit tle bit it was sticking out is actually a good thing so the shifter doesn't drag against the mount, although with the two supplied washers it wouldn't anyway. Murph is a smart guy!  :beerchug:
Also raised my shifter up a little to reduce the angleon my ankle. Very e asy job thanks to the great instructions!
Offline Racerboy
« Reply #2 on: January 14, 2014, 04:23:22 am »
Did it make a difference to the shifting action?
Offline rob
« Reply #3 on: January 14, 2014, 10:51:08 am »
Personally I think it's one of those "in the head" differences then an actual measurable one....but for $20 it's worth it.
Offline mrclean
« Reply #4 on: January 14, 2014, 11:49:08 am »
I'll be riding today and let you know, it was raining last night so I didn't get to ride.  :great:
Offline Gypsy JR
  • American Gypsy
  • Living the Gypsy Life
  • COG#: 9279
« Reply #5 on: January 14, 2014, 12:28:06 pm »
Technically, there should be a difference in feel. The OEM has bushings, the one Murph sells has bearings. So it should be smoother. Can a human feel the difference? Don't know, but I have one still waiting to be put on, and I guess I'll find out.
Offline JeffP
  • Jeff In NC
  • COG#: 10856
« Reply #6 on: January 14, 2014, 02:10:32 pm »
I installed this farkle last spring. Not sure if it's all in my head or not, but I think it DOES shift much smoother.
2008 Neutron Silver C14
2007 Honda CRF250R
Offline rcannon409
« Reply #7 on: January 14, 2014, 02:24:51 pm »
I bought one for my Concours 14 and really liked it. When I bought my Ninja 1000, I was able to send Murph the measurements and he built  a kit for that bike  as well.
Worth it? Yes.  It eliminates a lot of slop from the shift linkage.  Not everything. You still have  a little play in the Hemi-joints, but it helps a great deal.  In a way, its similar to the advantage you get from 500.00 dollar rearsets on a sportbike.   Plus, it eliminates wear on the aluminum pedal as it pivots around the bolt holding the lever in place.  Its like that feel of having high quality brake and clutch levers. Some dont mind floppy levers, but I hate them.
My old sv 650 had so much play in the shift lever, you could move it up and down 1/2 inch before it did anything. The bearing kit would have stopped this from wearing so badly after 25,000 miles.
Offline mrclean
« Reply #8 on: January 14, 2014, 04:10:08 pm »
Just went for a twenty mile hop and it does seem smoother, now I just need to take up some of the playing the shifter. I have about an inch of travel while shifting. I'm assuming I adjust only one rod end to decrease the travel?
Overall $21 well spent!  ;D
Offline rcannon409
« Reply #9 on: January 15, 2014, 02:08:02 pm »
You cannot really adjust the overall travel.  You can adjust how high, or low the shifter sits in relation to your foot.
Offline seagiant1
« Reply #10 on: January 17, 2014, 05:44:22 pm »
Hi,
      I put in the kit and was dissapointed in the bolt to ID of the bearings! If you don't have a press fit to the inside and out side of the bearing then you are still using the old "bushing" idea and not really utilizing the bearing!
  To fix this I loctited the inside bearing race with the install bolt and all is well! A better but more expensive idea would be a custom od bolt to actually fit the inside bearing  race,instead of something off shelf!
Online BDF
« Reply #11 on: January 17, 2014, 05:48:19 pm »
I have not seen one of these kits in the flesh but as I understand it, the bolt has a flange that only contacts the inner races- is that correct? If so, even though the inner race is not a tight fit on the bolt, the assembly will still act properly as a rolling bearing because the inner races are pinched by the end force of the bolt when it is tightened.
Brian
Hi,
Offline The Pope
  • North Carolina AAD
  • COG#: 9994
« Reply #12 on: January 17, 2014, 09:38:31 pm »
Brian
You are correct Brian. I've had this kit on my bike for ruffly 20k miles. IMHO it helps. Now to what extent, that's a rider perceived thing like seats. But for me, I'd do it again.
The Pope
Offline seagiant1
« Reply #13 on: January 18, 2014, 06:34:55 pm »
Brian
Hi,
      I'm not putting the kit down well worth the money and IMO is a better MT! However I would be remiss not to be honest in my "review"!
  There is no "flange" it is just a bolt like you buy at ACE Hardware. I don't see this as giving a better fit to the inside race of the bearing with just a little tension. The "gap filling" loctite works great and makes the kit work as it should and feels smoother to me!
  Oh yea, I'm a Marine Engineer,which dosen't mean anything but I do know which end of the wrench to hold! ;D
Offline mrclean
« Reply #14 on: January 18, 2014, 07:26:24 pm »
Brian
Hi,
I always hold the opposite end I'm about to throw  :))
Offline fartymarty
  • COG#: 9712
« Reply #15 on: January 18, 2014, 08:05:38 pm »
Murph's had two bolts available, a button head one and a flanged one (Murph calls it a washer head bolt) or at least it appears flanged to me, but I'm no engineer.
Quote from: Murph's Bearinged Up Shifter pdf file
Our parts from start to finish are: Bolthead, Stainless Steel Shim, bearing, bushing,bearing, bushing,bearing, stainless steel shim.
I have not seen one of these kits in the flesh but as I understand it, the bolt has a flange stainless steel shim that only contacts the inner races- is that correct? If so, even though the inner race is not a tight fit on the bolt, the assembly will still act properly as a rolling bearing because the inner races are pinched by the end force of the bolt when it is tightened.
FIFY Brian.
Please note that Murph has a NOTE about the the OUTER races being a possible problem, not the inner races.
Quote from: Murph's website
NOTE!! We have discovered that the tolerance on the bore for the sleeve varies enough that some shifters do not have a friction fit between the shifter and the bearings , so please note YOU MAY HAVE TO LOCK-TITE the bearings to the shifter. We have also discontinued supplying the kit with the small Button head screw, and only recommend using the washer head bolt supplied with the kit.
Online BDF
« Reply #16 on: January 18, 2014, 11:44:06 pm »
I hear ya', and as I said, I do not have and have not seen one of these things 'in the flesh' but have seen photos.
I was merely addressing the thought that the inner races had to be a tight fit to the bolt (or whatever they ride against) to make the bearings function as roller bearings; the bolt head, flange, washer, or whatever else pinches the inner races together will prevent them from turning and that alone will allow the bearings to function correctly. That was my only point.
Brian
Hi,
Online BDF
« Reply #17 on: January 18, 2014, 11:47:03 pm »
Interesting. Makes sense though as this shifter would be made with some clearance designed into it while anything using rolling bearings would be a very close (slip fit) fit or an actual interference fit (press fit). The LocTite idea is probably as good as anything else; removable too if the end of the shifter mechanism was heated and the bearings pushed out later if they needed to be replaced.
Brian
Offline Pistole
« Reply #18 on: January 19, 2014, 12:51:07 am »
there is so much play in the two ball-socket joints that I can't imagine what would putting some bearings on the pedal's pivot would improve ?
Offline fartymarty
  • COG#: 9712
« Reply #19 on: January 19, 2014, 02:27:54 am »
Maybe nothing, I certainly noticed nothing different (but then my wife insists that I'm insensitive). My C14 is still under 20,000 miles so I'll report back at 100,000+ miles after I've compared mine to other high milers that didn't do the mod.
Quote from: from Murph's site
My name is Joe Fecher, and like many of you who made it here I own a Kawasaki Concours 14.
I went to lube the shifter one day, and noticed there was a cheap plastic bushing which had already worn with only 1600 miles on the bike. A quick measurement of the shifter body followed, and I knew there were bearings that would fit. The improvement from this mod is quicker, more precise, and consistent shifting. Murph has sourced parts and put together a good kit based on my original mod, and he has my blessing.
The stock setup is a plastic sleeve that is susceptible to wear and additional play (looseness).  With the sealed bearings, you get a tighter shifter which is more precise, less friction for easier shifting and more consistency.  I know it sounds like a lot of fluff, but it really made a difference in mine and I did it with only 3k on the bike....
Offline nando
  • Transport C-14
  • COG#: 10454
« Reply #20 on: January 19, 2014, 04:58:39 am »
I put a Murph bearing on my shifter...but I thought we were all doing that to contribute to a Children Foundation...no?
Offline rcannon409
« Reply #21 on: January 20, 2014, 01:02:24 pm »
As mentioned before, the bearings wont get rid of the play in the linkage, but the side to side motion, of the shift lever, is gone.  The side to side play grows as the standard plastic bushing wears.  If its assembled correctly, using the proper supplied pieces, the bearings do function.  I had to use some of the loctite stud compound on the Ninja kit, but the c14 kit was an excellent press fit.
Offline Boston Bagger
  • COG#: Forum (M)
« Reply #22 on: August 13, 2014, 05:33:52 pm »
Has anyone broken down the list a specific parts needed to make this kit?  It’s just a couple of small bearings, spacers and a couple of specific washers.
I made one of these kits for my BMW K1200GT and an entire tube of bearings is something like $12.  It’s not the price at Murphs, but rather, I tend to want pure Stainless, including the bolt.
Offline Gypsy JR
  • American Gypsy
  • COG#: 9279
« Reply #23 on: August 13, 2014, 08:43:56 pm »
You want to be careful what you screw a stainless steel bolt into. You can have issues if the bolt hole threads are aluminum and not steel.
Offline el paso
  • COG#: 10048
« Reply #24 on: August 21, 2014, 02:08:39 am »
I put Murph's bearing shifter kit on tonight and it seems to take the side to side slop out of the linkage. I'm anxious to go for a ride and try her out. Like somebody else said for $20 I'll try it.
